Inductance of CIMs
Does anyone have a real multimeter and some CIMs lying about? One of our alumni needs the inductance of one of the kit CIMs, if you can measure it or have access to documentation. The measurement can be done without powering the motor, that will provide a sufficient approximation. Thanks!
Re: Inductance of CIMs
Bjorn,
You can't measure inductance with a multimeter and the measurement would only make sense if you were to measure each winding and average that data. As is, the brush assembly alternately contacts more than one winding at a time so mutual coupling will confuse the measurement as well. Any idea why the need for an inductance measurement? You might want to contact Mark McLeod, I think he has a better handle on this. |
The inductance of a DC motor is one of the parameters that is used when calculating the optimum frequency of the PWM fett H bridge. The power curve can also be plotted. For first robots this is all determined by IFI's victors and Firsts choice of motor. All First teams need to worry about is the joy tick - robot response. There are several posts regarding the curves that can be applied. The manufacture may have this data.
That said, the inductance needed to be included in this mathematical model, I'm told, because the power curve only provides insight to the motors behavior at a given fixed speed. It does not address how the motor responds as it accelerates. After some futzing about with a function generator and oscilloscope our alumnus found the result he was after. Last edited by phrontist : 03-01-2006 at 21:35. |
In almost every case (and perhaps EVERY case in a FIRST application), the time constant of the motor's inductance is at least an order of magnitude faster than the mechanical time constant of the system. Bottom line, the primary reason that the steady state speed-torque curves do not predict dynamic behavior of a motor+arm or a motor+robot is not that the motor current is hindered by the inductance of the motor windings but rather that the rotational velocity of the motor is hindered by the effective rotational mass of the system. Joe J. |
Although this has come up for discussion before, I believe what is of greater importance (effect) is the switching frequency of the bridge vs. the brush/commutator frequency of the motor. The discussion revolves around whether the switching frequency should be less than the commutator contact time at max RPM or significantly higher. At the current 2kHz, I believe that a number of pulses will be applied to a single winding (or pair) per contact. In the case of the FP where there is only three commutator segments, this is easy to achieve. In the Chalupa or the old drill motors, there are significantly more segments. The old speed controllers had a much lower switching frequency which made things a little more difficult for good motor performance. Remember, at full throttle (with a correctly calibrated controller) full DC is applied to the motor, no PWM.
Beyond this complexity there is ... I could go on, but I don't think it is helpful. For all cases I know of in FIRST, the inductance of the motor is a negligible effect. The only small asterist that I will provide is that the inductance plays a role (along with the PWM frequency and other factors) in the effectiveness of the assumption that we often use that PWM value given to the Victor is a good approximation of the Voltage applied to the motor (this effect is more pronounced at lower duty cycles). But even this effect is likely to be a noise factor in almost any control scheme teams are likely to employ on a FIRST robot. Callin' 'em as I see 'em... Joe J. |
Warning: Long response
There are 3 cases that are applicable to this discussion. Each of them involve cases where the normal behavior of motors did not behave as simple motor models would have us expect. One was a small motor doing a very big job. We had to do a lot of work in a small amount of time and we only had a 280 series motor can to work with. We had peak current specs, actuation times and actuation forces competing for the design space. We almost had it but we could not meet the peak current spec because the brushes bridged commutators and cause very short, very high current spikes. We ended up getting relief on the specs for current. The second was a largish motor (a Power Sliding Door motor). We were playing with PWM frequency to try to meet sound specs. PWM frequency can have a big effect on sound if you happen to be PWMing at or near a natural frequency of the body panels. As we varied PWM freq. we notice that as we increased the PWM frequency, we often had to increase the duty cycle of the motors (significantly at low duty cycles) in order to get the same performance of the motor. A simple analysis says that changing the PWM duty cycle is like changing the voltage on the motor. But this is