Go to Post Is it really that bad to ask a team to be able to do more than just drive? It's like asking a student to do more than just show up to class... - Katie_UPS [more]
Go Back   Chief Delphi > Other > FIRST Lego League
Unread 27-12-2005, 15:58
remy remy is offline
remy is an unknown quantity at this point
promblem with RCX firmware and BricxCommandCenter (NQC)
Hello guys
I have a problem with the RCX firmware and Bricxcommand center (The nqc language)
I have used 'firm328.lgo', i have loaded it into the rcx, en have written a program, first, the program does not what it have to do, and second, i can't use the 'run' button on the RCX.
Oja, the 'man' on the rcx, go not walk, when I start the rcx program by the BricxCommandcenter.
How can I solve this problem? I have try every version of bricxCommandCenter and with erery version I have the same problem.
Help me
Unread 27-12-2005, 16:05
Greg Perkins's Avatar
Greg Perkins Greg Perkins is offline
7 years, allready!!???!?!?!
AKA: Mongo
Rookie Year: 2000
Greg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond repute
Send a message via AIM to Greg Perkins Send a message via MSN to Greg Perkins Send a message via Yahoo to Greg Perkins
Re: promblem with RCX firmware and BricxCommandCenter (NQC)
These forums are primarily used for the FIRST robotics comepetition. Even though our forum has the name Delphi in it, we are in no way related to Delphi programming. Don't expect a response to your question immediatly, there may be a few select individuals on here that may know what your talking about, but the majority of us do not (including me). I do offer you to explore FIRST robotics more, and to enjoy your time on Chiefdelphi.com.
Thanks!
myResume -2004: PARC Referee; Beantown Staff; Battlecry Referee; Summer Frenzy Head Referee; River Rage Head Referee, 2005: Pittsburgh Regional Referee; PARC Referee
XBOX Live Gamertag = TrixAre4Kidss
Unread 27-12-2005, 17:56
Elgin Clock's Avatar
Elgin Clock Elgin Clock is offline
updates this status less than FB!
AKA: the one who "will break into your thoughts..."
FRC #0237 (Black Magic)
Elgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond repute
Send a message via AIM to Elgin Clock
Hey Greg, it's not Delphi programming.
About Bricx Command Center
Bricx Command Center (BricxCC) is a highly popular Windows-based IDE for programming the LEGO RCX (all versions), Scout, Cybermaster, and Spybot programmable bricks using NQC as well as MindScript, LASM, C++, C, Pascal, Java, and Forth.
Any FLL programmers wanna handle this question?
The influence of many leads to the individuality of one. - E.C.C. (That's me!!)
Unread 27-12-2005, 18:06
EricH's Avatar
EricH EricH is offline
New year, new team
FRC #1197 (Torbots)
I don't have experience with Bricx, but the first thing you should do is check your batteries. If you just replaced them, reload the firmware. If you have a problem with the "run" button, you can check the power (on or off) and if that doesn't work, try a remote (if you have one). If that doesn't work, I can't help anymore.
Could someone with Bricx experience help me out here?
Past teams:
2003-2007: FRC0330 BeachBots
2008: FRC1135 Shmoebotics
Unread 27-12-2005, 18:43
Astronouth7303's Avatar
Astronouth7303 Astronouth7303 is offline
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
Astronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud of
Download a program (preferably the default ones).
Use RIS (if you have it) to load firmware and/or default programs.
Make sure you've selected the right program.
Ask on Lugnet.
Unread 27-12-2005, 20:12
AKA: Mongo
Rookie Year: 2000
wow...i feel dumb, my appologies!
Unread 18-01-2006, 08:24
TJ09's Avatar
TJ09 TJ09 is offline
<?php echo wittyphrase(); ?>
AKA: T.J. Lipscomb
FRC #0230 (Gaelhawks)
Team Role: Webmaster
TJ09 will become famous soon enough
Send a message via AIM to TJ09
Originally Posted by remy
Hello guys
Help me
I've used BricxCC 3.3, but I've never downloaded firmware with it. I used the firmware that came with Robolab (2.5.4, I believe), and all of my NQC programs thus far do what they're told.
EDIT: Ohdamn, I just looked at the date on this.
N.E.R.D. #26
2007 | 230 Operator | NJ Volunteer | FL Safety Award Winners
2006 | UTC Quarterfinalist (195 and 236) | Las Vegas Semifinalist (79 and 1425) | Las Vegas GM Industrial Design Award Winners | Boston Visited
Unread 25-01-2006, 07:39
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
Hello guys
Help me
Remy,
There are different versions of the Brick/RCX. You may have software that requires one of the later versions of the hardware. Check the requirements for your software.
Al
WB9UVJ
www.wildstang.org
________________________
RCX Programming Guyute FIRST Lego League 10 23-08-2004 16:25
