Go to Post As my daughter said, you used to shut up your robot and send it away from home. Now you just suffocate it. - GaryVoshol [more]
View Poll Results: How important is it to collect loose balls from the playing surface?
Not important -- clearly irrelevant 5 4.20%
Somewhat important 25 21.01%
Very important 46 38.66%
Critical factor -- you have to be able to collect loose balls 36 30.25%
What? I thought this was about tetras? 7 5.88%
Voters: 119. You may not vote on this poll
  #16   Spotlight this post!
Unread 17-01-2006, 19:46
KenWittlief KenWittlief is offline
KenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond repute
Re: Loose Balls
you dont need to pick them up to push them in the corner goals, right?
  #17   Spotlight this post!
Unread 17-01-2006, 19:52
EricH's Avatar
EricH EricH is online now
New year, new team
FRC #1197 (Torbots)
Re: Loose Balls
Right. Just like you didn't in 2004. Just push, shove, or maybe even pick up so you can dump a wall in when you load the goals. Your choice.
Past teams:
2003-2007: FRC0330 BeachBots
2008: FRC1135 Shmoebotics
  #18   Spotlight this post!
Unread 17-01-2006, 19:57
Andrew Blair's Avatar
Andrew Blair Andrew Blair is offline
SAE Formula is FIRST with Gasoline.
FRC #0306 (CRT)
Andrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond repute
Send a message via AIM to Andrew Blair Send a message via Yahoo to Andrew Blair
Re: Loose Balls
Yep, but Aim High is a bit different than 2004. The dillema is that if you score in the corner goals now, your opposition gets the balls. So, not only do you get two less points (Potentially), but you give a scoring opportunity to the other team, versus just leaving them on the field, or picking them up and keeping them. But 1 point is better than none, right!
Reading makes a full man, conference a ready man, and writing an exact man.
-Sir Francis Bacon
"Any intelligent fool can make things bigger, more complex, and more violent. It takes a touch of genius -- and a lot of courage -- to move in the opposite direction."
-Albert Einstein
  #19   Spotlight this post!
Unread 17-01-2006, 20:14
santosh's Avatar
santosh santosh is offline
AKA: 2415
FRC #2415
santosh has a reputation beyond reputesantosh has a reputation beyond reputesantosh has a reputation beyond reputesantosh has a reputation beyond reputesantosh has a reputation beyond reputesantosh has a reputation beyond reputesantosh has a reputation beyond reputesantosh has a reputation beyond reputesantosh has a reputation beyond reputesantosh has a reputation beyond reputesantosh has a reputation beyond repute
Send a message via AIM to santosh
Re: Loose Balls
I think it will be vry important. Although you can load by the human player, I think there will be a ton of balls on the floor from missed shots, which I think there will be a lot of. Also when the human players try to load the balls into their bots, I think it may be more difficult thn most people expect.
Originally Posted by Alekat
I(as human player) plan on spending most of my time scoring points, not loading my robot. They can pick up my missed points and shoot them.
Also, if you are the human player and you are trying to score, imagine how hard that would be. first off, you have to get it in a corner goal 50 ft away . 50 feet isnt too bad, but your sight will be obstructed at most times in my opinion. Also there will be tons of bots bloking the goal. Not to mention the cfact that the goals ar elike 10" tall and the ball is 7". Not an amazing amount of tolerance on your shots there
2004 - 2007 = 1002
2007 - 2011 = Founding Mentor of 2415
6 regional wins, 3 EIs, 3 Chairmans
kiddies kiddies kiddies
  #20   Spotlight this post!
Unread 17-01-2006, 23:52
Lil' Lavery Lil' Lavery is offline
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Lil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond repute
Send a message via AIM to Lil' Lavery
Re: Loose Balls
Let's take a look at this problem from the very beginning of the match. Each alliance gets 40 balls to dispose of at their will (10+ MUST be at HP station though).
In a perfect world, all 3 robots could hit 3 pointers, and hit every 3 pointer they made (and every HP would get their ball into the robot every time). Therefore, no ball would ever end up on the field.
But this isn't a perfect world, there will be error. And seeing as you should always assume the worst when preparing strategy, we'll pretend that your alliance isnt perfect, but by some fluke you end up against 254, 71, and 233 (or some other "perfect alliance"). You will NOT be hitting 100% of your shots into the center goal, while they will. Therefore, if you cannot pick up your missed shots, a few options (and their results) appear:
a)push them into the "your" corner goal. Because the opposing alliance is hitting 100% of their shots, when their HP re-introduces the ball, it will be scored for 3 points, while the corner goal only gave you 1.
Net Result: -2 points
b)Leave them on the floor. Now we reach the point where we look at the opposing alliance's robot capabilities once again. In a "perfect alliance" all 3 robots would be able to load balls from both the HP and the ground. Therefore the opposing robots would gather the balls and shoot them for 3 points.
(In a non-perfect world, an alliance may lack the capability of loading balls, and would leave them in the exact same predicament as you for point swings per ball and how to distribute it, making this a very viable solution to leave the balls on the field in those matches)
Net Result: -3 points
c)push the balls into "their" corner goal (the one with your HPs). This will score 1 point for the opposing alliance, but give YOUR HP control of the ball, which, in the best case can result in a 3 point score for you (not counting the minimum of 1 point cost to grant the ball to your HP, and the amount of field movement time to get from your HP station to your effective firing range). But, for every shot you miss with that ball before you hit the shot, its a loss of 1 point that is not counter-acted in any way.
