Go to Post And if in the end the students are inspired and more of the public becomes aware of the program, and people gain more appreciation for engineering, how can that not be a good thing? - dlavery [more]
Unread 08-01-2006, 00:15
armoredvehicle's Avatar
armoredvehicle armoredvehicle is offline
ArmoredVehicl
AKA: Ahmad El-Arabi
FRC #0691 (HartBurn)
Team Role: Electrical
armoredvehicle is on a distinguished road
Send a message via AIM to armoredvehicle
Exclamation Serial Port Joysticks!!
This is crazy. I have looked thru every possible website for a serial port Joystick. Are they even made any more? My team still has the old controllers from last year, but I want to find two new controllers so that lefties and righties can control the robot. Half of my team is lefty so its kind of important. So if ANY body has an idea or can give me a brand of joysticks they use, I and my team would GREATLY APPRECIATE IT!
Unread 08-01-2006, 00:17
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
FRC #0254 (The Cheesy Poofs)
Re: Serial Port Joysticks!!
This thread should be helpful.
2001-2004: Team 100
2006-Present: Team 254
Unread 08-01-2006, 00:32
gburlison gburlison is offline
Mentor
FRC #0662 (Rocky Mountain Robotics)
Rookie Year: 2000
gburlison is a name known to allgburlison is a name known to allgburlison is a name known to allgburlison is a name known to allgburlison is a name known to allgburlison is a name known to all
And they are not serial ports (9 or 25 pin connector or USB) they are joystick ports (15 pin connector). Might be time to build our own joystick. If FIRST Teams can build a robot, maybe we should be able to build a joystick. AndyMArk where are you?
Gordon Burlison - Mentor
662/Rocky Mountain Robotics
"Every silver lining's got a Touch of grey - Robert Hunter"
"No sense in being pessimistic, it wouldn't work anyway"
Unread 08-01-2006, 08:15
Dakota Snow's Avatar
Dakota Snow Dakota Snow is offline
FRC #0957 (WATSON)
Dakota Snow is an unknown quantity at this point
have you try to froogle.com
Unread 18-01-2006, 22:51
Bruce Mather's Avatar
Bruce Mather Bruce Mather is offline
Reggie Programmer Ya Mon
AKA: Bruce Mather
FRC #0449 (Toltechs)
Bruce Mather is on a distinguished road
I don't entirely see how a serial port joystick works. A serial port interface generally requires the external device to have power since you have to drive RS-232 lines (+/- 12 vdc) as input to the computer. So you either have batteries or you have to phantom power from the RS-232 control lines (has been done, but not recommended due to the limitations of sink current on those lines). Also, a typical joystick has many channels: X, Y, 2 or more switches. These all have to be muxed into the RS-232 channel at a reasonably high rate (low latency) for a good response time for a game. Then you would need a PC (Windows?) device drive that could take this mux'ed RS-232 input and convert it into something looking for a gameport interface. Not impossible I suppose.
The beauty of the joystick is that the PC supplies a voltage on this 15 pin connector, uses the pots in the joystick as part of an RC circuit and measures the decay time of this RC circuit (I think that is the way it worked when I was a wee lad). Almost too simple. Plus other wire inputs for directly measuring switches.
The real problem we're facing is that RS-232 is GOING AWAY in favor of USB. My own laptop didn't have a RS-232 (DB9) port to test the camera with! But more USB ports than I could shake a stick at...
Unread 18-01-2006, 23:23
nuggetsyl's Avatar
nuggetsyl nuggetsyl is offline
FRC #0025
Team Role: Coach
nuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond repute
i rember when we heard they switched from the old joystick to the new one. One of our team members (lol you know who you are) bought the last 25 in stock from a store in ca. Now we find them on ebay and bid on them but still have the new ones for when we build each year.
shaun
Unread 18-01-2006, 23:40
Adam Richards's Avatar
Adam Richards Adam Richards is offline
I'm baaaaaaack.
FRC #1902 (Exploding Bacon)
Adam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond repute
Send a message via AIM to Adam Richards
Just incase anyone didn't know, the old kit joystick was called a "CH FlightStick". There was also a "CH FlightStick Pro" version released which has a larger button pad and the other two joystick axis on the top (see image below).
