Go to Post We can not close our eyes, ears and minds from March to December. - Dave Campbell [more]
Unread 22-12-2005, 12:28
Gary Dillard's Avatar Unsung FIRST Hero
Gary Dillard Gary Dillard is offline
Generator of Entropy
AKA: you know, the old bald guy
FRC #2973 (The Mad Rockers)
Rookie Year: 1998
Gary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond repute
Send a message via AIM to Gary Dillard
jumper cabling from sensors to controller
This is a follow-on to my thread about 3-pin pwm connectors; I looked through the threads on wiring recommendations and didn't see anything that specifically addressed this....
I am tasked this year with improving the integration of our controls system from a physical hardware standpoint. One of the things that seems to hold us up is cable routing, especially to the sensors. Last year we did a great job cleaning up the power cable routing (love the new relay board), but running small wiring to all the sensors is always the last thing we do. It seems like it can't really be done until the robot is mostly assembled and we always do it in place.
One of the ideas I have is to take all of our sensors (limit switches, shaft encoders, pots, etc.) and terminate them to 3 pin female connectors using just a few inches of wire length, which we could do starting week 1 and mount them with the component. Then we would make a cable for each of the sensors, male to female, extra long (or just use pwm extension cables) so we can test out all the sensors. The final task would be to cut them to length, put a new connector on the cut end and secure them along the routing.
Am I headed in the right direction? Is there any problem having an extra connector(s) in every line? Is there any benefit to adding short cables from each input on the controller side to some location with another connector so I can hard mount /strain relieve that termination point as well?
Or any other suggestions?
Close enough to taste it, too far to reach it
Why not analog sensors?? gnormhurst Programming 16 07-03-2004 16:14
Help On Coding 2K1 Controller GregTheGreat Programming 9 05-12-2003 18:35
serious problem found - robot controller resets when jarred! KenWittlief Electrical 23 19-03-2003 13:30
hooking up sensors to controller? Oakridege_665 Technical Discussion 5 21-01-2002 14:55
broken jumper on controller Mike Soukup Technical Discussion 5 22-10-2001 20:49
