Ok, everyone knows the common way fo charging the 7.2 Volt Backup Battery, taking it out and connecting it to the charger. Although while reading through the 2006 FIRST Encyclopedia (Rule Book) I noticed Rule R53 in Section 5 on page 16. It States:
Re: Charging 7.2V Backup Battery
i dont know, but is it that hard to take off the battery? lol.
That is a good point. For us at least, the backup battery seems to be one piece that is easily overlooked, no matter how hard I try to remember or write it down, I always get sidetracked. If this is acutally possible, it could be a nice backup in case it is not charged.
Quick question, what is constant charging going to do to the battery? I would be worried about the "memory effect" (not fully discharging the batteries makes them not able to hold a charge as long)
Don Last edited by DonRotolo : 10-01-2006 at 20:17. Reason: Shoulda used spell check |
As far as the battery being charged constantly i don't think you will have to worry about it for one season.
But back to the main question, has anyone seen the diagram yet? I STILL cannot find it. |
A couple of references have been made to the "memory effect" of Ni-Cad batteries. I did a lot of research into this in the late 80's and can state that it simply does not exist.
Now before someone ups and quotes a university, technical or other "knowledgeable" source, I would ask you to read the sidebar article, Memory effect? No, voltage depression, in this article from EDN magazine. It does as good of a job of explaining the phenomenon in (almost) layman's terms. The "memory effect" has been bantered about for so long (over 40 years) that it is accepted as fact by many very smart scientists and engineers. I had a devil of a time trying to explain this to my to management... But that's another story... Regards, Mike |
The memory effect is very real. Constant charging will shorten the life of the batteries. But, for the amount of use the batteries would see it shouldn't be much of an issue. You could also build a pack with NiMH cells that do not have a memory effect.
#10
Thats a very good point. |
#12
I feel the need to chime in here on a few points.
1. The charging circuit that IFI is likely to publish will include charge current limiting and diode protection so that the backup battery is not able to supply current to the 12 volt circuitry on the robot. There are several usable designs that can accomplish this, just be patient. 2. Mike, I have to disagree on the NiCad memory issue. It does exist, particularly in inexpensive cell technologies and older batteries (we make extensive use of rechargeable packs in camera, VCR and light applications for the field). New designs have managed to overcome the chemical issues that led to this problem. (much of the problem occurred with internal construction and material choice.) It is unlikely that any of the newer, high charge current or extended use NiCad cells will exhibit the problem. As a team, you should not consider it to be a factor in your battery choice. 3. Many of you seem to be fully on board with a 12 volt charging circuit operated from the main battery. I am not, as it adds weight to your robot and steals power from the main battery. Simple buy two backup batteries and charge one while you use the other on the robot. If you find that you require higher current (due to multiple servos in your design) Digikey or other vendors can assemble battery packs in any current or package size you might desire. |
#14
http://en.wikipedia.org/wiki/Cadmium http://risk.lsd.ornl.gov/tox/profiles/cadmium.shtml http://www.epa.gov/ttn/atw/hlthef/cadmium.html |
#15
The notion that NiMh batteries dont suffer from these problems is also incorrect, on top of all of this. Their problems are not as severe, but NiMh also can get a bit sleepy after storage and a couple of cycles from a good conditioning charger will wake them up. The Maha MH-C777PLUS charger, or its equivalent, will allow you to keep on top of this, and will tell you what your battery capacity is. Please recycle batteries properly when they die... At our first regional with a back up battery, I think two years ago, the tech inspector did not allow a larger radio shack battery and insisted on the IFI backup battery, in spite of the written rules. We compiled... Last edited by eugenebrooks : 14-01-2006 at 23:50. |
| Batteries and hard impacts | ConKbot of Doom | Electrical | 1 | 19-02-2005 13:39 |
| 7.2 Volt Battery | Justin_302 | Electrical | 4 | 28-01-2005 23:25 |
| Batteries Exide 2005 Quanity | Mike Martus | Electrical | 6 | 13-01-2005 19:44 |
| Charging Batteries | like_a_fox | Electrical | 10 | 15-03-2004 17:57 |
| HELP - We have no batteries!! | Rick Gibbs | Championship Event | 3 | 24-04-2002 19:07 |
