Go to Post woo hoo! I rigged up brief Internet access using an old wornout robot battery. - Mark McLeod [more]
Unread 15-01-2006, 11:06
Chris_Elston's Avatar
Chris_Elston Chris_Elston is offline
Controls Engineer
AKA: chakorules
FRC #1501 (Team THRUST)
Chris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond repute
While Loop Require in OperatorControl?
I've seen now two videos of a couple of engineers from Intellitek that are teaching a seminar on EasyC and both of them show creating a WHILE (1) LOOP in the operatorcontrol function and putting your code inside the loop.
Is this required? I've got my code to excute just fine without putting a while (1) loop inside the OperatorControl function. Doesn't it loop anyway?
I know the autonmous mode does not excute in a loop, once it completes to the end it's done, unless you put a while loop in there.
One thing that would be handy to see is a generic FLOW CHART on your "Competion Template". Like the one we get when we download default code from innovation first.
I am wondering if this loop is required and part of my problem of timing my standard CPU "Scan time". In another post.
Team T.H.R.U.S.T. 1501
Download all of our past robot's source code here:Repository
Favorite CD quote:
"That can't be their 'bot. not nearly enough (if any) rivets to be a 1501 machine." ~RogerR: Team #1369
Loop time for OperatorControl function? Debug blows... Chris_Elston Programming 10 13-02-2006 14:42
arm-limitting gyro PD loop producing some strange results ZZII 527 Programming 8 16-02-2005 02:30
Loop execution time for Autonomous code Transporter08 Programming 2 13-02-2005 16:17
Rewriting main loop Max Lobovsky Programming 4 04-01-2005 18:35
Rules for hanging, using a loop over the end of the bar caffel Rules/Strategy 10 04-06-2004 15:04
