Go to Post Dear Mr. Lavery, Congratulations. For the fourth year running, you have successfully ruined my Christmas holiday with your untimely release of a most obfuscating, but no less tantalizing, hint. - dubious elise [more]
Unread 14-01-2006, 23:17
pez1959's Avatar
pez1959 pez1959 is offline
Cap'n Patty
AKA: Patrick
FRC #1959 (Aye Aye Robot)
pez1959 is on a distinguished road
Send a message via AIM to pez1959 Send a message via MSN to pez1959 Send a message via Yahoo to pez1959
Re: 2006 Autonomous Disappointment
Now, I have a question.
We're a rookie team this year and we probably won't use the camera as our programmers are very green and a launching mechanism is beyond the scope of our mechanical team. What are other options for the autonomous period? I have heard suggestions about a spiraling drive pattern, just to bump into other bots to screw them up. Would that be effective? or would the bumpings be inconsequential?
Thanks
Unread 14-01-2006, 23:21
devicenull devicenull is offline
Robot? We need a robot?
Rookie Year: 1234
devicenull is just really nicedevicenull is just really nicedevicenull is just really nicedevicenull is just really nicedevicenull is just really nice
Thanks
As far as the camera goes, it's quite possible they could get it working.. out of the box the code will search for and lock onto a target
If you drive around randomly in auto. with the intent of running into other robots, I would worry about damage to your robot or someone elses. (Although we had our robot run full speed across the field last year, and right into the other wall) But I don't think driving around like that would do much..
Unread 14-01-2006, 23:41
pez1959's Avatar
Cap'n Patty
AKA: Patrick
Well I know that there are specific rules about ramming, but as far as the robot goes, I think we are pretty sure that we are going to ignore the top goals and just go for the sides. However, we aren't looking at a "garbage-can-dump-bot" like in the game animation, so the auton period seems useless to us.
Basically we decided to learn the CMU cam during the off season and get familiar with it to prepare for next year's competition.
Unread 14-01-2006, 23:55
KenWittlief KenWittlief is offline
KenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond repute
We're a rookie team this year and we probably won't use the camera ...
Thanks
the problem with just driving around is you may drive into your own alliance partner, who is trying to score ten balls in the center goal.
If nothing else, try for a dead reckoning approach to blocking your opponents goal, ie: drive forward two seconds, turn left for 1/2 second, drive forward for 2 seconds - see where your robot ends up, then tweak the timing to get the robot more or less where you want it on the field. then have it just sit there
or you could take the same approach and try to score one or two balls in the side goals. Even one point can be the difference between winning auton mode, if your alliance partners can score points as well
who knows, you might have matches in which none of your opponents can score any points in auton. Then one point would be all you need!
Unread 15-01-2006, 14:56
Joe Hershberger Joe Hershberger is offline
National Instruments
AKA: jhersh
FRC #2468 (Appreciate)
Rookie Year: 1997
Joe Hershberger is a name known to allJoe Hershberger is a name known to allJoe Hershberger is a name known to allJoe Hershberger is a name known to allJoe Hershberger is a name known to allJoe Hershberger is a name known to all
Just to clarify, dead reckoning is not the practice of turning on a motor for a given time. That is just a pre-timed sequence.
Dead reckoning is using sensors on your robot to figure out its speed and direction and integrating to maintain an approximate location and heading. This is a widely misused term in FIRST... I'm not sure why.
See wikipedia.
Cheers!
-Joe
Unread 15-01-2006, 16:19
Matt Krass's Avatar
Matt Krass Matt Krass is offline
"Old" and Cranky. Get off my lawn!
AKA: Dark Ages
FRC #0263 (Sachem Aftershock)
Matt Krass has a reputation beyond reputeMatt Krass has a reputation beyond reputeMatt Krass has a reputation beyond reputeMatt Krass has a reputation beyond reputeMatt Krass has a reputation beyond reputeMatt Krass has a reputation beyond reputeMatt Krass has a reputation beyond reputeMatt Krass has a reputation beyond reputeMatt Krass has a reputation beyond reputeMatt Krass has a reputation beyond reputeMatt Krass has a reputation beyond repute
Send a message via AIM to Matt Krass
See wikipedia.
Cheers!
-Joe
I was under the impression dead reckoning was running without feedback, such as sensors, and just blindly driving, whether based on timers or loop counts or just setting your motors to a wide turn and leaving it.
"dead reckoning
n 1: an estimate based on little or no information [syn: guess,
guesswork, guessing, shot]
2: navigation without the aid of celestial observations"
http://dict.die.net/dead%20reckoning/ google turned this up, not sure of the validity, so I'm not really sure. Anybody have any other sources?
Matt Krass
If I suggest something to try and fix a problem, and you don't understand what I mean, please PM me!
I'm a FIRST relic of sorts, I remember when we used PBASIC and we got CH Flightsticks in the KoP. In my day we didn't have motorized carts, we pushed our robots uphill, both ways! (Houston 2003!)
Unread 15-01-2006, 17:04
Ryan M. Ryan M. is offline
Programming User
FRC #1317 (Digital Fusion)
Ryan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud of
Many of the LEGO Mindstorms books I have read refer to rotation sensors/encoders as a form of dead reckoning. The way I would define it would be anything which is based off of assumptions on how you started. (IE, you have to be in a certain spot and track yourself the entire time.) Basically, "I reckin' I'm right about thar."
Unread 20-01-2006, 09:27
pclements's Avatar
pclements pclements is offline
AKA: Patrick
FRC #1254 (Entropy)
pclements is an unknown quantity at this point
Send a message via Yahoo to pclements
Cool Re: 2006 Autonomous Disappointment
Originally Posted by TimCraig
I'm sort of disappointed that the autonomous phase was cut to only 10 seconds this year. Finally, we get a processor that's reasonably capable, we've had a couple of years to develop some experience with the PIC processors, and instead of increasing the time so we can really show off, we get our time cut. Programming the autonomous phase is one of the more difficult and time consuming parts of robot development, I think cutting back the time seems to denegrate its importance. I was hoping for at least 20 seconds if not 30.
Well, Look on the bright side, you can program the robot and have it go streight, with any luck it might even be able to soot in the hoop, ah heck, what am i thinking, thats bull only giving us 10 seconds, and my freind says hi, an you can use the autonomous mode next year .
2006 game poll #3 (mor or less emphasis on autonomous) dhitchco Rumor Mill 3 19-11-2005 19:45
2006 game poll #4 (type of "sensing" in autonomous mode) dhitchco Rumor Mill 1 18-11-2005 12:27
A Warning to Human Players During Autonomous The Lucas General Forum 21 07-04-2005 02:29
