Go to Post And Dave...should I borrow someone's hair dryer from here in case the NASA truck needs some de-icing again this year? - Billfred [more]
  #16   Spotlight this post!
Unread 01-01-2006, 15:37
Cody Carey's Avatar
Cody Carey Cody Carey is offline
AKA: C. Carey
FRC #0306 (CRT)
Cody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond repute
Send a message via AIM to Cody Carey Send a message via Yahoo to Cody Carey
Re: Do robots have feelings?
I'll consider a robot to be living when it won't let me turn it off.
  #17   Spotlight this post!
Unread 01-01-2006, 16:07
KenWittlief KenWittlief is offline
KenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond repute
you mean like most PCs running windows 95? :^)
  #18   Spotlight this post!
Unread 01-01-2006, 17:58
Ashley Christine's Avatar
Ashley Christine Ashley Christine is offline
FRC #1511
Ashley Christine has a reputation beyond reputeAshley Christine has a reputation beyond reputeAshley Christine has a reputation beyond reputeAshley Christine has a reputation beyond reputeAshley Christine has a reputation beyond reputeAshley Christine has a reputation beyond reputeAshley Christine has a reputation beyond reputeAshley Christine has a reputation beyond reputeAshley Christine has a reputation beyond reputeAshley Christine has a reputation beyond reputeAshley Christine has a reputation beyond repute
Once a robot can reproduce then it will be living. LOL.
  #19   Spotlight this post!
Unread 01-01-2006, 18:47
Mike's Avatar
Mike Mike is offline
has common ground with Matt Krass
AKA: Mike Sorrenti
FRC #0237 (Sie-H2O-Bots (See-Hoe-Bots) [T.R.I.B.E.])
Mike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond repute
Originally Posted by KenWittlief
1. generate their own fuel or find it
You stated the Roomba, no need for me to reiterate.
2. self repair
Hmm. I can't really think of a popular/in production robot that does this now, but I can't picture this being anything beyond a somewhat complex self-debugging system. What are the logical things you do when your finger is hurting you? Rest it. Splint it maybe. Ice it. Etc. The robot would be programmed to recognize a set of symptoms and treatments.
3. self replicate (with error detection and correction).
http://science.slashdot.org/hardware...tid=216&tid=14
The Guardian unlimited is reporting that Korean roboticist Kim Jong-Hwan, who founded the robot football (soccer) World Cup, and is the director of the ITRC-Intelligent Robot Research Centre, has developed a series of artificial chromosomes that, he says, will allow robots to feel lusty, and could eventually lead to them reproducing.
http://hardware.slashdot.org/article.../05/11/2242239
Scientists at Cornell University have created small robots that can build copies of themselves.
As far as "with error detection and correction", I'm not totally sure what you mean by that. What if this robot is programmed with a PID loop of sorts, and when it reproduces the PID is tweaked because it notices that it needs to move slower/etc.
Well, instead of that big red switch on the robot, just directly connect the wires. Yes, you could just cut the wires, which are the lifeline of the robot, but you could also cut a living beings lifeline (blood vessels, windpipe, etc.)
As far as sparksandtabs post on adaptation... that is a tough one. Now, if I understand evolution correctly, animals naturally do not adapt to their environment. Instead, an animal is born with a genetic mutation that allows it to survive in a new area. This animal out-lives and out-reproduces all the other "normal" gened animals, eventually becoming the predominant gene type. So now this ties in with the topic of robotic reproduction. Going back to the PID example, would a robot with the better PID tuning not out-live the other robots, with an inferior tuning? This robot will recognize that it does not need to change that aspect of itself, and pass that aspect down to it's children. The children will then find an unsatisfactory aspect of it's programming, fix it and pass it down to their children, so on and so forth.
This post may be confusing and unorganized, but it's hard to organize thoughts like this
http://www.mikesorrenti.com/
  #20   Spotlight this post!
