Go to Post STEM is the new cool, STEM is the new fun, but nobody said STEM is the new easy. - Taylor [more]
Unread 08-01-2006, 17:54
Larry Barello Larry Barello is offline
http://www.barello.net
#0492 (Titan Robotics Club)
Larry Barello has a spectacular aura aboutLarry Barello has a spectacular aura about
Specification for timing belt pulley on large CIM?
Subject says it all: What are the specifications of the belt that mates with the pulley.
On a related topic, where would I purchase belts and or blank pulley stock to match (3" in diameter, say, hmm, 21 inches long).
Cheers!
Unread 12-01-2006, 19:52
Andrew Blair's Avatar
Andrew Blair Andrew Blair is offline
SAE Formula is FIRST with Gasoline.
FRC #0306 (CRT)
Andrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond repute
Send a message via AIM to Andrew Blair Send a message via Yahoo to Andrew Blair
Re: Specification for timing belt pulley on large CIM?
I'm bumping this thread. I'd also like to know the timing belt needed for the large CIM.
Reading makes a full man, conference a ready man, and writing an exact man.
-Sir Francis Bacon
"Any intelligent fool can make things bigger, more complex, and more violent. It takes a touch of genius -- and a lot of courage -- to move in the opposite direction."
-Albert Einstein
Unread 12-01-2006, 19:56
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
Rookie Year: 1999
Madison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond repute
In another thread, Paul Copioli posted that the supplied timing belt pulley is 16 tooth, 3 mm pitch and 15 mm wide, matching the PowerGrip GT 2 Series available from Gates.
--Madison--
...down at the Ozdust!
Like a grand and miraculous spaceship, our planet has sailed through the universe of time. And for a brief moment, we have been among its many passengers.
Unread 12-01-2006, 20:13
Dr.Bot
Posts: n/a
What FP product did this motor come off of, and how was it used? I am having trouble visualizing how the assembly would work installed in a power wheels vehicle. It seems if the belt breaks, the metal bar would slam into the
the shaft, and grind a nice groove while placing a no-no side load to the shaft.
Also, I was always taught that belts are fairly inefficient as a method for transferring power, especially for a vehicle. Maybe FIRST got all these motors
because they were recalled!
But that aside, they look like they can do some heavy lifting. Gear these babies right, and you'll be able to launch your entire robot through the center goal.
Unread 12-01-2006, 21:22
FRC #0306 (CRT)
Well, the pulley it uses is for timing belt, greatly decreasing, if not eliminating the amount of slip on a conventional belt drive. What I'm having trouble envisioning is how they mounted the wacky thing. I can only imagine a cnc'd hole, with setscrews holding it in place.
-Sir Francis Bacon
-Albert Einstein
Unread 13-01-2006, 09:45
1. Timing belts have no slip and are very efficient, quiet way to transfer power. They don't stretch either so they transfer shocks even more efficiently than chain - which is a design consideration - you might need torque limiters, for example.
2. The large CIMs have less overall output power than the small CIM, look elsewhere in this forum for details. Their main attribute is 1/2 the shaft speed and probably a much higher sustained output before overheating.
Unread 13-01-2006, 09:51
BlazinFire47's Avatar
BlazinFire47 BlazinFire47 is offline
Alumni
AKA: Blaze/Blackmoon/Nova
FRC #0047 (Chief Delphi)
BlazinFire47 is on a distinguished road
Send a message via AIM to BlazinFire47 Send a message via MSN to BlazinFire47 Send a message via Yahoo to BlazinFire47
the real question is why even a belt pulley??? most teams use chain and sprockets on thier robots, to much tension on the belts and they will rip. the only use i see for the new chips are for like trap door applications, or sliders, and other slow, but torquey situations.
Unread 13-01-2006, 17:32
FRC #0306 (CRT)
Most belts are reinforced with a fiber or cable that makes them extremly torque capable. These are not sanding belts
[img]http://images.google.com/images?q=tbnaGeAMdhjbLqcM:images.amazon.com/images/P/B000APLENW.01-A3REKJCJFKDI0B._SCMZZZZZZZ_.jpg[/img]
Or dress belts
http://images.google.com/images?q=tb.../Galco/SB3.jpg
They're are reinforced timing belts, meant to replace chain drives. And the MiniBike CIMs run at 2500 rpm, so its going to take a large bit of reduction to put them into a "slow, torquey situation". Though they would work well for stating a flywheel...
-Sir Francis Bacon
-Albert Einstein
Unread 14-01-2006, 20:13
bjimster1's Avatar
bjimster1 bjimster1 is offline
AKA: Jimmy Bourne
FRC #1029 (Wolvcats)
bjimster1 is just really nicebjimster1 is just really nicebjimster1 is just really nicebjimster1 is just really nice
Send a message via AIM to bjimster1
ok i found the correct belt for this thing but how about the pulleys? where can i get 3mm pitch, 15mm wide pulleys?
neither mcmaster or grainger has them which is pretty amazing, because there arent that many things that neither of these two companies carry.
if thats not possible are there any gears or pulleys with a flat side, to put in place of the existing pulley on the big CIM?
thanks
-2006 UCF Quarterfinalists w/ 1345 & 21
-2005 Peachtree Quarterfinalists w/ 1180 & 462
-2005 UCF Quarterfinalists w/ 1694 & 348
CMU '11
Unread 15-01-2006, 10:36
George George is offline
#0060 (Bulldogs)
George is a splendid one to beholdGeorge is a splendid one to beholdGeorge is a splendid one to beholdGeorge is a splendid one to beholdGeorge is a splendid one to beholdGeorge is a splendid one to beholdGeorge is a splendid one to behold
Try Stockdrive Sterling NY. spd-si.com
Great people, good service, lots of hard to find stuff,
They have pully stock too!
Have Fun!
Geo.
watch the oz, the lbs take care of themselfs
Unread 15-01-2006, 12:21
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
FRC #0254 (The Cheesy Poofs)
Have Fun!
Geo.
I too love SDP, and this was the first place I looked for pulleys. However, unless I'm missing something the largest width pulley they offer in 3mm pitch is only 9mm.
2001-2004: Team 100
2006-Present: Team 254
Possible to do multi-speed transmission with v-belt? Squirrelrock Motors 15 13-12-2005 14:44
How do you Calculate Belt Length? Gabriel Technical Discussion 7 08-11-2004 14:54
