Go to Post Moral of the story: Keep something you can power on gamepieces at all times. Leaving them "to do their own thing" will only lead to heartbreak. - Ian Curtis [more]
Unread 22-12-2005, 17:35
Jack Jones Jack Jones is offline
Retired
Jack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond repute
Re: Dump Backup Battery
Many are missing the point that the keyword here is backup. Any electronics added to replace the NiCad and yet store enough juice to power the RC (ETC.) during brownouts is sure to be less efficient than the NiCad.
That is, you can't get something for nothing! Instead of having a pre-charged NiCad, you use power from the main battery, which is a net loss of power available at the start of the match. You'd also gain weight!
Unread 22-12-2005, 17:37
billbo911's Avatar
billbo911 billbo911 is online now
I prefer you give a perfect effort.
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
billbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond repute
Originally Posted by BrianBSL
Huh? What is preventing you from doing it with an IC based buck/boost converter? Small surface mount IC plus an inductor and a few resistors is all I could see that would be necessary.
Originally Posted by Billbo911
The only way to do this and still get 7.2v out of it even when the main battery drops below 7.2v would require a circuit with weight and size that exceeds that of the backup battery it's self.
Again, the only advantage I could imagine would be gained by elliminating it would be a reduction of size and/or weight. I don't think it is possible to achieve both requirements based on what you are describing. (I don't mind being prooved wrong, it wouldn't be the first time.) The trick would be to have it supply enought power to keep alive all the devices that may be drawing from it when the input voltage drops to say 5vdc.
Not that I would say its worth doing it, stick with the backup battery. If you are really worried about size/weight, there are plenty of suppliers of smaller premade 7.2V battery packs.
Now your talking. Just make certain it has the capacity to power all the devices that run off the battery.
CalGames 2009 Autonomous Champion Award winner
Sacramento 2010 Creativity in Design winner, Sacramento 2010 Quarter finalist
2011 Sacramento Finalist, 2011 Madtown Engineering Inspiration Award.
2012 Sacramento Semi-Finals, 2012 Sacramento Innovation in Control Award, 2012 SVR Judges Award.
2012 CalGames Autonomous Challenge Award winner ($$$).
2014 2X Rockwell Automation: Innovation in Control Award (CVR and SAC). Curie Division Gracious Professionalism Award.
2014 Capital City Classic Winner AND Runner Up. Madtown Throwdown: Runner up.
2015 Innovation in Control Award, Sacramento.
2016 Chezy Champs Finalist, 2016 MTTD Finalist
Unread 23-12-2005, 10:49
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
We can't really answer this for a particulr robot but let us remember that there are robots (many robots) that have inefficient designs that do run the main battery down to nothing in a single match. I have had teams that were actually proud of the fact that they killed a battery every match. With that being said, a power convertor fed from the main battery is still going to fail when a current demand on the main battery causes it to go to a couple of volts during a shoving match. Even with boost buck convertors, a 10 volt swing on input will not reliably keep the backup power up at 7.2 volts. In this case, two voltage sources are the best solution.
Al
WB9UVJ
www.wildstang.org
________________________
Backup battery will not power RC steven114 Control System 13 24-01-2005 01:59
Urgent!!! Problem concerning Backup battery and autonomous. Code\\Pilot Programming 3 26-02-2004 16:44
Cutting wire on backup battery MikeDubreuil Electrical 4 23-02-2004 18:55
buy extra backup battery MaxM Electrical 2 20-02-2004 18:11
Weight of Backup Battery? sanddrag Control System 0 16-02-2004 20:58
