Go to Post Dave: THEY'RE NOT DOLLIES THEY'RE MY FRIENDS! - Dorienne [more]
Unread 28-11-2005, 18:19
Billfred's Avatar
Billfred Billfred is offline
Getting a 98SE box online
So I've started the task of getting some older hardware online for certain scientific purposes. I've got four computers right now, all various forms of PIIIs (450 MHz to 1 GHz), and all of them running fresh installations of Windows 98 SE. (And before anyone asks, we've got the licenses for them.)
Problem is, two of the boxes can't seem to find the right driver for the onboard LAN. Searching online for drivers has proven fruitless as well.
Short of plopping down the seven bucks to get a new NIC and put it in, is there any way to get these things on the network?
Unread 28-11-2005, 18:21
Adam Richards's Avatar
Adam Richards Adam Richards is offline
I'm baaaaaaack.
FRC #1902 (Exploding Bacon)
Adam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond repute
Send a message via AIM to Adam Richards
Re: Getting a 98SE box online
Do you have their motherboard model numbers, or even the computer make/model?
Unread 28-11-2005, 18:24
sciguy125 sciguy125 is offline
Electrical Engineer
AKA: Phil Baltar
FRC #1351
sciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond repute
Send a message via AIM to sciguy125 Send a message via MSN to sciguy125 Send a message via Yahoo to sciguy125
If they're only running boinc, why not just put linux on them? And you'll never have to reboot them.
-----BEGIN GEEK CODE BLOCK-----
Version: 3.12
GE/S/P a-- e y-- r-- s:++ d+ h! X+++
t++ C+ P+ L++ E W++ w M-- V? PS+ PE+
5- R-- tv+ b+ DI+++ D- G
------END GEEK CODE BLOCK------
Unread 28-11-2005, 18:32
Billfred's Avatar
Everything takes reboots now and again. (Although I did go 15 days without one on my iBook.) Plus I'm right familiar with Windows 98, so chalk it up to personal preference.
One is a Gateway E-3400, with a 1 GHz PIII. The other is a Dell Optiplex GX110 with a 733 MHz PIII.
Unread 28-11-2005, 18:48
I'm baaaaaaack.
I can't locate any drivers for the Gateway, but here's where to go for the Dell one:
http://support.dell.com/
(you might have to try about 7-8 different drivers to see which one works, as they appear to have packaged the 110 with several different cards)
Unread 28-11-2005, 18:55
Billfred's Avatar
I checked Gateway's site--I can't seem to even find the E-3400 for some reason. But a little poking around with a functioning Dell similar to this one seems to have indicated it's a 3Com 3C905somethingorother. I'll burn a CD and see what develops.
Unread 28-11-2005, 19:10
Electrical Engineer
AKA: Phil Baltar
FRC #1351
That's what you think... In the last year, I've only rebooted my server 6 times. Twice because the power went out, once for a hardware upgrade, twice for software upgrades, and another because I accidently killed something I shouldn't have.
Version: 3.12
Unread 28-11-2005, 19:58
Jay H 237 Jay H 237 is offline
Down at the railroad
AKA: Jason Hartmann
FRC #0237 (Black Magic)
Rookie Year: 1999
Jay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond repute
Send a message via AIM to Jay H 237
Billfred, when you go into the control panel and look at the hardware profile does it at least show the network card and possibly a manufacturer? I imagine since you're only missing the driver that it will show up with a yellow exclamation point and not a red X next to it.
I just did an internet search and I found that the Gateway 3400 was offered with 4 different mobos from GVC, Intel, Jabil, and MSI. The latter 2 apperently had capacitor problems and the units returned to and repaired by Gateway wound up with the GVC and Intel mobos. Not knowing which is in your computer puts a new twist in locating a driver. If you can at least come up with a manufacturer for the mobo and/or the LAN then it may make things easier.
Of course the simplest thing would be to just find a new, or even used, network card to put in it if there's an available PCI slot. To be honest I think that's what you're going to have to do to network this computer even though you're trying to avoid it.
2006 Maryland Delphi "Driving Tomorrow's Technology" award
2006 Connecticut General Motor's Industrial Design award
2005 Finalists-----------New Jersey (along with our alliances again, 56 & 303)
2005 WINNERS of the Radio Shack Innovation in Control Award (not once, but twice! )
2004 WINNERS ------ Johnson & Johnson Mid-Atlantic Regional (also thanks to our alliances 56 & 303)
2004 General Motors Industrial Design Award Winners
2004 Archimedes Quarterfinalists (also thanks to our alliances 121 & 386)
NEMO _________ NonEngineering Mentor Organization
"Make it idiot proof and someone will make a better idiot!" - author unknown
Unread 28-11-2005, 20:15
Billfred's Avatar
The control panel tells me zip. I think I might have an old NIC back at home, which I'll go hunt down later this week. (It's not like I'd rather die than crack the case, but it's not like I jump for joy, either.)
On a positive note, the Dell is now online and crunching. W00t!
Unread 29-11-2005, 05:47
JohnBoucher JohnBoucher is offline
Blue Shirt
FRC #0237
JohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond repute
Try the Novell/Anthem NE2000 compatible or the Zenith Datasystems NE2000 compatible drivers.
They are supposed to be generic NIC drivers to use with any (almost) NIC.
Unread 30-11-2005, 10:41
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
Your standards are too low. I've taken a windows 98 machine that needed rebooting several times a day and installed debian on it, and now it lasts at least 60 days between reboots. I took a Windows XP machine and installed OpenBSD on it and it lasts 90 days between reboots.
Unread 30-11-2005, 13:24
Billfred's Avatar
Suppose I should qualify that--15 days until the update to 10.4.3 forced a reboot. I normally update as soon as Software Update tells me new things are available, which often triggers a reboot. I've had to do the three-finger salute (Ctrl+Flower+Power on a Mac, if you're curious) perhaps three times since I got the iBook.
Unread 29-11-2005, 15:26
Rookie Year: 1997
How much is your time worth?
Unread 30-11-2005, 07:27
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
Bill,
Since you have been inside, it is better to get the manufacturer of the motherboard and go to their site looking for drivers. Unfortunately, you may find that a PIII board may never have written drivers for 98 as it was looking to be used for NT/2000 or above. There is also the possiblity that is disabled somewhere in the BIOS, check through every screen.
Al
WB9UVJ
www.wildstang.org
________________________
Pre-manufactured control box for FIRST Ben.V.293 Technical Discussion 19 22-08-2005 12:53
Introducing the Driver Strategy Database's Online Database impulse3D Rules/Strategy 17 17-03-2005 03:04
**FIRST EMAIL**/FIRST Online Store - New logo, New styles, New ideas! Ricky Q. FIRST E-Mail Blast Archive 2 02-03-2005 22:22
box grabbing matt111 3D Animation and Competition 3 27-01-2003 23:08
Gray box limitations Tim Skloss Technical Discussion 1 23-01-2002 07:38
