Go to Post Comments and Documentation: Use them! You would never believe how fast you will forget how something works, especially when things are flying at you so fast. Other/future programmers will understand what you did and why you did it. - BigJ [more]
Unread 10-01-2006, 23:27
Andy A. Andy A. is offline
Getting old
FRC #0095
Team Role: Coach
Andy A. has a reputation beyond reputeAndy A. has a reputation beyond reputeAndy A. has a reputation beyond reputeAndy A. has a reputation beyond reputeAndy A. has a reputation beyond reputeAndy A. has a reputation beyond reputeAndy A. has a reputation beyond reputeAndy A. has a reputation beyond reputeAndy A. has a reputation beyond reputeAndy A. has a reputation beyond reputeAndy A. has a reputation beyond repute
Re: Best way to collect balls off the field?
Here's a hint
-Andy A.
Unread 11-01-2006, 00:19
Tatsu Tatsu is offline
Audiophile and Physicist.
AKA: Tatsu Hashimoto
FRC #1072 (Harker Robotics Team)
Team Role: Leadership
Tatsu will become famous soon enough
Send a message via AIM to Tatsu
http://www.golfmachinery.com/collectors.htm
This looks pretty good, size it up and I think it'll work for this year too..
Tatsu
Unread 11-01-2006, 00:24
Heretic121 Heretic121 is offline
The Resident Gamer -
AKA: Pat or Harry... if you ask its a long story...
FRC #0078 (AIR Strike)
Team Role: Tactician
Heretic121 has a reputation beyond reputeHeretic121 has a reputation beyond reputeHeretic121 has a reputation beyond reputeHeretic121 has a reputation beyond reputeHeretic121 has a reputation beyond reputeHeretic121 has a reputation beyond reputeHeretic121 has a reputation beyond reputeHeretic121 has a reputation beyond reputeHeretic121 has a reputation beyond reputeHeretic121 has a reputation beyond reputeHeretic121 has a reputation beyond repute
Send a message via AIM to Heretic121
Tatsu
aka i belive 126's 1992 bot...
2004 - Team 121 Human Player
2005 - Team 121 Student Captian
2006 - Team 38 Drive Team Coach / Mentor
2007 - 2009 - Team 121 Mentor / Strategery Master
2010 - 2013 - Team 78 Mentor / Strategy / Scouting Lead
2014 - Team 78 coach
Unread 12-01-2006, 09:17
sdcantrell56's Avatar
sdcantrell56 sdcantrell56 is offline
AKA: Sean
FRC #2415 (Wired Cats)
sdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond repute
I was actually thinking about a golf-ball styyle collector. However, I am worried that it might push the balls away instead of pick them up. Any ideas?
Unread 12-01-2006, 14:14
Taylor's Avatar
Taylor Taylor is offline
Professor of Thinkology, ThD
AKA: @taylorstem
FRC #3487 (EarthQuakers)
Team Role: Teacher
Was the large non-slip fabric sticky enough to sufficiently pick up the balls or did it have to pin the balls against a side wall to collect? Being a second-year team, we haven't seen a lot of robots in action, and the kids are worried that a conveyor system will bounce the balls away or they may get trapped and just spin on the ground.
Hi!
Unread 12-01-2006, 15:03
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
It is sufficient for the balls to get "pinned" against the carpet by such a collector.
Unread 12-01-2006, 22:01
AKA: Sean
So are you syaing it will pick the ball up with a conveyor or will it just spin. Also what did team 121 us for the rollers for the conveyor belts?
Unread 14-01-2006, 09:39
Stephen P's Avatar
Stephen P Stephen P is offline
Team Role: Mechanical
Stephen P has a spectacular aura aboutStephen P has a spectacular aura about
I had been thinking of this exact idea and had that exact worry, but this is reasuring. I think it would be best to have the roller clearance from ground adjustable to some degree as to "fine tune" the mechanism, to ensure the "pinnage".
You know you are an electrical engineer when you can determine voltage relative to pain with a 5% error.
Unread 12-01-2006, 15:06
Kelvin Ng Kelvin Ng is offline
None #1558 (ACCIDENT Robotics (Albert Campbell Collegiate Institute stuD)
Kelvin Ng is on a distinguished road
try testing with wood models. I haven't visited my school in ages, so all my tests have been conducted with lego.
