Go to Post I bet Andy Baker would totally own JVN in a 1v1 dodgeball fight. - Greg Marra [more]
Unread 30-12-2005, 19:34
[527]phil's Avatar
[527]phil [527]phil is offline
Alumni
AKA: Phil
FRC #0527 (red dragons)
[527]phil is a glorious beacon of light[527]phil is a glorious beacon of light[527]phil is a glorious beacon of light[527]phil is a glorious beacon of light[527]phil is a glorious beacon of light
Send a message via AIM to [527]phil
Dr.SEUSS explains computers
DR. SEUSS EXPLAINS COMPUTERS
If a packet hits a pocket on a socket on a port, and the bus is interrupted as a very last resort, and the address of the memory makes your floppy disc abort, then the socket packet pocket has an error to report.
If your cursor finds a menu item followed by a dash, and the double-clicking icon puts your window in the trash, and your data is corrupted 'cause the index does not flash, then your situation's hopeless and your system's gonna crash!
If the label on the cable on the table at your house, says the network is connected to the button on your mouse, but your packets want to tunnel on another protocol, that's repeatedly rejected by the printer down the hall, and your screen is all distorted by the side effects of gauss, so your icons in the window are as wavy as a souse, then you may as well reboot and go out with a bang, 'cause as sure as I'm a poet, the suckers gonna hang.
When the copy of your floppy's getting sloppy on the disc, and the micro code instructions cause unnecessary risk, then you have to flash your memory, and you'll want to RAM your ROM... Quickly turn off your computer and go and tell your Mom.
EDIT:
I recieved this in an e-mail from somone. And I am not trying to pass this off as authentic work. But as comic releif.
Whats the difference between mechanical engineers and civil engineers?
Mechanical engineers build weapons, civil engineers build targets
Where does your team get computers for Inventor? sanddrag Inventor 10 05-10-2005 16:44
Engineering and Computers sciguy125 Chit-Chat 7 01-10-2005 10:44
connect three computers without hub kirov Chit-Chat 9 28-02-2005 18:55
Moody Compiling on certain computers... ConKbot of Doom Programming 4 28-02-2005 18:22
PCs or Personal computers? Hinkel Y. Chit-Chat 9 12-12-2003 21:14
