Go to Post If you plan the work and work the plan, you will very likely make it to the district championship. - IKE [more]
Unread 12-01-2006, 18:58
Mike's Avatar
Mike Mike is offline
has common ground with Matt Krass
AKA: Mike Sorrenti
FRC #0237 (Sie-H2O-Bots (See-Hoe-Bots) [T.R.I.B.E.])
Mike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond repute
Power Distribution Block - Green Light
We're trying to assemble the green light, but can't find the power splitter (the thing that the transformers connect to, not sure if I'm using the right name.) What is it listed as in the KOP? Was it even provided in the KOP? If not, what are we supposed to make?
Thanks,
-Mike
http://www.mikesorrenti.com/
Unread 12-01-2006, 19:08
DarMagi DarMagi is offline
DarMagi will become famous soon enoughDarMagi will become famous soon enough
Exclamation Re: Power Distribution Block - Green Light
It seems that the paper implies you need to supply your own 12 volt souce and a 2 amp recommended fuse that is as close to the power source as possible. That is the paper that was included with the cathodes. If you need I'll type the entire message and give it to you through email, just let me =]
Thanks,
-Mike
Unread 12-01-2006, 19:20
Mike's Avatar
AKA: Mike Sorrenti
Yeah, we read that paper. However, the lights plug into a transformer that needs to be plugged into twelve volts. As I understand it, there should be an AC adapter which takes 120vac from the wall and splits it into 4 seperate female connectors (one for each transformer) each at 12vdc.
Thanks for the help anyways
-Mike
Unread 12-01-2006, 19:25
BrianBSL BrianBSL is offline
FRC #0190
Rookie Year: 2000
BrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud of
-Mike
I think you are on your own as far as the 12V source. Just run them off the robot battery if you don't have a supply capable of running the lights.
My posts represent my personal views only, and do not represent the views of either my team, Team 190, nor its primary sponsor, Worcester Polytechnic Institute.
Unread 12-01-2006, 19:30
Mike AA's Avatar
Mike AA Mike AA is offline
Programmer and Mentor
AKA: Mike Aalderink
FRC #3458 (Code Blue)
Rookie Year: 1999
Mike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to behold
Send a message via MSN to Mike AA
-Mike
The connectors are connected to a few inches, close to a foot of red and black wire, there are 4 of these. You will need to supply your own 12 volt supply and fuse and connect to the little connector cables.
-Mike
Unread 12-01-2006, 21:08
MustangRobotics's Avatar
MustangRobotics MustangRobotics is offline
FRC #1281
MustangRobotics is an unknown quantity at this point
The supplied robot battery works nicely with the cathodes.
Unread 12-01-2006, 21:31
mechanicalbrain's Avatar
mechanicalbrain mechanicalbrain is offline
The red haired Dremel gnome!
FRC #0623 (Ohm robotics)
Team Role: Electrical
mechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond repute
Send a message via AIM to mechanicalbrain Send a message via Yahoo to mechanicalbrain
Or a hacked computer power supply. Seriously, well worth doing.
"Oh my God! There's an axe in my head."
623's 2006 home page
random mechanicalbrain slogans
Unread 12-01-2006, 21:39
DonRotolo's Avatar
Back to humble
FRC #0832
I don't see it that way.
We just connected all four red wires, and another red wire (that goes to the battery) together and soldered them, same for the black wires, we will put a 2A fuse in there tomorrow, and just hooked it up to a battery from last year.
I don't see anything that implies a power supply was provided.
Be careful, a switched power supply (as used by a computer) needsa decent load on the main voltage output (which is the +5 V supply) in order to regulate properly. Just putting a few hundred milliamps on the +12 output is inviting catastrophe*.
Don
* An award featuring the hindquarters of a feline.
Unread 12-01-2006, 21:59
Mike's Avatar
AKA: Mike Sorrenti
Alright, well I ended up getting it to work. I used some wire nuts to connect all the positive and negative wires and then connected it to a Radioshack Adapt-A-Plug AC adapter.
Thanks for the help
Green Light Power Source BobC Kit & Additional Hardware 19 20-01-2006 14:44
How many users does it take to change a Light Bulb? Matt Attallah Chit-Chat 4 04-09-2004 20:59
Stinger Fuse Block and Power Distribution Block Don Wright Electrical 2 30-03-2004 10:45
Using ground stem for power distribution steven114 Electrical 9 23-02-2004 11:40
Power Distribution Block DukesElectrical General Forum 0 09-02-2004 23:48
