Go to Post Moral of the story: Keep something you can power on gamepieces at all times. Leaving them "to do their own thing" will only lead to heartbreak. - Ian Curtis [more]
Unread 25-12-2005, 15:32
Theory6RobotiX's Avatar
Theory6RobotiX Theory6RobotiX is offline
Pi is exactly 3!!! Joking...
FRC #1241 (Theory6)
Team Role: Mechanical
Theory6RobotiX is on a distinguished road
What are Potentiometers?
Hi,
I was doing a little research on 'pots' on CD and i came across posts that suggested using different potentiometers in different scenarios. I am a little confused over how potentiometers work and what the difference is between the different ones?
Thanks
Unread 25-12-2005, 16:10
evolution's Avatar
evolution evolution is offline
FRC #0418 (LASA Robotics)
Team Role: Student
evolution will become famous soon enough
Re: What are Potentiometers?
This should answer your questions:
http://en.wikipedia.org/wiki/Potentiometer
Unread 25-12-2005, 16:27
KenWittlief KenWittlief is offline
KenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond repute
wow, that wiki page has a lot of errors! (weird for something as simple as a pot)
this page is a little more straight forward (without the archaic references to galvenometers and stuff): http://www.sound.westhost.com/pots.htm
Unread 25-12-2005, 20:06
TimCraig TimCraig is offline
AKA: Tim Craig
TimCraig is a splendid one to beholdTimCraig is a splendid one to beholdTimCraig is a splendid one to beholdTimCraig is a splendid one to beholdTimCraig is a splendid one to beholdTimCraig is a splendid one to beholdTimCraig is a splendid one to behold
We might be enlightened by what you think are errors. And as far as galvanometers being archaic, historical context is often helpful in understanding how a device has evolved.
Unread 25-12-2005, 20:25
so many things - like "a volume control acts as a filter" - thats not correct
back before voltage and current were defined by agreed to names (voltage was named after Voltaire) a device for measuring voltage was referred to as a potentiometer (potential meter) but that terminology is now obsolete.
A potentiometer is a variable resistor, nothing more. Its not a voltage source, its not a current source, its not a measuring device.
If you dont know what a pot is, the Wiki entry is very misleading and confusing.
Unread 25-12-2005, 22:12
Matt Adams's Avatar
Matt Adams Matt Adams is offline
b(o_o)d
FRC #1525 (Warbots)
Rookie Year: 2000
Matt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond repute
Send a message via AIM to Matt Adams
Post Re: What are Potentiometers?
I think that the two previous links explain technically how a pot works, but I think that often times people ask this sort of question because they want to know specifically how they're used in FIRST robots. I'll try to do this to add more to this discussion.
To summarize the what's been said, a pot is a variable resistor, and it's purpose typically in FIRST is for some sort of feedback, i.e. knowing the location of a device on a FIRST robot.
On a typical pot you have three wires, a +5 volts input into the pot (out from the controller), a ground wire, and an analog wire that carries a signal 0-5 volts back into controller. At one extreme on a pot, the voltage will be 0 volts, and on the other extreme the voltage will be +5 volts, depending on the shaft location. The robot controller takes this analog voltage signal and runs it through a analog to digital converter (ADC), and expresses this voltage as an integer somewhere between 0 and 1024.
A typical use is having a pot connected to a shaft on a robot arm. As the arm moves back and forth, the whipper on the pot will change the resistance, and hence the output voltage.
Going back to FIRST applications, you can use a potentiometer to have a push buttons on your operator interface move your arm to a known position. So instead of having your operator manually control the arm to move to 50 degrees, with a single button you could have the motor that powers the arm rotate until the controller sees the arm is in position, based on the voltage feedback you get from the potentiometer.
As a disclaimer, there's a whole discipline of engineering with regard to "having the motor that powers the arm rotate until it sees the arm is in position." You can look up some posts on PID control loops in these forums for more information.
I hope this answers your question!
ho ho ho!
Matt
Unread 25-12-2005, 23:07
skimoose's Avatar
skimoose skimoose is offline
Parent/Mentor/Engineer
AKA: Arthur Dutra
FRC #0228 (GUS)
Team Role: Electrical
skimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond repute
Matt's right on the mark. The other application in FRC is using pots to build custom operator interfaces. If you haven't opened a joystick before, it has one or two (depending on whether its a one or two axis stick) pots connected to the joystick's gimbal. As the joystick is moved it changes the analog signal. After its converted, the value is used to set the PWM value (0-255) being sent to the programmed Victor speed controller or being used to match the value to the feedback pot on the robot arm. Teams have built small arms on their OI which mimic the location of the arm on their robot. The pots are used at the joints to tell the bot's arm what position to go to.
Just one other bit on pots. FRC usually uses rotary pots, but there are also linear pots (think of sound mixing board slider pots). Rotaries also come in different resistance values (10k, 100k, 500k) and single turn or multi-turn versions. Single turn pots give you full range 0-5 volts in about 270 degrees of motion. This is good for arm feedback where the arm doesn't exceed the 270 degrees of motion. Multi-turn pots require several complete revolutions (usually 10 turns) to complete the full feedback range. These might be better on gearboxes or elevator feedback where the drive system is making several full rotations to complete its range of motion.