Unread 18-01-2006, 23:53
Unsung FIRST Hero
Mike Betts Mike Betts is offline
Electrical Engineer
Rookie Year: 1995
Mike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond repute
Originally Posted by Adam Richards
Just incase anyone didn't know, the old kit joystick was called a "CH FlightStick". There was also a "CH FlightStick Pro" version released which has a larger button pad and the other two joystick axis on the top...
Yes but it sports a USB interface...
Mike
Mike Betts
Alumnus, Team 3518, Panthrobots, 2011
Alumnus, Team 177, Bobcat Robotics, 1995 - 2010
LRI, Connecticut Regional, 2007-2010
LRI, WPI Regional, 2009 - 2010
RI, South Florida Regional, 2012 - 2013
As easy as 355/113...
Unread 19-01-2006, 00:01
I'm baaaaaaack.
Mike
Not true. Many of the ones sold now have USB interfaces, but I bought a Pro off of eBay last week with a gameport interface and it arrived at my house today when I got home. I know that Team 237 (SIE-H20-BOTS) is using a gameport Pro this year as well.
Unread 19-01-2006, 00:26
Unsung FIRST Hero
Electrical Engineer
Rookie Year: 1995
Adam,
I understand that you may be able to get old models from ebay but, if you check their website, all they offer is USB.
If I am in error, please let us know. A lot of teams would like to buy the gameport interface model (hence the reason for this thread).
Regards,
Mike
Mike Betts
Unread 19-01-2006, 00:35
I'm baaaaaaack.
Adam,
Regards,
Mike
Oh, right, sorry. In that case, then you're 100% correct. They stopped production on their gameport version (about the same time FIRST stopped putting them in our kits), but they still do sell replacement parts (potentiometers, springs) on their website.
Unread 19-01-2006, 10:51
artdutra04's Avatar
artdutra04 artdutra04 is offline
VEX Robotics Engineer
AKA: Arthur Dutra IV; NERD #18
FRC #0148 (Robowranglers)
artdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond repute
If you don't want to customize the KOP Joysticks, you can always try to "build your own" joysticks. Happ Controls sells tons of old coin-op video arcade replacement parts such as buttons, analog joysticks, trackballs, steering wheels, speed shifters, and more.
I like to browse through there whenever I am looking for cool ideas for our operator interface. Last year, our team bought a whole bunch of the push buttons from them for our operator interface from last year.
Art Dutra IV
Robotics Engineer, VEX Robotics, Inc., a subsidiary of Innovation First International (IFI)
Robowranglers Team 148 | GUS Robotics Team 228 (Alumni) | Rho Beta Epsilon (Alumni) | @arthurdutra
世上无难事,只怕有心人.
Unread 28-01-2006, 06:14
cdennisxlx2's Avatar
cdennisxlx2 cdennisxlx2 is offline
Team San Diego Web Liaison
AKA: Cameron Dennis
FRC #1266 (The Devil Duckies)
cdennisxlx2 is a splendid one to beholdcdennisxlx2 is a splendid one to beholdcdennisxlx2 is a splendid one to beholdcdennisxlx2 is a splendid one to beholdcdennisxlx2 is a splendid one to beholdcdennisxlx2 is a splendid one to beholdcdennisxlx2 is a splendid one to behold
Question Re: Serial Port Joysticks!!
Can this, http://shop.atriniti.com/product_inf...odel_id=22705A , be used to set up a USB controller for the FIRST OI board?
Team San Diego Robotics Web Liaison
Webmaster and Technical Advisor for the San Diego Regional Planning Committee.
Official Score Keeper for the San Diego Regional
www.sandiegoregional.com
www.frc1266.com
Unread 28-01-2006, 08:21
Mark McLeod's Avatar
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
I think that goes the wrong way.
I believe it allows you to use an old style port joystick with a USB system rather than a new style USB joystick with a joystick port based system.
  #15   Spotlight this post!
Unread 28-01-2006, 21:15
AKA: Cameron Dennis
but all you would have to do is splice the ends to make it the other way
www.frc1266.com
Scripting Setup and the Camera + Serial Port Drivers CJO Programming 22 11-01-2006 17:42
User input via serial port AJBelayer FIRST Tech Challenge 2 14-12-2005 18:54
TTL port to a serial port on a demo board ImmortalAres Programming 16 09-07-2005 23:44
Updated: Serial Port Driver Code Kevin Watson Programming 4 05-02-2005 18:39
New Serial Port Driver Kevin Watson Programming 16 09-01-2005 01:56
