Go to Post Don't like the predictions? Go out there and prove me wrong! - Looking Forward [more]
Unread 12-01-2006, 20:56
railerobotics's Avatar
railerobotics railerobotics is offline
FRC #0935
railerobotics will become famous soon enough
Can't find CMUCam2 demo.llb
We cannot find CMUCam2 demo.llb like mentioned in the camara workbook. Do we download it or is it somewhere else? Please help us.
Unread 12-01-2006, 21:23
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Re: Can't find CMUCam2 demo.llb
I think http://www.chiefdelphi.com/forums/fo...play.php?f=149 might help you find what you're looking for.
Unread 13-01-2006, 13:51
FRC #0935
No, we have already looked there. Where do we download the CMUCam2 demo.llb application used in Lab View 8.0 like mentioned in the camara workbook? We have searched and searched on the web but have failed miserably. Did this application come in the kit?
Unread 13-01-2006, 13:56
pbrules15 pbrules15 is offline
AKA: Ronny
pbrules15 is an unknown quantity at this point
WHERE IS IT?????????????????????????
Unread 13-01-2006, 14:25
fowlerm's Avatar
fowlerm fowlerm is offline
Bringing .NET to Robots
AKA: Matthew Fowler
FRC #0312 (Heatwave); FRC #1369 (Minotaur)
fowlerm has a spectacular aura aboutfowlerm has a spectacular aura aboutfowlerm has a spectacular aura about
You can get it here. The password to extract the contents of the zip file is "LVFRC2006!" case sensitive and without the quotes.
Unread 13-01-2006, 14:56
Danny Diaz's Avatar
Danny Diaz Danny Diaz is offline
Smooth Operator
AKA: FrankenMentor
None #0418
Danny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond repute
Send a message via AIM to Danny Diaz
Be careful about posting exact links to this file, the filename and/or location can change, it is best to look here:
http://www.chiefdelphi.com/forums/f...splay.php?f=149
The sticky post will always point to the correct link. Also note that now the files are not password-protected.
-Danny
Danny Diaz
Former Lead Technical Mentor, FRC 418
Unread 13-01-2006, 16:41
FRC #0935
Thanks
Unread 13-01-2006, 16:56
FRC #0935
Now that we have the application and have it on the computer in lab view, we cannot get it to run. I click the little arrow and a little error window pops up and says something like that we need to check our serial port or see if the camara has power. The serial port is fine, we spent hours checking it. And the camara has power. WHATS WRONG??? Please help us.
Unread 13-01-2006, 17:43
Danny Diaz's Avatar
Smooth Operator
AKA: FrankenMentor
None #0418
Originally Posted by railerobotics
WHATS WRONG???
Could be a number of things.
1. Make sure the backup battery is FULLY CHARGED.
2. Make sure you've installed the latest version of the NI-VISA software in your computer.
3. Make sure you've configured your serial port to the correct speed via Measurement and Automation Explorer.
4. Make sure the serial port specified in the application is the correct serial port the serial cable is plugged into.
5. Make sure the backup battery is FULLY CHARGED.
6. Make sure you've read the documentation provided with the Camera App.
7. Make sure your serial cable is good.
8. Make sure the camera is correctly set up and everything is plugged in snugly (especially the lens daughterboard).
And above all, make sure your backup battery is fully charged.
-Danny
Danny Diaz
Unread 13-01-2006, 18:12
FRC #0935
thanks, it now works. The file we were missing mi-visa was in the documention of the frc camara.
Unread 13-01-2006, 18:17
FRC #0935
You said, "If you use easyC for FRC the camera values for the target are preloaded in the software. If you upload Tutorial #7 to your robot it should folow the target." Where is "Tutorial #7"?
Unread 15-01-2006, 14:08
Chris_Elston's Avatar
Chris_Elston Chris_Elston is offline
Controls Engineer
AKA: chakorules
FRC #1501 (Team THRUST)
Chris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond repute
-Danny
I am sorry, but this hits HOME for us...I dunno how many times the camera stopped working only to find out the backup battery was dead or not charged. Only a week into this, and this is an inside joke for our team....
Backup battery charged? CHECK!
Team T.H.R.U.S.T. 1501
Download all of our past robot's source code here:Repository
Favorite CD quote:
"That can't be their 'bot. not nearly enough (if any) rivets to be a 1501 machine." ~RogerR: Team #1369
Kingofl337's Avatar
Kingofl337 Kingofl337 is offline
You didn't see anything....
AKA: Adam
FRC #0501 (Power Knights)
Rookie Year: 1998
Kingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond repute
Send a message via Yahoo to Kingofl337
Example LabVIEW Apps - Dashboard, CMUcam2 and Motors Russ Beavis National Instruments LabVIEW and Data Acquisition 9 21-01-2007 17:19
CMUcam2 disclaimer Cody Carey General Forum 4 12-01-2006 01:19
CMUcam2 interfacing Kram Programming 2 27-05-2005 07:17
CMUCam2 Camera Code - Are important parts commented out? Mr. Lim Programming 4 14-01-2005 12:11
3dmax - setting a display option that I can't find DanL 3D Animation and Competition 5 05-01-2003 12:42
