Go to Post Why is it OK to be "elitist" when we select people to be on a team to hit rocks with sticks, but not OK when we try to reach the special group of students that embody the intellectual capital that will define the future of this country? - dlavery [more]
Thread Tools Rating: Thread Rating: 4 votes, 4.75 average. Display Modes
Unread 07-01-2006, 21:52
b_mallerd b_mallerd is offline
Programmer
FRC #1346 (Trobotics)
b_mallerd is on a distinguished road
Send a message via MSN to b_mallerd
Re: ***THE GAME OFFICIAL: AIM HIGH***
I'm still wondering about that ball issue.
Does this mean that each team will already have 40 balls at thier disposal ALONG WITH up to 10 balls in each robot? Or does it mean 40 balls and you can stick balls in the robots but then that gets subtracted from your total?
Unread 07-01-2006, 22:29
Billfred's Avatar
Billfred Billfred is offline
Your alliance as a whole gets 40. Each robot can hold up to 10. Any balls the robots don't have onboard get distributed at the player stations.
Unread 07-01-2006, 22:53
BrianR BrianR is offline
AKA: Brian Roehl
FRC #1525 (Warbots)
Team Role: Electrical
BrianR has a spectacular aura aboutBrianR has a spectacular aura about
Send a message via AIM to BrianR
I have a specific question. It states in this rule:
<G13> Balls Contained in ROBOTs at the Start of a match - Each ALLIANCE will start a match with 40 balls.
Each ROBOT may contain up to 10 balls at the start of a match. Any balls not contained within the robot
will be evenly distributed between the alliance ball corrals. All of the balls must be contained within the
ROBOT’s 28” x 38” x 60” starting volume and must be clearly visible from outside the ROBOT. The
Head Referee will require that balls outside of the starting volume be removed. It is the responsibility of
the head referee to verify that this rule is satisfied prior to the start of the match.
So do they have to be totally visible, from all angles, which sounds a bit unreasonable, or should the referee just be able to see each ball from some point outside of the robot, and if that is so, what happens if because a bunch of balls are stacked together, a ball is hidden by other balls, and is thus not visible to the referee? Is there a penalty for that, I can't find a penalty for failing to comply with this rule, so what exactly would they do in that situation.
Unread 07-01-2006, 23:10
George A.'s Avatar
George A. George A. is offline
I come through in a spinsch
AKA: George- The Voice
FRC #0303 (TEST Team)
George A. has a reputation beyond reputeGeorge A. has a reputation beyond reputeGeorge A. has a reputation beyond reputeGeorge A. has a reputation beyond reputeGeorge A. has a reputation beyond reputeGeorge A. has a reputation beyond reputeGeorge A. has a reputation beyond reputeGeorge A. has a reputation beyond reputeGeorge A. has a reputation beyond reputeGeorge A. has a reputation beyond reputeGeorge A. has a reputation beyond repute
Send a message via AIM to George A.
I don't think that it will be penalized when 10 balls are piled in...you obviously can't see through the balls...or it could be one of these "up to the discretion of the referee" deals...in which case they should have a set guideline to go by so there isn't the confusion like there was last year.
My Volunteer Resumé
Game Announcer NJ: 2005-Present
Game Announcer Philly: 2006-Present
Game Announcer NY: 2005-2008
Game Announcer Champsionships: 2005-2008
Unread 07-01-2006, 23:13
slickguy2007 slickguy2007 is offline
Copioli is the man!!!
FRC #1403 (Cougar Robotics)
Rookie Year: 1997
slickguy2007 has a reputation beyond reputeslickguy2007 has a reputation beyond reputeslickguy2007 has a reputation beyond reputeslickguy2007 has a reputation beyond reputeslickguy2007 has a reputation beyond reputeslickguy2007 has a reputation beyond reputeslickguy2007 has a reputation beyond reputeslickguy2007 has a reputation beyond reputeslickguy2007 has a reputation beyond reputeslickguy2007 has a reputation beyond reputeslickguy2007 has a reputation beyond repute
Send a message via AIM to slickguy2007
That is a good question, I would bring it up with Q&A and wait for their response. I would assume that they just want to make sure that before the 10 balls are loaded, the robot does not already contain extra balls for cheating purposes. So as long as the refs can easily see nothing is in the robot before and after matches, you should not have a problem. This is only an assumption, I would still contact Q&A about this.