2005 - Waterloo Regional Highest Rookie Seed
2005 - Theory6 (1241) Top Rookie 2005
Unread 12-01-2006, 14:17
Tom Bottiglieri Tom Bottiglieri is offline
FRC #0254 (The Cheesy Poofs)
Tom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond repute
Originally Posted by Don Rotolo
How about a belt along the bottom of the robot, as the center of the robot gets 'stuck' on the top edge of the ramp, just power up the belt and !zoom!.
Remember, the rules state your robot just needs to be off the carpet to score the bonus points. Whether or not you can get to the top of the ramp is totally up to you.
Unread 10-01-2006, 22:08
Masterfork's Avatar
Masterfork Masterfork is offline
Joshua Hunnings
AKA: Fork
FRC #0233 (the pink team)
Masterfork is a jewel in the roughMasterfork is a jewel in the roughMasterfork is a jewel in the rough
Send a message via AIM to Masterfork Send a message via MSN to Masterfork
Lightbulb best way to collect the balls
what do u think and why either wheels, tracks,ect. ect. and getting it up to the loader this should be intereting because many people think creatively and it is nice to see creativity even though ur team might not be using it on their robot what do u think
also another question "should u use a hopper of some sort also or not what other ways would u do to carry them or increase ur capacity"
and how to load them efficiently?
2007 World Championship Finalist thank you 71 and 179
2007 Archimedes undefeated Champions thanks 179 and 71
2007 Florida regional semifinalist thanks 180 and 1889
2007 Florida regional Spirit Award
2006 Archimedes Division Finalist
2006 Boston Champions
2005 UCF Regional champions thanks 1592 and 179
2005 Colorado Regional champions thanks 118 and 935
2005 Colorado Regional Chairmans Award
IRI 2005 - Champion thanks to 33 and 868 - it was a GREAT event
2005 World Championship - GM Industrial Design
Unread 10-01-2006, 22:43
Re: best way to collect the balls
For ball collection:
I've really been stuck on using vertically mounted belts to grab the balls off the ground and drop them off in a hopper. wheels with poles(or whatever you call them) protruding could probably work as well. I don't know how many people of thought of this, but a big shovel could also double as a ball collector and storage. It may even be able to drop balls off as well.
I believe that being able to score in the centre goal will give alliances the edge needed to win. Because of this, I was thinking of incorporating the ball storage with the mechanism that feeds the ball firing device.
Unread 10-01-2006, 22:50
Masterfork's Avatar
Joshua Hunnings
AKA: Fork
yes but feeding vertically also is feeding against gravity and it could slip on the balls surface. going up and cause some problems
Unread 10-01-2006, 23:10
Lil' Lavery Lil' Lavery is offline
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Lil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond repute
Send a message via AIM to Lil' Lavery
look at bots from 2002 and 2004, tons of good ideas
Being correct doesn't mean you don't have to explain yourself.
  #15   Spotlight this post!
Unread 10-01-2006, 23:14
Shu Song's Avatar
Shu Song Shu Song is offline
Melodious Footware
AKA: *Crash!* Shuuuuuuuuuuuu
FRC #0639 (Code Red Robotics)
Shu Song has much to be proud ofShu Song has much to be proud ofShu Song has much to be proud ofShu Song has much to be proud ofShu Song has much to be proud ofShu Song has much to be proud ofShu Song has much to be proud ofShu Song has much to be proud of
Send a message via AIM to Shu Song
A few bots to look at as a starting point are team 121 and 233's from 2002 and team 33's from 2004. All had amazingly efficient ball collection and release mechanisms.
Code Red Robotics - Team 639
Ithaca High School| Ithaca | New York | USA | Earth | Sol System | Milky Way | Universe | Some Alien's Locker
WINNER of the 2005 Finger Lakes Regional, thanks to teams 191 and 494.
WINNER of the 2004 Canadian Regional, thanks to teams 33 and 1112
WINNER of Delphi: Driving Tomorrow's Technology Award at the 2007 Finger Lakes Regional.
We can extend beyond the playing field with our ball-knocker-offer??? Natchez Rules/Strategy 35 19-03-2004 09:35
Small balls in 2001 competition archiver 2001 10 24-06-2002 03:59
Team 188 Pictures - four big balls anyone? archiver 2001 6 24-06-2002 01:03
Numbers for thought: Are 10 black balls worth 30 seconds? archiver 2001 6 23-06-2002 22:42
Just curious, how many robots could shoot or toss balls into the goal? Alan Ing General Forum 7 13-05-2002 19:09
