Omni-Wheel Design
Has any team come up with an omni-wheel design that allows for the mini-wheels in each omni wheel to turn on their own?
Re: Omni-Wheel Design
P.S i hope you dont have in mine an omni-whell design for this years competition i wouldnt recomend it |
sorry. what i mean is that the omnis are not positioned like this
- || - or any similar designs. I want to know if you can get the mini-wheels moving by motor or some other means. |
yea for the holonomic drive the wheels are position at 45 degree angles like this
/ \ I cant understand a practical reason for controling the miniwheels \ / on a motor? |
there is...i can assure you
one, i dont think its possible, two the prograaming would be ridicoulously complex to make it all those wheels actually being controlled by motors.
i figured it out...using gears
Sure its possible, but it would be overcomplicated, require very big wheels or very small gears.
The reasons I could see for this would be so be able to more easily climb the ramp, and have more pushing power in the forward direction. I think you talking about positioning the wheels like this. | | | | with the rollers opposite. Is this correct? Also the programing for this would be no more complicated than the pro gaming for a normal omni drive. However I don't see the benefit of this over using a swerve drive because its more complicated to build and doesn't hold any advantages over a swerve. Alex |
| pic: Omni Wheel Drive -- Top | Richard Wallace | Extra Discussion | 4 | 05-12-2005 18:55 |
| Wheel Layout/Attachment Design | Andrew Blair | Technical Discussion | 3 | 12-10-2005 19:29 |
| new wheel design | mechanicalbrain | Technical Discussion | 20 | 29-06-2005 14:13 |
| Omni wheel supplier | JamesBrown | Technical Discussion | 5 | 25-02-2005 13:27 |
| pic: Team 60 Wheel Design | CD47-Bot | Extra Discussion | 6 | 18-11-2004 19:57 |
