Go to Post I personally need all the limbs and eyeballs I currently have, and I assume other feel the same way. - bfk [more]
Unread 10-01-2006, 21:36
Stephen.Yanczura's Avatar
Stephen.Yanczura Stephen.Yanczura is offline
opportunist
FRC #0195 (Cyberknights)
Stephen.Yanczura is a name known to allStephen.Yanczura is a name known to allStephen.Yanczura is a name known to allStephen.Yanczura is a name known to allStephen.Yanczura is a name known to allStephen.Yanczura is a name known to all
Re: Anyone thinking NERF ball turret
What I ment about no open systems, was that you cannot design the air system just to dump to the atmosphere such as an air cannon design. Now that was my belief but upon scaning the rules I found nothing to back that up. So perhaps that is not the case. Would anyone like to offer input on that?
Unread 12-01-2006, 15:04
Taylor's Avatar
Taylor Taylor is offline
Professor of Thinkology, ThD
AKA: @taylorstem
FRC #3487 (EarthQuakers)
Team Role: Teacher
At the kickoff they spent an awful lot of time talking about the softball launcher - surely they wouldn't have been misleading us would they?
Are softball launchers compatible with a tube? Would it improve accuracy or put sidespin on the ball, forcing it to hook or slice?
And I know you're not Shirley.
Hi!
Unread 12-01-2006, 15:24
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
They wouldn't intentionally provide misleading information in the official presentation of the game. However, the game with the rocking ramp (Diabolical Dynamics?) was won using a scheme which ignored the example of a single robot balancing on the ramp while holding on to one goal at each side. The teams who followed that example lost the opportunity to have all four robots score bonus points at the end of the match.
So consider well your options. A spinning-wheel ball launcher is an obvious choice, but it might not be the winning one.
Unread 14-01-2006, 21:20
Leo 1529's Avatar
Leo 1529 Leo 1529 is offline
uber fabricata, webmasta, president
AKA: Tzu-san
FRC #1529 (Cyber-Cards)
Team Role: Webmaster
Leo 1529 has a spectacular aura aboutLeo 1529 has a spectacular aura aboutLeo 1529 has a spectacular aura about
yeah i thought that a spinning-wheel launcher would be a real common feature on most of the robots. I dont know if we are still considering even using a cannon or pitching machine on our robot
Unread 14-01-2006, 22:09
Jonathan Norris Jonathan Norris is offline
Jno
FRC #0610 (Crescent Robotics)
Jonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond repute
Surprisingly the cannon extension will not provide as much accuracy as you may think. At least that is what we found from our prototyping.
Co-Founder of Taplytics.com
2013 World Champions (1241, 1477, 610)
Crescent Robotics Team 610 Mentor
K-Botics Team 2809 Founding Mentor ('09-'11)
Queen's University Mechanical Engineering, Applied Science '11
Crescent Robotics Team 610 Alumni
Unread 10-01-2006, 19:48
DonRotolo's Avatar
Back to humble
FRC #0832
Originally Posted by dlavery
Before you spend too much time on this idea, try this simple test: put your mouth on the ball, making a reasonably tight seal against the surface, and blow. Surprising, isn't it?
-dave
I can't get my mouth to fit around the 7" ball.
But, I think your point is, if the ball has a tight seal and is restricted from moving until the pressure builds sufficiently*, then some surprising force can be generated.
*Sufficient = you do the math
Don
Unread 14-01-2006, 22:49
TEAM456MS TEAM456MS is offline
FRC #0456
Team Role: Leadership
TEAM456MS is an unknown quantity at this point
You could use a spring then pull back a plate inside the turret with a winch. It would be semi simple design that would follow regulations.
Unread 15-01-2006, 11:52
EricRobodox's Avatar
EricRobodox EricRobodox is offline
AKA: Eric... I think a lot
FRC #0599 (RoboDox)
EricRobodox has a brilliant futureEricRobodox has a brilliant futureEricRobodox has a brilliant futureEricRobodox has a brilliant futureEricRobodox has a brilliant futureEricRobodox has a brilliant futureEricRobodox has a brilliant futureEricRobodox has a brilliant futureEricRobodox has a brilliant futureEricRobodox has a brilliant futureEricRobodox has a brilliant future
Send a message via AIM to EricRobodox
What i have figured out, there are only 4 plausible ways of firing a ball.
