Go to Post Our safety manager isn't allowed to use the power tools, because he used a drill as a pointing device. - daniel_dsouza [more]
Go Back   Chief Delphi > Technical > Kit & Additional Hardware
Unread 13-01-2006, 01:33
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Team Role: Teacher
KOP Transmission gear defect
One of our KOP transmission gears (one of the small ones with the hex hole) has a defect. The hex bore has a slight twist to it. It is the oddest thing. I don't know how it could have happened. It is slight, but definitely visible to the naked eye. We had to press the gear on the shaft, but luckily it still fit; tight, but we got it on without too much trouble.
Anyway, I just wanted to let you know in case anyone had a similar problem with getting that gear on.
Please respond if you have the same problem, so we can get an idea if we got the one unluck gear or if there are a few like this out there.
Unread 13-01-2006, 09:47
Unsung FIRST Hero
JVN JVN is offline
@JohnVNeun
AKA: John Vielkind-Neun
FRC #0148 (Robowranglers)
Rookie Year: 2000
JVN has a reputation beyond reputeJVN has a reputation beyond reputeJVN has a reputation beyond reputeJVN has a reputation beyond reputeJVN has a reputation beyond reputeJVN has a reputation beyond reputeJVN has a reputation beyond reputeJVN has a reputation beyond reputeJVN has a reputation beyond reputeJVN has a reputation beyond reputeJVN has a reputation beyond repute
Re: KOP Transmission gear defect
This was actually a manufacturers problem from last season. (There was some leftover inventory from last year that was used this year; I guess your team received a transmission kit with this 2005 gear.)
The fix is talked about here:
http://www.ifirobotics.com/forum/viewtopic.php?t=174
The manufacturing flaw was fixed for 2006.
-JV
In the interest of full disclosure: I work for VEX Robotics a subsidiary of Innovation First International (IFI) Crown Supplier & Proud Supporter of FIRST
Adding FP Motor to '05 KOP Transmission Tom Bottiglieri Technical Discussion 20 10-01-2006 23:02
KOP Chassis & Transmission Inventor 8 Files JVN Inventor 0 12-01-2005 15:00
KOP Chassis & Transmission Support/Documentation JVN Technical Discussion 0 10-01-2005 00:28
Looking for KOP Helical Gears ChuckDickerson Kit & Additional Hardware 1 21-07-2004 15:39
