| View Poll Results: did you use the kitbot? | |||
| yes |
82 | 31.18% |
| no |
138 | 52.47% |
| kitbot? |
43 | 16.35% |
| Voters: 263. You may not vote on this poll | |||
Thread Tools |
Rating:
Display Modes |
Re: how far have you gotten on your robot?
My team has mocked up a thrower and collecter, but there is still some debate on how to transport the balls into the hopper.
Our kitbot is built and drive train is finalized. |
I was wondering my Rookie Team was far behind. My teacher insists that we are right on schedule but it is hard to tell, knowing that there is so much to do and so little time left.
We have experimented on the devices to try and discover a system that would effectively shoot the 7.5 inch ball. We discovered that pneamatics would not be powerful enough and using springs was good idea but also did not work out so well in the end. We also tried using a pinball machine design, where a "hammer" would hit behind the ball and launch it forwards, but it again turned out not to be powerful enough. We are now trying to build a system with wheels and a motor to shoot the ball out similar to softball machine at batting cages. For the electrical stuff, we have laid out the most of the electronics and created the circuits and have screwed everything down to the plywood. We have built the chasis for the robot and started to play around with the camera, but are running into some technical difficulty. We have yet to look into a hopper system and a system for picking up loose balls. Thanks Scott |
we were about to have the basic chasis running, BUT we had to do a major over haul of the chasis due to lack of ground clearance and we should be running by tomorrow, and will be able to finish on schedule.
well we came up with this really cool see-saw design to move the balls to the shooter, but as a consequence we couldn't use the kit bot, which though primitive is really strong if put together right. for motors we are gonna end up using either cim motors with DeWalt transmissions for the most power. if the finance goddess blesses us, we might put 4 cims for extra power. we like push power
especially with the defence quarter thing. we did that last year, so we are just waiting on partsi made a shooter merely using the old bot for a platform and the softball launcher design. separately we got the camera to work after much tinkering. are we the only team having problems with the camera locking onto ceiling lights as well as the target? |
We're done!!!!
Our drivetreain design deadline is wednesday but I hear that we will be done by tomorrow and order parts by tomorrow and starting builing the drivetrain by wednesday.
we have finsih protype start build monday have finished
with driver programing and auton which only took us about 4 hours |
at school it was all encased with no holes so the case exploded with the rest of that side. strange things sometimes happen but for once this wasnt my fault we just finished exams. we had to work through them anyone else had things blow up or burn? Last edited by gondorf : 15-01-2006 at 20:22. |
#11
as for the motors on the kitbot smoking the real problem was because there was a gear stuck.
we now have it working again and it is fine |
#12
No matter how much you do you will never be on schedule. So we are far enough.
#13
68 has a few prototypes working. We're still testing different ideas, though. Hopefully by the end of this week or next we will have settled on a design. And no, we're not using the kitbot. JBotAlan |
#15
1. What is a dremel bit? 2. how do they shatter? 3. if it shattered why did it "throw" shrapnel? it should have dropped. 4. why did it only hit his goggles? |
| VCU NASA Regional | Collmandoman | Regional Competitions | 83 | 10-03-2005 13:20 |
| 2005 FRC Team Update 14 | Jeffrafa | General Forum | 43 | 01-03-2005 15:52 |
| Manual placement of tetras | Petey | Rules/Strategy | 7 | 22-02-2005 18:04 |
| A Question on Sportsmanship | Steve M | General Forum | 31 | 25-05-2004 23:52 |
| Calling all Lawyers... ...Define "all parts" | Joe Johnson | General Forum | 10 | 13-03-2002 15:12 |