1. Single wheel shot (pitching machine on kickoff video)
2. Multiple wheel shot (more advanced pitching maching, look at a batting cage)
3. Catipult
4. Pneumatic piston/spring shot (both similar in a platform pushing the ball out)
Unread 15-01-2006, 12:21
Andrew Blair's Avatar
Andrew Blair Andrew Blair is offline
SAE Formula is FIRST with Gasoline.
FRC #0306 (CRT)
Andrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond repute
Send a message via AIM to Andrew Blair Send a message via Yahoo to Andrew Blair
Don't forget "Flywheel to linear transition" thrower"...
Reading makes a full man, conference a ready man, and writing an exact man.
-Sir Francis Bacon
"Any intelligent fool can make things bigger, more complex, and more violent. It takes a touch of genius -- and a lot of courage -- to move in the opposite direction."
-Albert Einstein
Unread 15-01-2006, 16:05
FRC #0599 (RoboDox)
Can you show me an example. i can up with this basic list in like 2 min, so i want to know what the fly wheel to a linear transition is?
Unread 15-01-2006, 16:45
Ianworld's Avatar
Ianworld Ianworld is offline
AKA Ian Ferguson
AKA: Ian Ferguson
FRC #0694 (StuyPulse)
Ianworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud of
Send a message via AIM to Ianworld
I'm not sure if this is what Blair was going for but this is what i'm envisioning. First place a ball on a cart like object that can carry the ball and make it travel on a short track. Then take a flywheel and bring it into contact with the cart to accelerate it. the cart should travel until it hits a stopper making it stop and any ball on it flying off. It seems like a nice compromise between a flywheel and some other sort cannon mechanism. You get consistency because you're always shooting the same cart object, but it isn't quite as fast and quickly repeatable as a straight flywheel. If you springload the cart so that it automatically comes back you wouldn't have to devote another motor the cart mechanism.
Team Website
Unread 15-01-2006, 16:51
FRC #0599 (RoboDox)
that still is categorized in the one wheel system, its just a small modification.
Unread 15-01-2006, 17:06
FRC #0306 (CRT)
Eh, something like like. Your's is better. There was a thread on here before about converting rotational into linear motion. That was what I referring to. But it seems rather feasible. The other option is to have a flywheel somehow coupled to a rod so that you can throw the rod forward. Rod hits ball, ball goes out.
-Sir Francis Bacon
-Albert Einstein
Unread 15-01-2006, 21:34
greencactus3 greencactus3 is offline
occra 23.
AKA: ryo
None #1481
greencactus3 is a name known to allgreencactus3 is a name known to allgreencactus3 is a name known to allgreencactus3 is a name known to allgreencactus3 is a name known to allgreencactus3 is a name known to all
Send a message via AIM to greencactus3 Send a message via MSN to greencactus3
think crankshaft or camshafts too
also how about gravity fed trbuchet style or bow and string mangonels. crossbowish stuff.
so basically simply put the list gets to be
angular kinetic energy (flywheels and the such)
gravitational potential energy (obvious)
elastic potential energy (bows. cross bows. springs. bungees)
compressed gas
electrical(as in motors so i guess this is kinda angular kinetic)
mind power(technically unless you need to send radio waves from your head you dont even need to have the driver do this. someone in the stands can do this.. and even shoot down opponent's shots. but maybe violates GP? i unno
some sort of chemical reaction or sumthing. probably not legal
  #15   Spotlight this post!
Unread 15-01-2006, 21:40
FRC #0599 (RoboDox)
that was like the post of the day for me. ahahahaha. Like Wonderboy, mind bullets. (Tenacious D reference for all you newbs)
Experimental Ball Drive Sepsis900 Technical Discussion 16 31-10-2005 16:59
Ball Shooter Squall Rules/Strategy 7 11-01-2005 14:47
Lip at ball chute opening Doug Traster Rules/Strategy 1 19-01-2004 01:33
2004 Game BBFIRSTCHICK General Forum 112 19-04-2003 17:12
Curie Division Robots information... (not complete) archiver 2001 3 24-06-2002 03:13