Unread 02-01-2006, 01:06
Our DNA contains duplicate (redundant) information, which allows reproduction to take place with error detection and correction.
An engineering equivalent is flight control systems, which have 3 or 4 copies of each unit, that constantly cross check each other. If one is found to be operating differently than the rest then it is locked out by the others. Thats error detection.
Error correction (fixing the failed component in real time) would be a little more complex. Our bodies fix themselves without our conscious involvement or awareness. Our blood clots to stop leaks, then our skin, muscle and bones repair themselves from the basic elements present in our blood (from the food we have eaten).
A robotic equivalent would be a fluid that contains iron, aluminum, copper, semiconductors... and nanotechnology that is able to detect when part of the robot has failed or been damaged, and pulls the needed molecules from that fluid, and rebuilds the damaged component molecule by molecule.
Thats the kind of self repair you would need to approach robotic life.
  #21   Spotlight this post!
Unread 02-01-2006, 01:21
greencactus3 greencactus3 is offline
occra 23.
AKA: ryo
None #1481
greencactus3 is a name known to allgreencactus3 is a name known to allgreencactus3 is a name known to allgreencactus3 is a name known to allgreencactus3 is a name known to allgreencactus3 is a name known to all
Send a message via AIM to greencactus3 Send a message via MSN to greencactus3
well theres those new plastics with "self repair". sumthing about catalysts in them. i forgot
  #22   Spotlight this post!
Unread 02-01-2006, 01:31
sciencenerd's Avatar
sciencenerd sciencenerd is offline
ooh, what does this button do?
AKA: Kyle
FRC #1318 (the IRS (Issaquah Robotics Society))
Team Role: Coach
sciencenerd has much to be proud ofsciencenerd has much to be proud ofsciencenerd has much to be proud ofsciencenerd has much to be proud ofsciencenerd has much to be proud ofsciencenerd has much to be proud ofsciencenerd has much to be proud ofsciencenerd has much to be proud of
[a little off topic] A very cool program that replicates selection in a population is gene pool. I let it run a few days once, and the swimbots that came out were amazingly well developed.
Oh, maybe I shouldn't have pushed that...
  #23   Spotlight this post!
Unread 02-01-2006, 19:04
lukevanoort lukevanoort is offline
in between teams
AKA: Luke Van Oort
lukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond repute
Send a message via AIM to lukevanoort
A lot of our DNA also contains garbage from previous ancestors that wasn't "overwritten", just ignored. A programming equivalent would be commenting out a bunch of code, and when you decide not to use it, just leave it there and write more code.
Team 1219: 2009 - Mentor
Team 587: 2005 - Animator, 2006-2008 - Team Captain
  #24   Spotlight this post!
Unread 02-01-2006, 19:48
Saru29's Avatar
Saru29 Saru29 is offline
3ds addict
FRC #0025 (Raider Robotix)
Team Role: Scout
Saru29 is a jewel in the roughSaru29 is a jewel in the roughSaru29 is a jewel in the rough
Send a message via AIM to Saru29
When a robot army comes marching in to force us into body pods put us ina virtual world and lets call this the matrix for some random reason and in the matrix some dude can dodge bullets comes and talks to the machines while being blind...Then i will believe robots are alive.
Proud to be a BMS team.
2008 NJ Regional Champions. 103 - 25 - 381
2008 Hawaiian Regional Semi Finalists. 968 - 25 - 2459
2008 Galileo Division Quarter Finalists. 494 - 25 - 88
Thanks to all the teams we were partnered with this season! You guys were great.
Less Interest in Robots in the pits this year? sanddrag General Forum 36 11-06-2005 14:47
Students design robots, beneficial technology Billfred FIRST In the News... 0 07-02-2005 01:32
Robots doing origami! RoboMom Math and Science 4 24-10-2004 19:42
FYI: FIRST Robots at the NYC Hall of Science Rich Wong General Forum 9 11-07-2002 10:52
