Go to Post The strive for the Chairman's award is by far more important than the award. - Pavan Dave [more]
Unread 16-12-2005, 16:40
M. Enns M. Enns is offline
FRC #1310
M. Enns is an unknown quantity at this point
Plasma Cutter
We just got a new plasma cutter (Lincoln Electric Pro-Cut 25) and I was wondering about gas supply. Can we just hook it up to our compressor? Is there any advantage to using bottled nitrogen? Do we need some sort of filter or dryer for the compressed air?
Thanks,
-ME
Unread 16-12-2005, 17:33
Greg Needel's Avatar Unsung FIRST Hero
Greg Needel Greg Needel is offline
REVving up for a new season
FRC #2848 (All-sparks)
Greg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond repute
Re: Plasma Cutter
Thanks,
-ME
oh you are gonna have some fun with this. Compressed air should work fine as long as your compressor can deliver the flow required by your machine. The small miller i used required 4.5 cfm at 60psi. As for nitrogen, i wouldn't recommend it. Most people run nitrogen because they don't have a source of compressed air or think that it is cheaper then buying a compressor, but by the time you get the bottle and all the fittings you are only a few bottle fills away from the cost of the compressor. As for a filter dryer,i would check the documentation of the one you got but the last one that i used did not have a dryer and seemed to work just fine. If you live in a very humid environment i would get one anyway as long as it doesn't interfere with your required flow.
Greg Needel│www.robogreg.com
Co-founder REV Robotics LLC www.REVrobotics.com
2014 FRC World Champions with 254, 469, & 74
Unread 17-12-2005, 03:55
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Team Role: Teacher
Re: Plasma Cutter
On the little Miller one I use we just hook it up to the shop's compressed air system (big tank and good sized compressor). No special gas needed.
Unread 17-12-2005, 11:14
Jay H 237 Jay H 237 is offline
Down at the railroad
AKA: Jason Hartmann
FRC #0237 (Black Magic)
Rookie Year: 1999
Jay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond repute
Send a message via AIM to Jay H 237
Re: Plasma Cutter
Having a filter at the end of your air line isn't a bad idea if you're air plumbing is done with black or galvanized pipe. Over time the moisture in the air will rust the inside of black pipe and rust particles will break free being passed along to whatever tools are hooked to the air line. With galvanized pipe the galvanized particles could flake off being passed to your tools also. The filter(s) will have to be located at or near the end of the air line(s) to be effective. This isn't a big problem but just something you might want to take into consideration.
With copper, aluminum, and rubber air lines you don't have this problem. If you've got PVC air lines then whoever installed those was just plain ignorant or stupid. I'd be more worried about getting maimed or killed then whether or not I should have a filter on my PVC lines.
PVC makes great FIRST game pieces, not air lines!
2006 Maryland Delphi "Driving Tomorrow's Technology" award
2006 Connecticut General Motor's Industrial Design award
2005 Finalists-----------New Jersey (along with our alliances again, 56 & 303)
2005 WINNERS of the Radio Shack Innovation in Control Award (not once, but twice! )
2004 WINNERS ------ Johnson & Johnson Mid-Atlantic Regional (also thanks to our alliances 56 & 303)
2004 General Motors Industrial Design Award Winners
2004 Archimedes Quarterfinalists (also thanks to our alliances 121 & 386)
NEMO _________ NonEngineering Mentor Organization
"Make it idiot proof and someone will make a better idiot!" - author unknown
Unread 17-12-2005, 12:29
Andrew Blair's Avatar
Andrew Blair Andrew Blair is offline
SAE Formula is FIRST with Gasoline.
FRC #0306 (CRT)
Andrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond repute
Send a message via AIM to Andrew Blair Send a message via Yahoo to Andrew Blair
Re: Plasma Cutter
We just use the schools compressed air for ours. This drawing a bit off topic, but perhaps a gas would improve this. How can you make precise cuts in Al with a plasma cutter? We have no problem with steel, but with 1/8" Al, it just leaves an 1/8" cut, and terribly ragged edges.
Reading makes a full man, conference a ready man, and writing an exact man.
-Sir Francis Bacon
"Any intelligent fool can make things bigger, more complex, and more violent. It takes a touch of genius -- and a lot of courage -- to move in the opposite direction."
-Albert Einstein
Unread 17-12-2005, 20:53
Mike AA's Avatar
Mike AA Mike AA is offline
Programmer and Mentor
AKA: Mike Aalderink
FRC #3458 (Code Blue)
Rookie Year: 1999
Mike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to behold
Send a message via MSN to Mike AA
Re: Plasma Cutter
Although unlikely I suppose that PVC pipe could burst under the pressure, more likly the connectors. Most PVC pipe is rated in the 300-600psi range, well below aircompressor range.
-Mike
Unread 17-12-2005, 21:12
Gdeaver Gdeaver is offline
FRC #1640
Gdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond repute
Re: Plasma Cutter
There are plastic air piping systems. However, normal ABS, PVC, or CPVC water pipe and fittings ARE NOT rated for air.
Unread 17-12-2005, 21:49
Ian Curtis Ian Curtis is offline
Best Available Data
FRC #1778 (Chill Out!)
Ian Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond repute
Re: Plasma Cutter
We also use compressed air, and ours is filtered to prevent moisture.
How many amps and at what speed are you running the cutter? We get great cuts on aluminum, so I'll look up the numbers on Tuesday at our meeting and post them.
CHILL OUT! | Aero Stability & Control Engineer
Adam Savage's Obsessions (TED Talk) (Part 2)
It is much easier to call someone else a genius than admit to yourself that you are lazy. - Dave Gingery
pic: Sheet steel resting on CNC plasma cutter Jay H 237 Extra Discussion 3 11-01-2005 05:46
Maximum Depth of Cuts indieFan Technical Discussion 9 09-05-2004 18:18
Image Discuss: Plasma Combustion Motor Teaser CD47-Bot Extra Discussion 5 14-02-2003 15:46
