Go to Post If my counts are correct, during the official matches 141,077 points were scored, and a minimum of 28,746 frisbees were successfully shot into goals. All without a single decapitation, severed limb, or even one porpoise becoming accidentally entangled in the nets. - dlavery [more]
Unread 27-11-2005, 13:03
Cuog's Avatar
Cuog Cuog is offline
Registered Linux User: 390661
AKA: Alex
FRC #0422
Cuog has a reputation beyond reputeCuog has a reputation beyond reputeCuog has a reputation beyond reputeCuog has a reputation beyond reputeCuog has a reputation beyond reputeCuog has a reputation beyond reputeCuog has a reputation beyond reputeCuog has a reputation beyond reputeCuog has a reputation beyond reputeCuog has a reputation beyond reputeCuog has a reputation beyond repute
Send a message via AIM to Cuog
Using camera PWM out
I have been sriting a basic code for the camera which requires the camera to use its demo mode to track colors, i then triangulate the position of the object that the camera is tracking and tell how far away it is, my only problem is that my code is designed to use the PWM input that the camera sends to the servos to move it so that it stays pointing at them,
Basically how do I get a pwm input into the RC or do I need to attach a potentiometer to the camera's mount and measure it that way?
Thanks for the help,
Cuog
KK4KQO
http://voltair.us
Too many projects, too little time.
Scripting Setup and the Camera + Serial Port Drivers CJO Programming 22 11-01-2006 17:42
Trying to import Camera code into program without. Kingofl337 Programming 1 18-02-2005 00:43
Pins to insert into PWM Header on Camera Sscamatt Programming 1 29-01-2005 02:06
FYI about using PWM 13-16 with interrupts cabbagekid2 Programming 6 22-01-2005 00:54
CMUCam2 Camera Code - Are important parts commented out? Mr. Lim Programming 4 14-01-2005 12:11
