Go to Post This is high school robotics for fun and education. Let's try and keep it that way. - Rod [more]
Unread 07-05-2002, 17:04
Ragin_Kage's Avatar
Ragin_Kage Ragin_Kage is offline
fhqwhgads
AKA: Kyle
#0869 (Power Cord)
Ragin_Kage is on a distinguished road
Send a message via AIM to Ragin_Kage
There were alot of great robots that i saw, just from experience with them, i got to say, 16. you gotta love em
"I've got a fever, and the only prescription is more cowbell!"
www.powercord869.com
Unread 07-05-2002, 18:38
Andy A. Andy A. is offline
Getting old
FRC #0095
Team Role: Coach
Andy A. has a reputation beyond reputeAndy A. has a reputation beyond reputeAndy A. has a reputation beyond reputeAndy A. has a reputation beyond reputeAndy A. has a reputation beyond reputeAndy A. has a reputation beyond reputeAndy A. has a reputation beyond reputeAndy A. has a reputation beyond reputeAndy A. has a reputation beyond reputeAndy A. has a reputation beyond reputeAndy A. has a reputation beyond repute
If you really wanna know about 95...
The entire front end of the 'bot is devoted to the ball. The back end is filled with 'guts'.
There are a total of 10 (or close to it) rollers that run the width of the bot. There is one set of 4 furthest to the front, and a second set of 6 behind them, the width of a soccer ball between the two sets. Each roller has it's own coating of rubberized fabric that gives a good grip on the balls and cusions the rollers from the impact of balls hitting them. The balls move from roller to roller at very high speed, with out the hooper on top they will fly 7 or 8 feet in the air. The extra cusioning avoids dents in the rollers.
Each set is powered by a fisherprice motor with a custom gear box (I don't know the exact ratio). They are belt driven (half inch timing belt i belive, don't quote me on that though). They spin at several hundred RPM at least. When the rollers run inwards balls are pulled in and up into the hopper. The rollers and hopper are seperated by a 'check valve'. The valve is made of poly carb 'fingers' and acts like a lobster trap. Balls have enough energy from the rollers to pass through with out jamming, but thier weight isn't enough to drop them back down into the rollers.
The roller motors are under variable speed, since as more balls are picked up the rollers must spin faster to displace the ones already collected. This is done with a pot on the operators switch box. Needless to say, correctly adjusting the roller speed is a fine art.
On paper, we should be able to get 40 balls in a goal with in the first minute of the match. More often it's been a matter of waiting for our ally to get a hold of a goal before we dump our balls.
So thats pretty much how you get 20 balls off the ground in 5 seconds...
-Andy A.
Unread 07-05-2002, 19:15
Scorpion515's Avatar
Scorpion515 Scorpion515 is offline
#0040 (Trinity Pioneers)
Scorpion515 is an unknown quantity at this point
Send a message via AIM to Scorpion515
I'd say team 95 had the coolest ball collector!!!
Our ball collector as pretty effective, we had a vertical conveyor belt and a corkscrew design that fed into a ball shooter. It was pretty cool the times it worked perfectly.
Jill
Trinity FIRST (40)
Semi-Finalist @ RiverRage6
2004 Game BBFIRSTCHICK General Forum 112 19-04-2003 17:12
Ramp Riot 2002, November 2, Updated Information OZ_341 Off-Season Events 0 05-09-2002 02:40
Curie Division Robots information... (not complete) archiver 2001 3 24-06-2002 03:13
30" ball sits up there real pretty archiver 2001 18 23-06-2002 22:49
Ramp Riot 2002, Third Annual Off-season Competition OZ_341 Off-Season Events 0 20-06-2002 12:21
