Go to Post Remember, WWGD? (What would Grandma Do?) - Vikesrock [more]
Go Back   Chief Delphi > Technical > National Instruments LabVIEW and Data Acquisition > LabView and Data Acquisition
Unread 15-01-2006, 09:48
fuse's Avatar
fuse fuse is offline
fuse is an unknown quantity at this point
MAX software not working
I have installed the LabVIEW software and drivers and also have CMUcam2. When i open Measurement and Automation Explorer, the only options in the tree are "My System" and "Remote Systems". Under My System i click on the devices and interfaces category but there are no COM ports or anything. I have reinstalled everything 3 times and yes i have my serial-USB adapter plugged in while opening it. Everything works fine on a teammates computer. Please help!
Unread 15-01-2006, 13:09
Joe Hershberger Joe Hershberger is offline
AKA: jhersh
FRC #2468 (Appreciate)
Rookie Year: 1997
Joe Hershberger is a name known to allJoe Hershberger is a name known to allJoe Hershberger is a name known to allJoe Hershberger is a name known to allJoe Hershberger is a name known to allJoe Hershberger is a name known to all
Re: MAX software not working
Sounds like you haven't installed NI VISA. Install the latest version, reboot, and try MAX again. Your serial ports will then show up and your CMUcam2 will work in LabView.
Good Luck!
-Joe
Unread 15-01-2006, 23:44
fuse's Avatar
Good Luck!
-Joe
Wow thank you. Isnt it a bit odd that when a teammate followed the exact same steps i did, it worked for him but not me... oh well. Problem solved.
wiki software robot180 IT / Communications 5 02-10-2005 16:44
Time tracking software scitobor 617 Programming 19 26-08-2005 21:21
Open scoring software? Kevin Sevcik General Forum 16 15-04-2005 00:00
