Go to Post The final product, the inspiration, it all that matters. Awards and championships are just bling. - artdutra04 [more]
Unread 03-01-2006, 15:44
Salik Syed Salik Syed is offline
FRC #0701 (RoboVikes)
Salik Syed has much to be proud ofSalik Syed has much to be proud ofSalik Syed has much to be proud ofSalik Syed has much to be proud ofSalik Syed has much to be proud ofSalik Syed has much to be proud ofSalik Syed has much to be proud ofSalik Syed has much to be proud ofSalik Syed has much to be proud of
Send a message via AIM to Salik Syed
microcontroller for rocket.
My team is building a rocket for a rocketry contest.
We want to use some kind of micro controller that can eject the parachute at a set height etc..
the requirements:
it should be able to control two servos
it should be able to get input from an analog sensor
it should be programmable in C or Pbasic
What should we use? Which is easiest to hook up and program. What model do you recommend basically?
Team 701
Vex Microcontroller Model petek Inventor 6 13-12-2005 15:24
microcontroller selection¿ Rickertsen2 Programming 11 25-05-2003 10:52