GO 1403 and GOOD LUCK TO ALL 2006 FRC TEAMS!!!
Team 1403 is Proudly Sponsored By:
Unread 07-01-2006, 23:19
PARhodes's Avatar
PARhodes PARhodes is offline
FRC #1559 (Devil Tech)
Team Role: Mechanical
PARhodes has a little shameless behaviour in the past
Just design for the rule. If the ref cant see them, like you said its up to their discretion, but i wouldnt take the chance.
Unread 07-01-2006, 23:30
cbudrecki's Avatar
cbudrecki cbudrecki is offline
AKA: Carl Budrecki (buh-dre'-key)
FRC #0222 (Tigertrons)
cbudrecki is a name known to allcbudrecki is a name known to allcbudrecki is a name known to allcbudrecki is a name known to allcbudrecki is a name known to allcbudrecki is a name known to all
3.4.3 Ball CorralsA Ball Corral is located at the ends of the Alliance Station Wall to restrain any balls that enter through the Corner Goals. The Ball Corral covers a four-by-four foot area. The side walls of the Ball Corral are three feet tall and constructed of square aluminum tube and polycarbonate. The back wall of the Ball Corral is of similar construction, except it is only 20 inches tall to permit easy retrieval of balls from the interior of the corral.
<G39>Scoring Inerference - HUMAN PLAYERs, DRIVERs, or COACHes may not reach into a ball chute or in any way interfere with the ball counting system. Violations of this rule will result in DQ.
I'm I misinterpreting, or do these statements contradict each other?
Unread 07-01-2006, 23:46
PARhodes's Avatar
I think there are designated makrs on the ball chorals which would be "roped off". Just dont reach into there which would interefere play. But you need to pick the balls out.
Unread 08-01-2006, 02:04
Wetzel's Avatar
Wetzel Wetzel is offline
DC Robotics
FRC #2914 (Tiger Pride)
Rookie Year: 1999
Wetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond repute
Send a message via AIM to Wetzel
No.
The ball chute is the drop for the center goal and the ball corral is for the two corner goals. You may not interfere with the ball counting system for either.
Originally Posted by netman85am204
I am believing that the velocity speed limit (12 m/s or 28.6 mph) would be the fastest the ball could travel through the center goal to actually be counted as a score by the automatic counting mechanism for their alliance.
-matt
This is incorrect. Per <S02>, the velocity at which the ball exits the muzzle(your robot) may not excede 12 m/s. This is considered in violation of <S01>, 10 point penatly and disabled for the remainder of the match.
Originally Posted by <S02>
Muzzle Velocity - No ROBOT may throw a ball with an exit velocity of greater than 12 m/s (26.8 mph). As a reference, a ball traveling at this velocity when leaving the ROBOT at an angle of 30º from horizontal with no spin will travel approximately 35 feet. A robot that violates this rule will be considered unsafe per <S01>.
Does anyone know if a human player picking up a ball from the corral happens to drop it across the counting system, will the other team get a point?
Wetzel
Viva Olancho!
Video Game game. Eria4044 Games/Trivia 168 01-06-2006 10:11
We Aim For The Stars Part III Ken Leung General Forum 5 03-01-2006 16:57
"Gyrating Jamboree" game Mike Ciance Chit-Chat 7 26-05-2004 09:35
crazy game Mike Ciance Fantasy FIRST 22 25-05-2004 11:37
i didnt like this years game....please read archiver 2001 19 24-06-2002 03:23
