Go to Post "The safety log is the log people sit on to think about the unsafe act they've just committed." - Kevin Sevcik [more]
Unread 02-05-2002, 21:01
Jeff Rodriguez Jeff Rodriguez is offline
Too young to be an 'old guy'
FRC #0155 (Technonuts)
Team Role: Teacher
Rookie Year: 1999
Jeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond repute
Send a message via AIM to Jeff Rodriguez Send a message via Yahoo to Jeff Rodriguez
80/20
173 is building a 2nd robot for fun. We want to use the 80/20 stuff, but i'm stuck in a dilemma.
For those who have used it before:
Would it be better to make the frame of the base out of the 1010 or the 1515-lite?
It looks like the 1010 is hlf as havy as the 1515, but the 1515 is twice as strong as the 1010. Which is more important? Is the strength that important, and have a bigger influence, or shouls i go with the 1010?
If you watch our matches, you will see that our drivers can get pretty crazy, and the bot will take alot of impact. Any advice you have would be great. Thanks
173, student: 1999-2002
173, mentor: 2005-2010
155, teacher: 2011-
Unread 02-05-2002, 22:29
Jnadke Jnadke is offline
Go Badgers!
#0093
Jnadke is on a distinguished road
Send a message via ICQ to Jnadke Send a message via AIM to Jnadke Send a message via Yahoo to Jnadke
I think we're using the 1515, I'm not completely sure (Bot Pic). But anyways... I think we used that and we still manage to bend one of our protection beams on the front at MMR (Front pic: it's the thing with the tinted polycarb over it). You could see the curvature when looking at it from above, but we didn't notice it until nationals...
Of course... that was hitting the goal, full-speed (12fps), without stopping. Nothing else broke... except maybe the goal.
Other than that, the stuff has held up fine. We stand on our robot all the time and nothing has broken.
The best moments of our lives fall in two categories: those that did happen and those that did not.
Unread 03-05-2002, 15:54
Alavinus's Avatar
Alavinus Alavinus is offline
Siege Weapon/Robotics Guy
AKA: Andrew LaVinus
Rookie Year: 2000
Alavinus will become famous soon enoughAlavinus will become famous soon enough
Send a message via AIM to Alavinus
extrusion
Considering the bend strength of the 1010 I think is 3600 lbs, I think the 1010 should be fine. We used it to make the entire frame of our robot,with no ill effects. (We liked to get into pushing contests too) Anyway, the only part that was more beefed up then the 1010 was the 2010 we used on our arm to make it wider. I would say that 1010 is more than adequate for the frame.
Unread 07-05-2002, 18:22
Andy A. Andy A. is offline
Getting old
FRC #0095
Team Role: Coach
Andy A. has a reputation beyond reputeAndy A. has a reputation beyond reputeAndy A. has a reputation beyond reputeAndy A. has a reputation beyond reputeAndy A. has a reputation beyond reputeAndy A. has a reputation beyond reputeAndy A. has a reputation beyond reputeAndy A. has a reputation beyond reputeAndy A. has a reputation beyond reputeAndy A. has a reputation beyond reputeAndy A. has a reputation beyond repute
Perhaps use the 1010 for the frame, and brace it with something more beefy? It means a bit more work on the frame, but 80/20 is so easy to start with.
Also, consider adding foam padding of some sort, that should take care of most impact related bends...
-Andy A.
Unread 08-05-2002, 13:33
patrickrd's Avatar
patrickrd patrickrd is offline
AKA: Patrick Dingle
Rookie Year: 1999
patrickrd is a splendid one to beholdpatrickrd is a splendid one to beholdpatrickrd is a splendid one to beholdpatrickrd is a splendid one to beholdpatrickrd is a splendid one to beholdpatrickrd is a splendid one to beholdpatrickrd is a splendid one to behold
Send a message via AIM to patrickrd
While a number like 3600 lbs may sound impressive, that is not necessarily the case.
What you care about here is a collision. As an example I will choose a pretty bad (you could say worst possible) collision of two FIRST robots. Each robot is traveling towards the other with a speed of 10 ft/sec and each robot has a mass of 130 lbs.
We can calculate the momentum of each robot:
P = (10 ft/sec)(130 lbm) = 1300 lb*ft/sec
Now when these two robots collide, conservation of momentum will cause them both to come to a complete stop. Thus the impulse caused by this collision is:
J = Pi - Pf = 1300 lbm*ft/sec - 0 = 1300 lbm*ft/sec
Now, I will assume you have a piece of extrusion on your robot that is simply supported on both ends. This piece is on the 36" side of your robot and the other robot hits only this piece and exactly right in the middle of the piece.
The next quantity that must be determined is the duration of the collision. To calculate this in reality would involve some really complex dynamics and study of elasticity of metals, so I am going to use some approximations. Again these are probably worst case. I am estimating a robot collision takes about 1/100 sec to occur. (this is absolute worst case! i speculate it takes longer)
If we assume the force is distributed equally over time during the collision (i.e. each robot exerts a constant force on the other over the timespan until both robots come to a stop), we can calculate the average force from the impulse:
F[avg] = J/t = (1300 lbm*ft/sec)/(0.1 sec) = 130000 lbm*ft/s^2
F[avg] = 130000 lbf
So, now we have a simplified problem where we have 130000 lbf acting upon the center of a simply-supported extrusion piece. this means that each end of the extrusion has is supporting half the weight. Thus there is a reaction force of 65000 lbf on each end. The maximum moment on the beam will also occur in the middle (1.5 feet from the end) This moment is:
M = (65000 lbf)(1.5 ft) = 97500 lbf*ft
I will now convert to inches since the rest of my calculations are in inches:
M = (97500 lbf*ft)(12 in/ft) = 1170000 lbf*in
Finally, the formula for maximum stress is:
S = M*c/I
Where S = stress, M = moment, c = maximum distance from neutral axis, and I = moment of inertia about neutral axis.
FOR 1010 EXTRUSION:
I = 0.044 in^4 (from catalog)
c = 0.5" (from catalog)
S = M*c/I = (1170000 lbf*in)(0.5 in)/(0.044 in^4)
S = 13295450 lbf/in^2
FOR 1515 EXTRUSION:
I = 0.185 in^4 (from catalog)
c = 0.75" (from catalog)
S = M*c/I = (1170000 lbf*in)(0.75 in)/(0.185 in^4)
S = 4743240 lbf/in^2
Since the yield strength of aluminum is 13,000,000 lb/in^2, the 1010 extrusion will yield (permanantly deform), but the 1515 has a factor of safety of 2.7.
However, the 1010 just meets the requirements for yielding, and that is with my worst-case assumptions for everything. If it were my decision, I wouldn't hesitate to use the 1010 since I don't think my worst case scenarios would ever be satisfied.
Hope this helps answer your question
Patrick
Unread 08-05-2002, 19:55
Team Role: Teacher
Rookie Year: 1999
That helps alot. I took physics last year, and forgot all those formulas. I'm also too lazy to figure out all that That made up my mind. Thank you
155, teacher: 2011-
Bosch Aluminum Structural Framing Carl Owenby Technical Discussion 37 15-01-2003 21:11
EVERYONE, ANSWER THIS PLEASE!!! archiver 2001 10 24-06-2002 02:30
Building material archiver 2000 1 24-06-2002 00:10
Inventor Assemblies? Jon Lawton Inventor 11 27-01-2002 21:31
Bosch VS IPS Extrusion Systems kmcclary Technical Discussion 11 12-01-2002 22:44
