Go to Post Heaven forbid. A hexed Vex. - Warren Boudreau [more]
Unread 13-01-2006, 01:55
lasindi lasindi is offline
FRC #1164 (Project Neo)
lasindi is an unknown quantity at this point
In Linux, compiler can't find standard headers
I've been trying to get the default code to compile under Linux, but I've run into some trouble. So far, I've mostly been following the advice in this thread. I installed the C18 compiler under WINE, and that appears to have worked. I can't yet use a makefile because I can't get individual files to compile. For example, I tried to get main.c to compile with this command:
Code:
mcc18 main.c -fo=main.o
But I get the following error:
Code:
Microchip MCC C18 Compiler
        Version 0.0+SVN20050725
DEBUG:Using wine /opt/mcc18/bin/mcc18-traditional main.c -fo=main.o  to launch MCC18
fixme:msvcrt:_spawnve :not translating name Z:\opt\mcc18\bin\cpp18 to locate program
C:\first\default_code\ifi_aliases.h:18:Error [1027] unable to locate 'adc.h'
C:\first\default_code\ifi_default.h:13:Error [1027] unable to locate 'p18cxxx.h'
It looks like it can't find the headers in the standard include directory (/opt/mcc18/h). Is there a parameter I need to pass to mcc18 or some modification to the mcc18 script that I need to make in order for this to work?
Let's have Linux Robots Next Year! jdong Control System 52 22-08-2005 09:40
printf could not find definition Alex829 Programming 7 27-06-2005 10:04
IMPORTANT regarding the new C Compiler dlavery General Forum 12 14-01-2005 05:05
Where can I find the new C compiler? CompMaster Programming 2 13-01-2005 02:28
Linux C18 compiler? Servo888 Robotics Education and Curriculum 1 13-12-2003 01:27
