Team 358 Shooter Prototype
Below is a link to our prototype ball shooter.
shooter prototype.wmv this is a prototype using the minibike motor to drive 2 aluminum wheels coated with friction tape. The vast majority of the inconsistancy is due to the feed mechanism. There are, however some belt slippage issues, which were responsible for the rest of it. |
Re: Team 358 Shooter Prototype
I have some questions i hope you wont mind answering: 1)what is the gear reduction bwetween the motor and the wheels. 2)how did you connect the motor to frame? 3)how did you transfer the power? (belt/ chain) 4)if belt, as implied by post, where did you get the matching parts? (i.e. the belt and the other belt compatible sprocket) 5)are both wheels moving? hope that's not too intrusive! Thanks! -Leav |
Wow, good job! Seems like alot of teams are making accurate shooter mechanisms...this this should be an interesting year.
Very similar to ours, though we used a small instead of a large CIM. I'm glad to see that the RPM difference isn't an issue, as that is what we plan to use eventually. Great job guys!
Nice job team 358. Look forward to seeing you at UTC New England in March.
Leav - Your questions are not intrusive at all. As was said, this is a prototype, and we still have some work to do, but the following are the answers based upon what you see in the video: 1, 3, 5) There is a 2:1 gear ratio off the mini-bike motor, to timing belts which rotate (2) 4" drums. 2) The motor is connected to the frame by means of replacing the motor length assembly screw to match the other longer motor assembly screw. These screws then attach the motor to the gearbox. 4) These are standard gears and timing belts/pulleys, available from places like McMaster Carr, Small Parts, MSC, Stock Drive Products, etc... I hope that helps. Jon K. - It's our first time at UTC, and we look forward to seeing you guys/gals as well. By the way, very impressive teaser!!!! Last edited by Scott358 : 15-01-2006 at 23:39. |
I'm starting to notice a lot of people using the minibike motors for their shooting mechanism. My team and I seem to think the smaller CIM motors will pay off when shooting balls repeatedly.
Wow, I guess I'm missing out this year, maybe I'll stop in this week to see what else you guys have done without me.
What makes you think the smaller CIM's will be more repeatable? |
#10
It works pretty well and it's got a pretty good kick to it, hit me at 12 feet away and it hurt!
![]() I'm also curious as to why the smaller CIM would be more repeatable? |
#11
this is a cool design
i guess that the design was sort of like the baseball shooter. maybe ill show my team and they might start taking suggestions |
#12
They were MXL aluminum pulleys and 1/4" wide timing belts (where the "M" stands for mini). We're moving up to XL steel pulleys and 3/8" timing belts for a more robust system. We'll know more about how this works tomorrow. As far as were we are getting materials, I've found that StockDriveProducts.com has a very good selection, and most items available. Hope this helps. |
#15
| How do you organize your team? | NoodleKnight | Team Organization | 18 | 03-11-2005 22:57 |
| Who do you think is the best bet to win the Chairman's Award at the Championship? | Koko Ed | Chairman's Award | 58 | 29-04-2005 16:39 |
| Free Kittens/Tetra Grabber | Mr. Lim | Rumor Mill | 30 | 08-04-2005 11:36 |
| Real names, please | Andy Baker | General Forum | 131 | 21-07-2004 22:07 |
| **FIRST EMAIL**/Important Information for All Championship Teams! | Jeremy Roberts | FIRST E-Mail Blast Archive | 0 | 09-04-2004 21:12 |