not true, it is only a first order approximation. The approximation gets worse and worse as the PWM frequency grows. We believe that the main reason for this is that by increasing the PWM freq by a couple orders of magnitude, we started to get into the area where the inductance of the motor count not be neglected. The third was a small motor driving a very lightly loaded actuator (it was lightly loaded most of the time, some times we need every inch-ounce the motor could provide). We were having impact problems at the end of the travel. "No problem," we thought. We had a plan: we could reduce the PWM duty cycle, this would be like reducing the voltage to the motor, which (we all know) reduces the free speed of the (almost unloaded) motor. This plan was based on our assumption that changing the PWM duty cycle is like changing the voltage on the motor -- not exactly true. To our surprise, the free speed of the motor was basically flat as we reduced the duty cycle. Our tests were clear but our brains were fussy. What was going on? As it turns out, not all PWMing is created equal. Most PWMing (IFI's Victor included) switches between Vbatt and Open Circuit. This is what we were using. There are other types, but you can read my P.S. to learn about them. In this case, it turned out that both the mechanical time constant and the electrical time constanst were fast with respect to our PWM period. What would happen is that in one PWM pulse (even at low duty cycles) the motor would accelerate to the Vbatt freespeed.* Once the motor was at Vbatt free speed, it would stop accelerating. When the PWM pulse ended it would cause an open circuit between the motor leads. But an open circuit motor that is lightly loaded will coast at basically the same speed. So it would coast, slowing down a little but not much, until... ...the next PWM pulse would come along and give the motor another kick, back up to the Vbatt freespeed. It was not until the duty cycle got down to near the electrical or mechanical time constants of the motor that it slowed down at all. A very unexpected result, given our assumptions. By the way, other forms of PWM do not share this problem and are better for slow speed control of motors as a result. So. That is that. Probably more than you wanted but you got anyway... Joe J. *FYI, back in the 70's when Permanent Magnet (PM) motors were new to the auto industry (and the world actually), GM did some tests on a 280 series lock unlock motor. An unloaded motor got up to its 12V free speed (12Krpm) from a dead start IN 1/4 TURN!!!! P.S. There are at least 2 other methods of driving motors that are called PWMing. Recall the first type is to switch between Vbatt and Open Circuit. You can also switch between Vbatt and Shorting the motor leads (connecting both leads either to ground or to Vbatt, it makes little difference to the motor - it can make a lot of differenced to the voltage spikes the rest of the system sees -- but that is a different message). In my opinion, this is the type of PWMing we would like to use in almost all FIRST applications because it is easier to do control tasks that involve speed control using this method. The reasons are complicated, but there is a term in the equations of motion that help make the speed of the motor less sensitive to changes in load. This term is particularly effective at slow speeds so when you want to control something at slow speeds it helps you the most. Who has had fits and sleepless nights trying to get a FIRST robot arm to behave? Some of those lost winks could have been yours if IFI would implement a method to implement this type of motor driver. You can also switch between Vbatt and -Vbatt (this kind of motor driver is sometimes called locked anti-phase -- see what Brother Barello has to say about it here). This sounds crazy because in order to get the motor to turn OFF you have to kick it half the time with Vbatt and half the time with -Vbatt. The reason I bring this up at all is that if it were not for inductive limitations on the current through the motor, OFF would essential be stalling the motor. I have never used this type of drive but the PWM frequency must be high enough to limit the current because people DO use this method. I should actually play with this method because it sort of seems too crazy to actually believe. The fact that people are not generally stupid (especial folks who build robots) and yet they use them must mean that they have something to offer (more than Barello's only 1 I/O pin required argument). I just did some digging. I found this quote (here): Quote:
From the National Semiconductor app note referenced above: Quote:
#11
Just saw this on the Globalspec web site.http://www.globalspec.com/MSKennedy/...eed_020802.pdf