2009 CT Regional Motorola Quality Award
2010 VRC Connecticut Championship Winners & Amaze Award
2010 VRC Championship Divisional Energy Award
2010 WPI Regional Winner
2010 WPI Regional Engineering Inspiration Award
2011 WPI Regional Chairman's Award
2012 WPI Regional Finalists
Unread 26-12-2005, 21:41
AKA: Tim Craig
I think you mean the Italian physicist, Alessandro Volta, rather than the French writer and philosopher Francois-Marie Arouet de Voltaire.
http://inventors.about.com/library/i...ndro_Volta.htm
http://www.ideafinder.com/history/inventors/volta.htm
Unread 27-12-2005, 10:31
yep, you are right. Amps and watts are also named after people, and I believe the unit of charge (coulomb) as well.
maybe someday they will name a unit of something after me (like stupidity maybe? :^)
Unread 27-12-2005, 11:20
billbo911's Avatar
billbo911 billbo911 is offline
I prefer you give a perfect effort.
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
billbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond repute
...maybe someday they will name a unit of something after me (like stupidity maybe? :^)
Ken, are you giving us license to begin using expressions like, "Boy, that was a full Wittlief." or maybe, "Just remember class, Stupidity is measured in Wittlief's"?
The question then becomes, "Is it a single Wittlief, broken down by percentage, or is it a small unit that requires multiples to describe the actual level of stupidity?"
I think I'll stop here, the door is already too far open.
Thanks for allowing me to run with this for a short distance, I'll hand the baton off to the next runner now.
CalGames 2009 Autonomous Champion Award winner
Sacramento 2010 Creativity in Design winner, Sacramento 2010 Quarter finalist
2011 Sacramento Finalist, 2011 Madtown Engineering Inspiration Award.
2012 Sacramento Semi-Finals, 2012 Sacramento Innovation in Control Award, 2012 SVR Judges Award.
2012 CalGames Autonomous Challenge Award winner ($$$).
2014 2X Rockwell Automation: Innovation in Control Award (CVR and SAC). Curie Division Gracious Professionalism Award.
2014 Capital City Classic Winner AND Runner Up. Madtown Throwdown: Runner up.
2015 Innovation in Control Award, Sacramento.
2016 Chezy Champs Finalist, 2016 MTTD Finalist
Unread 27-12-2005, 11:34
ChrisH's Avatar Unsung FIRST Hero
ChrisH ChrisH is offline
Generally Useless
FRC #0330 (Beach 'Bots)
Rookie Year: 1998
ChrisH has a reputation beyond reputeChrisH has a reputation beyond reputeChrisH has a reputation beyond reputeChrisH has a reputation beyond reputeChrisH has a reputation beyond reputeChrisH has a reputation beyond reputeChrisH has a reputation beyond reputeChrisH has a reputation beyond reputeChrisH has a reputation beyond reputeChrisH has a reputation beyond reputeChrisH has a reputation beyond repute
When I was in college a group of us created a unit named after a professor who seemed to be somewhat behind the times.
1 Maradudin = 1 carat furlong/(fortnight^2)
The Maradudin is a unit of force, you can use existing quantities and just change the units to create a new unit. The hard part is getting it generally accepted.
Christopher H Husmann, PE
"Who is John Galt?"
Unread 27-12-2005, 14:07
keeping with engineering tradition, the unit would be similar to my name (volts: Volta...)
like maybe "Wittless" ?
Im not sure what the units would be? how do you measure stupidity? number of dollars wasted? or dollars wasted per second?
number of seconds wasted doing something the wrong way? number of seconds it takes to find/debug/correct a mistake?
time would be more of an intenational standard than say dollars per second.
We found a 3.6k Wittless in the code (stupid mistake that took one hour to find and correct)....
Unread 27-12-2005, 14:27
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
I like measuring length in femto parsecs. (1 x 10 **-15). Somehow a wittlief doesn't seem fitting.
Al
WB9UVJ
www.wildstang.org
________________________
Unread 27-12-2005, 15:22
Richard Wallace's Avatar
Richard Wallace Richard Wallace is offline
I live for the details.
FRC #3620 (Average Joes)
Rookie Year: 1996
Sometimes more that one person's name is used as a unit for the same physical quantity. Gauss is a common unit of magnetic flux density; the earth's magnetic field induces a flux density of 0.3 to 0.6 Gauss depending on where you measure it (e.g., higher in northern Canada, lower in central Africa). Another common unit for magnetic flux density is the Tesla, equal to 10,000 Gauss. The strongest rare-earth permanent magnets have a residual induction of about 1.2 Tesla, or 25,000 times the flux density due to earth's magnetic field.
So should we infer anything about Tesla and Gauss based on the relative size of the flux density units that bear their names? Tesla was arguably the most important inventor of the twentieth century (I think it would be hard to top polyphase AC electrical distribution and its associated electric machinery for impact on society) while Gauss was arguably the most important mathematician of the 19th century.
Anyway, if Ken is to have a unit of stupidity named for him, then I suggest we will need a much larger unit named for someone else.
Richard Wallace
since 2003
Attaching Potentiometers to VEX billbo911 FIRST Tech Challenge 9 07-07-2005 19:03
1 Megohm Potentiometers phrontist Electrical 9 22-02-2005 02:05
Flaky Potentiometers theDoctor Electrical 4 21-02-2005 21:08
Where to buy good potentiometers? Kirk Electrical 3 12-02-2005 22:23
Q about potentiometers Nick R. Electrical 13 07-02-2004 09:13
