Go to Post It's still not about the robots. FIRST is about doing the right thing. - DonRotolo [more]
Go Back   Chief Delphi > Technical > Kit & Additional Hardware
Unread 08-01-2006, 18:39
BobC's Avatar
BobC BobC is offline
Big Daddy
FRC #0176 (Aces High)
Rookie Year: 2000
BobC is a name known to allBobC is a name known to allBobC is a name known to allBobC is a name known to allBobC is a name known to allBobC is a name known to all
Send a message via AIM to BobC
Green Light Power Source
We went to build our green light that goes above center goal. We could not figure out how to power it. Does anyone know how it is to be powered? I know this should go on First site, but no one knows where the password for their site is. I was hoping to get a faster answer here.
Thanx
FIRST Robotics is like NASCAR for Geeks.
1999 National Champions
Unread 08-01-2006, 18:43
mechanicalbrain's Avatar
mechanicalbrain mechanicalbrain is offline
The red haired Dremel gnome!
FRC #0623 (Ohm robotics)
Team Role: Electrical
mechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond repute
Send a message via AIM to mechanicalbrain Send a message via Yahoo to mechanicalbrain
Re: Green Light
As I recall their are green cold cathode tubes in the KOP, or are you asking how to power those? Their is also a included inverter, make sure you use it and don't try powering the tubes directly.
"Oh my God! There's an axe in my head."
623's 2006 home page
random mechanicalbrain slogans
Unread 08-01-2006, 18:45
dlavery's Avatar
dlavery dlavery is offline
Curmudgeon
FRC #0116 (Epsilon Delta)
Rookie Year: 1996
dlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond repute
Re: Green Light
Connect it to a 12V power source. If you can find one anywhere, you might try to look for a 12V battery - that would probably work (hint, hint )
"I know what you're thinking, punk," hissed Wordy Harry to his new editor, "you're thinking, 'Did he use six superfluous adjectives or only five?' - and to tell the truth, I forgot myself in all this excitement; but being as this is English, the most powerful language in the world, whose subtle nuances will blow your head clean off, you've got to ask yourself one question: 'Do I feel loquacious?' - well do you, punk?"
- Stuart Vasepuru, 2006 Bulwer-Lytton Fiction Contest
My OTHER CAR is still on Mars!!!
Unread 08-01-2006, 18:54
Billfred's Avatar
Billfred Billfred is offline
Re: Green Light
Probably a slightly silly question, but will the fact that our 12V batteries are often slightly more than 12V negatively affect the lights?
Unread 08-01-2006, 18:57
Re: Green Light
Yes they will be slightly brighter. From playing with moding computers I can tell you the voltage difference in the battery won't do much. I would using a AC to DC 12 volt converter though.
Unread 08-01-2006, 23:13
Sscamatt's Avatar
Sscamatt Sscamatt is offline
AKA: Matt Syska
FRC #0195 (Cyber Knights)
Sscamatt has much to be proud ofSscamatt has much to be proud ofSscamatt has much to be proud ofSscamatt has much to be proud ofSscamatt has much to be proud ofSscamatt has much to be proud ofSscamatt has much to be proud ofSscamatt has much to be proud ofSscamatt has much to be proud ofSscamatt has much to be proud of
Send a message via AIM to Sscamatt
Re: Green Light
An old computer supply makes a nice and cheap 12v power supply.
2006 Championship Finalist, Thanks 25 + 968!
2006 Newton Division Winner
2006 International Innovation In Control Award
2006 Radio Shack Innovation in Control Award, UTC Regional
RIT Class of 2011
Unread 08-01-2006, 23:40
Re: Green Light
That it does! For those interested take a look at this thread. http://www.chiefdelphi.com/forums/sh...ad.php?t=39754
Careful though you can make lots of magic smoke doing this wrong. You essentially short a specific wire, and shorting the wrong wire can be very bad.
Unread 09-01-2006, 00:48
Rickertsen2 Rickertsen2 is offline
Umm Errr...
None #1139 (Chamblee Gear Grinders)
Rickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant future
Send a message via AIM to Rickertsen2 Send a message via Yahoo to Rickertsen2
Re: Green Light
The last few years, we have had CCFL's very similar to the ones used for the vision target on our robot. The brightness is effected slightly by input voltage, but not too much until the battery gets really low.
1139 Alumni
Unread 09-01-2006, 06:15
KTorak's Avatar
KTorak KTorak is offline
Fire Rescue 47
AKA: Kyle Dersch
FRC #1023 (Bedford Express)
Team Role: Driver
KTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond repute
Send a message via AIM to KTorak
Re: Green Light Power Source
I'm assuming they included all the parts that normally come with a cold cathode tube kit, in which you could just hook it up to any computer with extra power connectors, or even just plug it into a power supply.