It details the other speed controller Joe mentioned. These are used allot for brushless dc servo motors. The pulse width period can also have an effect on brush - commuter wear. Too long a period can cause wear.This link was posted in another thread this year. It may be of interest to reviewSpeed controller |
#12
Jim,
It is difficult to get a good read on the inductance of the motors when the brush assembly covers more than one winding most of the time. We can get an idea from backing into calculations if we make some assumptions. The worst case inductance stated so far is 230 micro henries. If we know that the switching frequency of the controller is about 2kHz and that there are 127 steps between full on and full off then (assuming no dead band) 1/2kHz=.5msec/127= 4 microseconds as the minimum "on" time for the controller. If we assume a stall current of 100 Amps (this makes the calculations easier) then the internal resistance = .12 ohms. Add to that a typical wiring/controller/connector/breaker loss of .03 ohms a typical robot will have a series resistance equivalent of .15 Ohms. Plug that into the charge equation for an inductor, I=(E*(1-e^^(-tR/L))/R or about .15 amps for the lowest speed PWM(if the controller is calibrated). An inductor (our motor winding) will reach about 90% of stall current (for this theoretical motor only) in approximately 2L/R or 0.07 msec or about at the 008 PWM value. It will reach full short circuit current in 6L/r or 0.2 msec or about 064 PWM value. Now all of this theory still does not account for the motor moving, different windings being switched in and out by the brushes or the mutual magnetic coupling taking place between windings. I think it is safe to say that we can reach full stall current on the motor (limited by the series resistance of all the losses) in a very short time. So for all but the most inquisitive, the effect of motor winding inductance does tend to be negligible for our use. Please note: that the motor will start to turn almost immediately unless stalled by an external force. It is there and it does effect the operation when viewed on test equipment but it does little for robot operation (with the motors we use) because of the human and electronic factors that come into play during a match. Let us not forget that full up on the throttle produces full DC where full stall current will be reached in 0.2 msec. or about 1/20 the reaction speed of the best driver. As to discussion on some of the other topics. A "locked" motor is essentially a powered stall condition that requires precise choice of switching frequency to make the most efficient use of the specific motor in use. Please note that this method is the most costly in electrical terms since the load is always consuming full stall current when doing no work. As to the two methods of motor drive... A dual polarity power supply does allow a simplification of the drive circuitry if you already have the power supplies in use in your system. A video recorder does use this drive system since it requires the dual supply for other analog circuitry. It also uses the antiphase locking feature in oder to produce a synchronous locked video still frame from tape. With the single supply, our motors and the systems in use, the speed controller running at 2Khz makes the most sense and takes into account all of the tradeoffs that need to be made in order to get a robot running. P.S. Remember the controller output alternates between +12 and open circuit. It is not swinging to ground. That means that the when the power is removed, there is no circuit into which the inductor will discharge. Even though the magnetic field is collapsing, there is no where for the current to go. The controller only produces a load on the motor during a PWM 127 +/- the deadband and only when the jumper is in "brake" setting. While the motor is turning, a moving coil in a magnetic field will produce a current if there is a circuit for it to flow into. All of these events add up to the charachteristics you may see when using an oscilloscope to view these complex motor waveforms. Please remember when using the discharge equations for inductance that the resistance of the circuitry for a controller in "brake" no longer includes the supply side wiring (battery connectors, circuit breakers, supply side wiring and breaker panel). The only resistance is the wire and connectors between the motor and controller and the internal resistance of the controller. (as low as .0025 ohms) Last edited by Al Skierkiewicz : 06-01-2006 at 19:42. |
#13
![]() So yes, very small, but it doesn't account for all sorts of factors. |
| Could a magnetic field around CIMs cause fuses to blow? | scitobor 617 | Electrical | 41 | 15-02-2005 08:56 |
| where to buy cims | Brawler006 | Motors | 2 | 26-01-2004 13:16 |
| Gears for CIMs | Brawler006 | Motors | 5 | 18-01-2004 09:46 |
| 40A Breakers popping when using CIMs | galewind | Electrical | 9 | 13-02-2003 10:30 |
