yet again i have more computer problems
i can't connect to any secure sites from this computer i get the error with fire fox
"The connection was refused while attempting to contact "(SECURE SITE)". i need to track an order i made and this is preventing me from doing this so any suggestions would be appreciated |
Re: yet again i have more computer problems
IE or another browser to see if its available there? Some websites simply dont support firefox yet.-Mike |
it works from other computers and it does not work with IE or fire fox on mine
Check your privacy settings. Sometimes you might have privacy//security settings to high and it wont allow certin traffic to come through. Or maybe it isnt high enough and the sites server doesnt want to send it since it is a secure sight, its going to make sure it has a clear channel. Are you using a laptop? if you are then there a other things that could be wrong ( dont wanna get into it unless i have to)
Ive been change security settings left and right with no result
How is your computer set up to connect to the internet?
Is it just that one site or is it multiple? |
only secure sites, i have roadrunner
... Do you have a router?
no
#10
Do you have a firewall?
and if it isnt too much trouble, what is your IP? [edit]and so no one tires to hack you or anything only post the FIRST TWO sections It should be formated like 255.255.255.255 only send 255.255.255.255 The easist way for me to get it is to hold down the windows key and hit "R" and that will open a run command and type in CMD and then that will open a command prompt and then type ipconfig [/edit] Your problem could be a private unregistered IP address.... Is it Wired or WIreless? Last edited by Michelle Celio : 26-11-2005 at 22:51. |
#11
his IP address would have nothing to do with it, nor would unregistered IP address nor if wired or wireless. Most likely this could be they either blocked the IP address ( did you try computers on the same network ie another computer in your house, or at different locations ie at school or library?), or this could be caused by needing to restart the browser before settings take place, maybe even restart the computer. what OS are you using? I found running my new install of 2003 server, it didn't let me into many websites period. can you tell us specifically what websites you are trying to access? also, if this is simply for an order you are trying to track, could you just access the tracking from another computer for the next couple days til you get it? or will you be having more shipments from this company? -Mike M-PUTE |
#12
It could be that if your using a firewall software with relativiely high settings it would block some sites based on known bad sites.
Just a suggestion |
#13
Funny, I had the exact same problem when I read this post. I could not access gmail, mozilla update, or any other secure site.
I just rebooted my computer and everything is working again. I have a feeling that my gmail notifier caused the problem; I was messing with it during boot-up. Perhapse it prematurely tried to use the http module and prevented it from completely loading. Whatever the real problem is, it is weird. I'd like to hear if rebooting worked, and whether or not you have gmail notifier. Good luck. |
#14
Web servers cant send information to an unregisters IP address and all private ip address are unregisterd. So when an unregisterd IP wants information from a webserver it sends its request to a proxy server and the proxy server uses it's IP address to get the information from the web server. Now if the webserver doesnt trust the proxy server it will NOT send the information. Thus, preventing the system from getting the information to the client. As for the wired//wireless aspect. Most wireless connections give you a private IP address, yet again leading to the probelm of an unregistered IP And if your wondering "Shes just in high school...she shouldnt know this" I'm taking a networking class, and im learning about this type a thing as we speak...litterally im reading my book and looking at cd. But yeah... just to inform you guys that im not just guessing And seeing as the Unregistered IP is very unlikely but still an aspect but it is most likely a firewall problem. Quote:
#15
I, nor anyone else was insulting your intelegence or knowledge. Just there's many things books get wrong or dont explain correctly. -Mike |
| Computer Horror Stories | Pat McCarthy | Chit-Chat | 24 | 29-11-2005 13:46 |
| Most computer problems... | Joel J | Chit-Chat | 6 | 27-11-2005 16:58 |
| Computer Stupidity | sanddrag | Chit-Chat | 1 | 10-07-2005 17:50 |
| Who's on FIRST: An ode to triple play | Daniel Brim | General Forum | 8 | 13-04-2005 17:51 |
| My computer loves Microsoft ARGH!! HELP ME! | team222badbrad | Chit-Chat | 12 | 29-01-2005 09:17 |
