Go to Post that is one of the funniest non-photoshoped pictures of my father i have seen... - Lil' Lavery [more]
Unread 18-02-2008, 10:02
avitzur avitzur is offline
avitzur is an unknown quantity at this point
clock cod
I am using the 'frc_encoder' from 2006 as a base project and C18 2.4
I wont to use your new 'clock' file from 2008 but it looks for 'ifi_frc.h'
what can i do ??????
avi
Unread 18-02-2008, 12:56
Kevin Watson's Avatar
Kevin Watson Kevin Watson is offline
La Caņada High School
FRC #2429
Kevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond repute
Re: clock cod
avi
Replace that #include statement with this one: #include <p18cxxx.h>. If you're using 2006 code, it's important to make sure you follow the steps in this document too.
-Kevin
Kevin Watson
Engineer at stealth-mode startup
http://kevin.org
Out of the Box Camera Code russell Programming 9 21-10-2009 05:28
Kevin Watson's encoder code with RPM output MaxM Programming 2 05-02-2005 00:06
Team THRUST - Kevin's Code and Camera Code Combine Chris_Elston Programming 3 31-01-2005 22:28
Updated Encoder Code Available Kevin Watson Programming 2 04-01-2005 01:00
heres the code. y this not working omega Programming 16 31-03-2004 15:18
