Go to Post "Its not a glitch its a new feature, we just dont know how to use it yet" - Cuog [more]
Unread 14-01-2006, 10:43
Uberbots's Avatar
Uberbots Uberbots is offline
Mad Programmer
AKA: Billy Sisson
FRC #1124 (ÜberBots)
Uberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond repute
12 volt sensor distribution breaker panel?
We have been reading the manual as to how to hook upi this years new set of sensors.
and in order to supply to power to the sensors it mentions that the sensor getis its power from the "12 volt sensor dristribution breaker panel".
were kinda wondering where this is, and we have eliminated the possibility of the power supply comoing off of a PWM output because it only supplies 7.2 volts.
are we missing something here?
--ss32
A few of my favorite numbers:
175 176 177 195 230 558 716 1024 1071 1592 1784 1816
RPI 2012
BREAKAWAY
Unread 14-01-2006, 17:42
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Re: 12 volt sensor distribution breaker panel?
I don't recall wording like that in the manual, and I didn't find it quickly. Please specify where you're reading it, and we'll try to help interpret it.
Unread 14-01-2006, 22:52
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
The section to which you refer, requires that all powered sensors receive power through a 20 amp circuit breaker in one of the circuit breaker panels that your team chooses to use.
Al
WB9UVJ
www.wildstang.org
________________________
Unread 14-01-2006, 23:31
eugenebrooks eugenebrooks is offline
AKA: Dr. Brooks
no team (WRRF)
eugenebrooks has a reputation beyond reputeeugenebrooks has a reputation beyond reputeeugenebrooks has a reputation beyond reputeeugenebrooks has a reputation beyond reputeeugenebrooks has a reputation beyond reputeeugenebrooks has a reputation beyond reputeeugenebrooks has a reputation beyond reputeeugenebrooks has a reputation beyond reputeeugenebrooks has a reputation beyond reputeeugenebrooks has a reputation beyond reputeeugenebrooks has a reputation beyond repute
Last year, in response to a rule like this but with things like the gyro and accelerometer using a PWM hookup getting power from the 7.2 volt battery in other sections of the manual and documentation, I asked about it in the Q+A and FIRST approved hooking a gyro and accelerometer directly to the PWM power instead of running a separate 12 volt line and regulator. This year's ruling might be different...
Eugene
New Model Posted - 2005 Breaker Panel Ed Sparks Inventor 5 01-01-2006 23:25
Breaker Panel Diagnostics dm0ney Programming 4 29-03-2005 19:00
Digital Breaker Panel Mark McLeod Control System 8 31-01-2005 00:22
Breaker Panel weight Emily Pease Electrical 4 24-01-2005 12:22
Breaker Panel Gal Longin Electrical 1 13-01-2005 16:01