Kyle D- Myspace - Facebook
2008 Bedford Express Driver & Build & Design (Team) Co-Leader
2007 Bedford Express Driver & Build & Design (Team) Leader
2006 Bedford Express Driver, Build Team Member, & Board of Directors
2005 Bedford Express Rookie, Build Team Member & Robot Operator
2008 - GLR Quarter Finalist
2007 - GLR Finalist & Boilermaker Finalist & MARC Off Season Event Winner
2006 - GLR Johnson & Johnson Sportsmanship Award & Archimedes 7th Seed Quarter Finalist
2005 - GLR Finalist & Judges Award.
2004 - GLR Semi Finalist.
2003 - GLR/DTR Quarter Finalist & GLR/NAT'L Rookie All Star.
Unread 08-01-2006, 18:55
Unsung FIRST Hero
Greg Marra Greg Marra is offline
[automate(a) for a in tasks_to_do]
FRC #5507 (Robotic Eagles)
Greg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond repute
Re: Green Light
Worth noting: The 8 cathodes and a small fan will require more than 1 amp to power. Our team has a 1 amp power supply that we hooked up to it, but it was only able to power the system at 8 volts.
I need to find where we put our spare Anderson hookup...
Unread 09-01-2006, 00:10
Arkorobotics's Avatar
Arkorobotics Arkorobotics is offline
Robots!
AKA: Ara Kourchians
FRC #0589 (FalkØn)
Arkorobotics is a splendid one to beholdArkorobotics is a splendid one to beholdArkorobotics is a splendid one to beholdArkorobotics is a splendid one to beholdArkorobotics is a splendid one to beholdArkorobotics is a splendid one to beholdArkorobotics is a splendid one to behold
Send a message via AIM to Arkorobotics
Re: Green Light
Cool, a wireless field you can setup anywhere! Battery +field = field anyway!
I like this idea of a green LIGHT, it's a nice idea.
2007 Rockwell Automation Innovation in Control Award winners (Southern California Regional)
Crescenta Valley High School Team 589
http://www.arkorobotics.com My Blag
3.141592653589793238462643383275902884197 <- Current memorization of Pi
Callsign: N6ARA
Unread 09-01-2006, 11:55
jerry w's Avatar
jerry w jerry w is offline
Free Agent Mentor
no team (Team Krunch)
jerry w has much to be proud ofjerry w has much to be proud ofjerry w has much to be proud ofjerry w has much to be proud ofjerry w has much to be proud ofjerry w has much to be proud ofjerry w has much to be proud ofjerry w has much to be proud ofjerry w has much to be proud of
Re: Green Light
wait a minute...
Dave posted a hint here yesterday. but no one has tried to analyze it word by word.
has something changed since the kickoff???
jerry w
Happiest when people tell the truth... However, I am blessed with many friends.
Unread 11-01-2006, 09:19
pheNIX637 pheNIX637 is offline
None #0637
pheNIX637 will become famous soon enough
yea i think if you use an old PS from a computer it would work. but i think u have to get a paperclip and stick the end in to 2 sprocket on the main feed from the power supply .. you have to do this because then the power supply is "fooled" by saying that there is a motherboard in place but really there isnt.. just google search it.. you will find it.
Unread 11-01-2006, 09:56
BlazinFire47's Avatar
BlazinFire47 BlazinFire47 is offline
Alumni
AKA: Blaze/Blackmoon/Nova
FRC #0047 (Chief Delphi)
BlazinFire47 is on a distinguished road
Send a message via AIM to BlazinFire47 Send a message via MSN to BlazinFire47 Send a message via Yahoo to BlazinFire47
why not just use a 12 volt battery that you use on your robot to power it? it seems very easy to do to me. wire them all together, or on a disto-block, and put a switch on it somewhere and power it like that. itll be like wiring them to your car,pc, robot cart, or whatnot.
  #15   Spotlight this post!
Unread 11-01-2006, 10:08
Rick TYler Rick TYler is offline
A VEX GUy WIth A STicky SHift KEy
VRC #0010 (Exothermic Robotics)
Rick TYler has a reputation beyond reputeRick TYler has a reputation beyond reputeRick TYler has a reputation beyond reputeRick TYler has a reputation beyond reputeRick TYler has a reputation beyond reputeRick TYler has a reputation beyond reputeRick TYler has a reputation beyond reputeRick TYler has a reputation beyond reputeRick TYler has a reputation beyond reputeRick TYler has a reputation beyond reputeRick TYler has a reputation beyond repute
One of those jump-start batteries sold in auto parts store would work great, to, if you already have one. Many of them also have 120 VAC inverters built in, which could come in handy at the tournaments, too, especially if you want a stereo on your cart... (just don't bring a music cart to Portland, please).
Exothermic Robotics Club, Venturing Crew 2036
VRC 10A, 10B, 10D, 10Q, 10V, 10X, 10Z, and 575
TTL port to a serial port on a demo board ImmortalAres Programming 16 09-07-2005 23:44
How many users does it take to change a Light Bulb? Matt Attallah Chit-Chat 4 04-09-2004 20:59
program light blinks red and green JBabbie Programming 3 02-03-2004 09:19
Please...no more steenkin' light! Andrew General Forum 37 17-04-2003 23:06
Important info about light Jay Lundy Technical Discussion 10 12-04-2002 11:37
