Go to Post I'm pretty sure Andrew Baker and Andy Baker are the same person. Then again, Andy may just be holding out on us. - Amanda Morrison [more]
Unread 16-12-2005, 14:37
Gary Dillard's Avatar Unsung FIRST Hero
Gary Dillard Gary Dillard is offline
Generator of Entropy
AKA: you know, the old bald guy
FRC #2973 (The Mad Rockers)
Rookie Year: 1998
Gary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond repute
Send a message via AIM to Gary Dillard
PWM connectors
I've found several old threads dealing with the connectors used by IFI on the PWM cables, but they all seem to end with "I think it's _____ - let me confirm it" and there's no followup post. Does anyone have the Part Numbers for the male and female Nomex connectors that IFI uses on its PWM cables, or a Digikey part number of a similar 3 pin connector (both male and female) for 24 AWG wire that we can use for routing our sensor cables to the controller?
Close enough to taste it, too far to reach it
Unread 16-12-2005, 14:44
Unsung FIRST Hero
Greg Marra Greg Marra is offline
[automate(a) for a in tasks_to_do]
FRC #5507 (Robotic Eagles)
Greg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond repute
Re: PWM connectors
I know that we have the supplies to make our own PWM cables, but offhand I do not know what part numbers they are or anything.
If no one posts sooner, I will try to let you know after our next meeting on Wednesday.
Unread 16-12-2005, 15:51
Mark McLeod's Avatar
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
Re: PWM connectors
We've used a variety of manufacturers.
The ones I currently have were purchased from Jameco
3-pin Housing - 157382
http://www.jameco.com/webapp/wcs/sto...oductId=157382
(the photo is incorrect)
Male pin - 145357
http://www.jameco.com/webapp/wcs/sto...oductId=145357
Female pin - 100765
http://www.jameco.com/webapp/wcs/sto...oductId=100765
Crimper - 159265
http://www.jameco.com/webapp/wcs/sto...oductId=159265
You have a choice of different size housings:
http://www.jameco.com/webapp/wcs/stores/servlet/CatalogSearchResultView?langId=-1&storeId=10001&catalogId=10001&searchType=k&searc hValue=100765&categoryId=304026
You can use Molex connectors available at DigiKey and elsewhere, but the male pins are a little too long and must be cut short for the housing to fit snugly to IFI females in the Victors and Spikes.
3-pin Housings - WM2801-ND
Male Pins WM2515-ND
Female Pins WM2554-ND
P.S. Rickertsen2 Sorry, I didn't mean to imply you couldn't get other .1 connectors through DigiKey. I only meant to share my experience with the Molex ones. We have and do use other manufacturers connectors as well. I just don't have those part numbers within easy reach.
Unread 16-12-2005, 16:43
Unsung FIRST Hero
Mike Betts Mike Betts is offline
Electrical Engineer
Rookie Year: 1995
Mike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond repute
Re: PWM connectors
Greg,
I purchased the parts you are thinking of at a local electronics store in Berlin CT. They buy the pins and housings in bulk and slap their own part number on the bags of 50 that I buy.
The original manufacturer and P/N is not marked on the packages...
As such, the info we have would not be of value to teams outside of the Hartford area.
Mike
Mike Betts
Alumnus, Team 3518, Panthrobots, 2011
Alumnus, Team 177, Bobcat Robotics, 1995 - 2010
LRI, Connecticut Regional, 2007-2010
LRI, WPI Regional, 2009 - 2010
RI, South Florida Regional, 2012 - 2013
As easy as 355/113...
Unread 17-12-2005, 00:35
BrianBSL BrianBSL is offline
FRC #0190
Rookie Year: 2000
BrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud of
Re: PWM connectors
Actually, I wouldn't say thats a bad implication. The only other ones that I have found from digikey are the AMP ones, and the housings are too large to fit next to each other. Go with the molex ones from Digikey if you are buying other stuff from them or the Jameco ones. We've used both (mostly the molex ones) and they work fine.
You can also get "servo style" connectors off ebay, but the Jameco ones are likely the best bang for your buck.
Unread 18-12-2005, 18:05
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
Re: PWM connectors
Gary,
I know we buy ours from Digikey. I have looked through my computer here at home and can't find the number but I will get it to you tomorrow.
Al
WB9UVJ
www.wildstang.org
________________________
Unread 21-12-2005, 02:03
eugenebrooks eugenebrooks is offline
AKA: Dr. Brooks
no team (WRRF)
eugenebrooks has a reputation beyond reputeeugenebrooks has a reputation beyond reputeeugenebrooks has a reputation beyond reputeeugenebrooks has a reputation beyond reputeeugenebrooks has a reputation beyond reputeeugenebrooks has a reputation beyond reputeeugenebrooks has a reputation beyond reputeeugenebrooks has a reputation beyond reputeeugenebrooks has a reputation beyond reputeeugenebrooks has a reputation beyond reputeeugenebrooks has a reputation beyond repute
Re: PWM connectors
We use the Molex C-Grid connectors, housings, and the associated
crimper. We make our own connectors only for the female
connections to analog and digital sensor inputs on the RC where
we use custom (longer) cables, and cables with larger conductor
counts.
The three pin female housing is Digikey WM2801-ND.
The female connector that goes into this housing is Digikey WM2554-ND.
