Go to Post When you are able to get inside their heads, you will either... or.. B) Learn way to much, and end up running away screaming. - Either way, it'll be a learning experience. - Elgin Clock [more]
Unread 14-01-2006, 15:17
Windward's Avatar
Windward Windward is offline
FRC #1452
Windward is an unknown quantity at this point
CPU loop speed
Last year 1 loop on through the code on the CPU was about 1.36 secs (depending on amount of code). Now that the processor is faster is the time any different?
Unread 14-01-2006, 17:44
Windward's Avatar
FRC #1452
Re: CPU loop speed
Is it changed at all?
Unread 14-01-2006, 18:02
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Re: CPU loop speed
(I don't have a copy of the code handy, so please forgive small errors in function names.)
The "fast" loop, process_data_from_local_IO(), is essentially called again as soon as it returns, so it runs more often if it takes less time. Ours two years ago was quick enough to deal with polling digital sensors that changed every couple of milliseconds. The "slow" loop, Default_Routine(), is called every time there is a new communication packet available from the OI, approximately 39 times per second.
I have no idea where your "1.36 seconds" came from.
Unread 14-01-2006, 20:53
Salik Syed Salik Syed is offline
FRC #0701 (RoboVikes)
Salik Syed has much to be proud ofSalik Syed has much to be proud ofSalik Syed has much to be proud ofSalik Syed has much to be proud ofSalik Syed has much to be proud ofSalik Syed has much to be proud ofSalik Syed has much to be proud ofSalik Syed has much to be proud ofSalik Syed has much to be proud of
Send a message via AIM to Salik Syed
Re: CPU loop speed
1.36!!!! that is VERY slow... lol... i think the Default routine is called every 26.2 ms ... but the actual loop time of other functions varies based on a lot of other factrs.
Team 701
Unread 14-01-2006, 21:03
jdong jdong is offline
Linux Nerd
AKA: John D
#0245 (Adam-Bots)
jdong will become famous soon enoughjdong will become famous soon enough
Re: CPU loop speed
Sounds like the "other end" that you're using to "measure" the "loop speed" isn't accurate -- note that serial ports don't magically report data back in realtime...
The new controller (PIC18F8722) just boasts more storage all around, and does not improve on speed.
John Dong
Co-Captain, Webmaster / Programmer
Team 245 -- Rochester Adams Robotics
Unread 06-02-2007, 14:25
last_decesion last_decesion is offline
FRC #1926
last_decesion is an unknown quantity at this point
Question Re: Cam Program
Who here has the latest progamming for the CPU Cam2?
Unread 07-02-2007, 15:22
shawger shawger is offline
Programming Subteam Leader
FRC #1732 (Hilltopper Robotics)
shawger will become famous soon enough
Re: Cam Program
Do you mean Kevin Watson's code? You can find the latest version at his website www.kevin.org/frc
Electronic Speed Controllers for DC Motor Spindle Robotics Education and Curriculum 12 23-04-2005 09:18
Autonomous loop speed BillyJ Programming 6 08-03-2005 14:10
Rewriting main loop Max Lobovsky Programming 4 04-01-2005 18:35
Joining 2 dif. motors K.Shaw Motors 32 14-10-2004 19:40
Power, speed, and torque... AGH Gui Cavalcanti Technical Discussion 5 10-11-2002 19:02
