Go to Post it's flattering, but a little scary, because I don't know if I'm ready to be an inspiration! - MissInformation [more]
Unread 12-01-2006, 13:01
red_alert_13 red_alert_13 is offline
AKA: Patrick Frampton
no team (Red Alert)
red_alert_13 is an unknown quantity at this point
Help: IFI loader not communicating with control unit
We are trying to hook up our robot controller to our computer to test the motors. We connected the two with a serial cable (the end connected to the robot controller went to the program port), and pressed the PROG button until the Program State light was a solid yellow. We ran the IFI loader program, and pointed it to the default .hex file supplied in the 2006 source code. When we clicked the download button it displayed a message stating: "Port failed to open". We tried with all 12 possible ports, none gave any other answer. We also tried using EasyC to download an unchanged project .hex file using the in-program download utility. This time, with port 2, it displayed the download progress bar, and at some point said that port 2 was open. However, after a few seconds, it stopped and told us to check to make sure that the serial cable was connected (which it was) and that the robot controller was on (which it was). We are out of ideas. Any suggestions would be helpful. This is our first year in competition, and we have NEVER used this software before. Thanks in advance!
Concept of PID explained ConKbot of Doom Technical Discussion 11 27-01-2008 00:11
IFI Loader Reloaded sciguy125 Programming 26 07-08-2007 00:07
IFI Loader and PROG button Dave... Programming 3 20-02-2005 12:03
IFI Loader Doc's Raven_Writer Programming 0 21-01-2004 17:53
Bug in IFI Loader rwaliany Programming 2 06-01-2004 21:26