In addition to the three pin housing, the longer rail housings
that offer a varying number of connections can be useful, for instance
connecting an array of switches to digital inputs with a single
multi-conductor cable. An 8 pin single in line housing, for instance,
is WM2806-ND. We don't use the male pins, but these are part number
WM2515-ND.
Don't forget the proper crimper. We use Digiikey WM9997-ND,
this being the proper Molex crimper for these connectors. There is
a cheaper multi-purpose crimper, WM9999-ND, and we use this
crimper on other kinds of connectors, such as those for the backup
battery, but it is not well suited for the C-Grid connectors.
Unread 21-12-2005, 07:28
Unsung FIRST Hero
Rookie Year: 1996
Re: PWM connectors
Thanks Gene, I believe those are the ones we use as well.
Al
WB9UVJ
www.wildstang.org
Unread 21-12-2005, 11:52
billbo911's Avatar
billbo911 billbo911 is offline
I prefer you give a perfect effort.
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
billbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond repute
Re: PWM connectors
We don't use the male pins, but these are part number WM2515-ND.
Just to help round things out here, the male pins will be needed if you are working with VEX and need to make up your own cables to attach sensors such as potentiometers or custom micro switches to the analog/digital inputs.
CalGames 2009 Autonomous Champion Award winner
Sacramento 2010 Creativity in Design winner, Sacramento 2010 Quarter finalist
2011 Sacramento Finalist, 2011 Madtown Engineering Inspiration Award.
2012 Sacramento Semi-Finals, 2012 Sacramento Innovation in Control Award, 2012 SVR Judges Award.
2012 CalGames Autonomous Challenge Award winner ($$$).
2014 2X Rockwell Automation: Innovation in Control Award (CVR and SAC). Curie Division Gracious Professionalism Award.
2014 Capital City Classic Winner AND Runner Up. Madtown Throwdown: Runner up.
2015 Innovation in Control Award, Sacramento.
2016 Chezy Champs Finalist, 2016 MTTD Finalist
Unread 21-12-2005, 17:23
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
Rookie Year: 1996
Re: PWM connectors
I have had good success using the "generic" Molex crimper rather than the specialized one for the C-grid terminals (though I often back up the crimp with a solder job if the wire is a 24 gauge).
I use Mouser as often as Digikey.
The do-all crimper from Molex is Mouser part number 538-63811-1000
The housings are part number 538-50-57-9003
There are many terminal styles -- there are 2 gold platings and 1 tin plating, there are 2 sizes for gauge of wire and in females there are "box" and "high force" version -- all these varieteis lead to 6 male types and 10 female types.
For me and mine, I use:
  • tin plated
  • 22-24 guage wire size
  • high force female
For my choices I get the following:
The male terminals are part number 538-16-02-0114
The females terminals are part number 538-16-02-1114
Feel free to pick your own. Here is a link to the right page from the Mouser Catalog.
Joe J.
Joseph M. Johnson, Ph.D., P.E.
Mentor
Team #88, TJ2
Unread 22-12-2005, 09:35
Rookie Year: 1998
Re: PWM connectors
I'm drooling with all the good information everyone has posted here. You've saved me from pulling out what hair I have left trying to wade through my catalogs. Thanks - this will make my conversion from ME mentor to EE mentor much easier.
Unread 22-12-2005, 10:09
Just Itinerant
Re: PWM connectors
This will make my conversion from ME mentor to EE mentor much easier.
I suggest leaving the hammer and drill behind
Unread 22-12-2005, 10:17
EricS-Team180's Avatar
EricS-Team180 EricS-Team180 is offline
SPAM, the lunchmeat of superheroes!
AKA: Eric Schreffler
FRC #0180 (SPAM)
EricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond repute
Re: PWM connectors
...we're going to have to be SO careful with him, around the batteries this year
Don't PANIC!
S. P. A. M.
Unread 30-12-2005, 20:30
Billfred's Avatar
Billfred Billfred is offline
Re: PWM connectors
I know this kinda diverges from the thread a bit, but what does everyone use for wire? (I looked at Jameco's site, and couldn't find anything that resembled the stuff we use.)
  #15   Spotlight this post!
Unread 30-12-2005, 21:45
FRC #0190
Rookie Year: 2000
Re: PWM connectors
We use this: http://www.jameco.com/webapp/wcs/sto...oductId=232995
for switches and other digital inputs requiring only 2 conductors.
And this:
http://www.jameco.com/webapp/wcs/sto...oductId=233023
for Pots and other stuff requiring 3 conductors.
You can get similar ribbon wire to the IFI stuff on ebay and at hobby shops, they often call it "servo wire", but its cost is far more than the belden stuff from Jameco. We haven't had any noise issues that would have justified going with a ribbon-style wire instead of the multiconductor cable.
PWM connectors dawonn Control System 11 30-01-2005 23:37
FYI about using PWM 13-16 with interrupts cabbagekid2 Programming 6 22-01-2005 00:54
PWM Style .100 pitch Male Connectors BrianBSL Electrical 2 05-10-2004 19:43
Using an Operator Interface with the 2004 EDU RC wirelessly Dave Flowerday Robotics Education and Curriculum 34 19-04-2004 19:06
pwm 13-15 wayne 05 Programming 2 04-10-2003 12:08