Net result: +2 (AT BEST)
Therefore, only one real reaction can give you ANY positive points from leaving balls on the field, and even then, not as much as the 3 point shot scored without missing by the opposing alliance. So, let's pretend that both alliances shoot 100 shots per match. If you miss even one shot, and you react in the fashion that will give you the greatest net gain, your score will be 300, and theirs (because of the 1 point you scored for them) will be 301.
Okay, let's interject a bit of reality to the opposing alliance. They will be missing shots too (or so everyone hopes...), or your defense should hopefully be able to force them to. Now the amount of balls on the field is far greater, and the action of the balls will have a far greater swing on the outcome of the match. For every ball they are allowed to introduce straight to the robot, they save the mandatory point cost of having their HP aquire the ball, and save the possible time of having to most to a range where the HP can shoot it (depending on the design and capabilities of the HP).
Beyond even all the net gains of each ball that is missed, there is the whole concept of ball "hoarding" when you have the lead.
Being correct doesn't mean you don't have to explain yourself.
  #21   Spotlight this post!
Unread 18-01-2006, 10:13
Taylor's Avatar
Taylor Taylor is offline
Professor of Thinkology, ThD
AKA: @taylorstem
FRC #3487 (EarthQuakers)
Team Role: Teacher
Re: Loose Balls
In reading the posts on this thread, it seems to me that most people think the only way HPs can get balls is from the corner goals. Keep in mind the center goals will be feeding back to the HPs as well, so as long as your team is scoring, the other side will never be starved.
New and interesting strategy: build up a ton of points at autonomous mode, get the early lead, stock up on balls and play pre-shot-clock-era basketball where you just hold them until the absolute end of the match. If this means scoring for your opponents, as long as you've got the lead, that's OK. Offense wins games, defense wins championships. Yeah, your RP will be hurt because by design the games would be low-scoring, but if you've got all Ws, who cares?
One more thought: you don't have to have a ball in your hopper (or magazine or whatever) to have control of it - it could be in your alliance station, or you could simply corral the balls in a corner, have 1 or 2 bots in that corner making a fence and defending the balls from the opposition.
So for this strategy, loose ball manipulation would be critical.
Hi!
  #22   Spotlight this post!
Unread 18-01-2006, 10:37
Rick TYler Rick TYler is offline
A VEX GUy WIth A STicky SHift KEy
VRC #0010 (Exothermic Robotics)
Rick TYler has a reputation beyond reputeRick TYler has a reputation beyond reputeRick TYler has a reputation beyond reputeRick TYler has a reputation beyond reputeRick TYler has a reputation beyond reputeRick TYler has a reputation beyond reputeRick TYler has a reputation beyond reputeRick TYler has a reputation beyond reputeRick TYler has a reputation beyond reputeRick TYler has a reputation beyond reputeRick TYler has a reputation beyond repute
Re: Loose Balls
We war-gamed this strategy, and it works well, especially if you have a mixed team with a good shooter and a good defense bot. We hypothesized a robot with an amazing ball sucker, a big hopper, and a powerful 2-speed drive train following the suck-and-dump-once-at-the-end strategy. It worked really well, especially if the sucker could transfer balls to the shooter (a ball ejector on the top that could drop balls into a top-mounted hopper on the shooter). Regardless of the quality of the strategy, our students thought that this 'bot would be boring to build and went with a shooting strategy instead. I know of at least one old 3-digit team that is building a bot like this, and is even giving up ramp-climbing to focus on ball-hoarding.
Exothermic Robotics Club, Venturing Crew 2036
VRC 10A, 10B, 10D, 10Q, 10V, 10X, 10Z, and 575
  #23   Spotlight this post!
Unread 18-01-2006, 14:18
insub2 insub2 is offline
None #1227
insub2 is an unknown quantity at this point
Re: Loose Balls
while throwing the 7 inch diameter ball, the human player has to stand 4 feet behind a 6 foot wall then it is another 54 feet to a corner gaol that is only 10 inches by 48 inches. a shot i would think to be extremely dificult. and santosh raises another point, ROBOTS! they'll be in your way. so, to sum up, i don't think human players will be scorring many (if any) pionts.
  #24   Spotlight this post!
Unread 18-01-2006, 14:48
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Re: Loose Balls
That would be an amazing strategy if you were ahead by 26+ points, but otherwise, or your opponents lack the ability to get 3 robots onto the platform. Additionally, you could go for the ramp, which would force the opponent to score very rapidly to make up for the difference, but in many situations they may be able to do so, or at minimum prevent you from getting ramp points (or in a worse case, pin your robots on their ramp).
Because the platforms can potentially be worth 50 points (25 for them, 25 for you), any strategy forsaking the platform can be very risky.
Additionally, because of the fact that any balls score re-circulate back into play, a large lead in this game will be hard to accomplish. I predict that almost every "blow-out" will involve the winning team having more "platform points" than the loser. This is also magnified by the fact that "ball hoarding" is a viable (if yet risky during the final period) strategy. And because of that the 2/3 periods may become very very defensive. (They may also be incredibly offensive depending on robot capabilities and how the back-bot acts-and how the other alliance reacts to the backbot).
This game has more potential for different styles of play than any I have ever seen, and it will be hard to see which strategies work and which don't until you see what the robots' capabilities are.
POLL: have small balls been abandoned? Solace General Forum 44 04-09-2004 17:53
New Jersey Regional Status Aignam Regional Competitions 144 21-07-2004 17:04
Thoughts on the competiton balls Petey Regional Competitions 26 14-03-2004 09:31
Team 188 Pictures - four big balls anyone? archiver 2001 6 24-06-2002 01:03
Will ANYONE mess with the black balls? archiver 2001 0 23-06-2002 22:35
