Go to Post Lengthy posts are not discarded ones. Information comes in all sizes - Garii [more]
Thread Tools Rating: Thread Rating: 4 votes, 5.00 average. Display Modes
Unread 10-01-2006, 14:38
bcharbonneau bcharbonneau is offline
None #1296 (Full Metal Jackets)
Team Role: Teacher
bcharbonneau is an unknown quantity at this point
Default Code to Easy C
Does anyone know how to load the Default FRC code into EasyC? I just downloaded the software and obviously haven't read all the documentation yet.
Thanks,
Team 1296
Unread 10-01-2006, 14:50
Kingofl337's Avatar
Kingofl337 Kingofl337 is offline
You didn't see anything....
AKA: Adam
FRC #0501 (Power Knights)
Rookie Year: 1998
Kingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond repute
Send a message via Yahoo to Kingofl337
Re: Default Code to Easy C
EasyC allows you to create your own default code. Because easyC is so simple, there was no reason to provide a generic template like the default code. Once you become familiar with the software you will see that it is easier to write your own arcade or tank style drive program (two easyC blocks, a While Loop and RC block) then to edit one we provide, or rewire your robot to match our default settings.
You can still load the FRC default code into the robot from easyC. This option can be found in the 'Build & Download' menu under 'Download default Code'.
Take a look at the "Getting Started" Section in the help file. You can find samples of all the 'finished' code from each tutorial chapter in the tutorial folder in easyC.
Unread 13-06-2011, 22:39
ahwei ahwei is offline
ahwei is an unknown quantity at this point
I wanted to view on the coding of the default code. How can i do so? i need them for some educational purposes. If you have them can you send me? Please send them to this email ahwei093611k@hotmail.com
Unread 14-06-2011, 01:31
ok i figured it myself alrdy...
Out of the Box Camera Code russell Programming 9 21-10-2009 05:28
Best Way To Insert Autonomous Code Into Default then load help.? :-)? gemccnp Programming 2 05-02-2005 18:58
default code vs. 2.4 stephenthe1 Programming 2 05-02-2005 18:02
Team THRUST - Kevin's Code and Camera Code Combine Chris_Elston Programming 3 31-01-2005 22:28
heres the code. y this not working omega Programming 16 31-03-2004 15:18
