Go to Post Yeah, yeah...those who aren't spotlit, spotlight.... - Jessica Boucher [more]
Unread 27-12-2005, 13:36
complete's Avatar
complete complete is offline
complete is an unknown quantity at this point
reading negative numbers from a file in VB
So far the code I have written can read and write to and from a file.
In other words, I have the
Code:
    Line Input  #FileNum...
and the
Code:
     Write #FileNum...
written.
But how do I handel a situation where the file has negative numbers to be read? I am able to output to a file a negative integer. But when I try to read it back I get an error.
I assume I will have to read each line of the file one by one into a string and then have it converted. What are the string conversion routines in VB? The line of code is written as
-1
I suppose I have to do some string manipulation to get it stored back as a negative integer.
Negative numbers? Calvin Programming 6 09-02-2005 10:46
Error in header file p18f8520.h !!! RbtGal1351 Programming 3 17-01-2005 16:03
heres the code. y this not working omega Programming 16 31-03-2004 15:18
File Sharing and Revision Tracking Madison FIRST-related Organizations 14 04-06-2003 18:01
