Go to Post Heck, every human being has the potential to change the world, as long as the world still exists. - [more]
Unread 09-01-2006, 18:28
Andrew Blair's Avatar
Andrew Blair Andrew Blair is offline
SAE Formula is FIRST with Gasoline.
FRC #0306 (CRT)
Andrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond repute
Send a message via AIM to Andrew Blair Send a message via Yahoo to Andrew Blair
Fly Wheel Moment Calc.
For quick reference, what are the equations for calculating the moment of a fly wheel? (A disk of mass, not just a weight on a stick, if that matters). I know that there are other things too, like bearing load/friction, drag, etc. Am I missing anything?
And how would I calculate the energy lost if I was to, say, use it to be momentarily loaded with a foam ball? (This may be too much for simple calculations, I'll guess and test if I have to.) Thanks!
Reading makes a full man, conference a ready man, and writing an exact man.
-Sir Francis Bacon
"Any intelligent fool can make things bigger, more complex, and more violent. It takes a touch of genius -- and a lot of courage -- to move in the opposite direction."
-Albert Einstein
Unread 10-01-2006, 09:15
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Rookie Year: 1998
Re: Fly Wheel Moment Calc.
here
Several things. Moment of a solid disk is 1/2*m*r^2. Moment of a solid ring is m*r^2. Energy loss is easy. Figure out how fast you want your ball to come out and you know its kinetic energy. It had to come from somewhere, right? I'd figure 50% efficiency transferring it from the wheel to the ball to be really safe. Kinetic energy of rotation is 1/2*I*omega^2 if you want to figure out how much your wheel slows down. (omega is rotational speed in rads/sec).
Finally, I've just uploaded a whitepaper that will calculate the time to spin up a flywheel based on the motor characteristics and flywheel dimensions. Check for it in a few hours.
EDIT: The white paper is
How did you control your Robot? 1? 2? Wheel? How? ChrisCook Control System 9 17-05-2005 21:41
Steering wheel issues jgannon Programming 5 15-12-2004 10:14
Clamping wheel hubs sanddrag Technical Discussion 7 29-02-2004 00:20
how can you use a gyro in autonomous mode magical hands Programming 3 02-01-2004 13:31
"Motors and Drive train edition" of Fresh From the Forum Ken Leung CD Forum Support 6 29-01-2002 12:32
