Go to Post Lose lips sink... robots? (during a water game at least) - Zach O [more]
View Poll Results: did you use the kitbot?
yes 82 31.18%
no 138 52.47%
kitbot? 43 16.35%
Voters: 263. You may not vote on this poll
Unread 20-01-2006, 00:39
jesusfreakmths's Avatar
jesusfreakmths jesusfreakmths is offline
AKA: Jonathan
FRC #1778
jesusfreakmths will become famous soon enough
Send a message via AIM to jesusfreakmths
Re: how far have you gotten on your robot?
Originally Posted by Nuttyman54
YAY! the magic smoke is back!! I haven't heard about any Victors smoking...you DO have it hooked up to the fuse block, right?
I believe that we connected it right. The positive wire from the 120amp cut off switch connects to the 40amp fuse then straight to the victors, right?
well right now we have disconnected the fuses so that it doesn't run for now. we ordered two more victors and are still waiting for those to come in.
Jonathan
Unread 20-01-2006, 10:59
Josh Murphy's Avatar
Josh Murphy Josh Murphy is offline
AKA: Josh
FRC #0051 (Wings of Fire)
Team Role: Coach
Josh Murphy has a reputation beyond reputeJosh Murphy has a reputation beyond reputeJosh Murphy has a reputation beyond reputeJosh Murphy has a reputation beyond reputeJosh Murphy has a reputation beyond reputeJosh Murphy has a reputation beyond reputeJosh Murphy has a reputation beyond reputeJosh Murphy has a reputation beyond reputeJosh Murphy has a reputation beyond reputeJosh Murphy has a reputation beyond reputeJosh Murphy has a reputation beyond repute
right now we pretty much have alot done but we have alot to be welded right now so we really aren't ahead of the game as we planned
Unread 20-01-2006, 11:45
devicenull devicenull is offline
Robot? We need a robot?
Rookie Year: 1234
devicenull is just really nicedevicenull is just really nicedevicenull is just really nicedevicenull is just really nicedevicenull is just really nice
Originally Posted by jesusfreakmths
So far we have a basic design. we are currently trying to get our robot to move around with out ruining anything. lol.
Has anyone had there speed controller (Victor 884) start smoking and melt?
Anyways we are a little behind, gut are amazed at what we have gotten done so far since we are just a rookie team.
Please tell me you aren't drilling/cutting/filing metal above them? That will kill them really really nicely. Although the RC seems to withstand metal shavings in its pins, the speed controllers don't like them from what I hear.
Unread 20-01-2006, 12:10
Veselin Kolev's Avatar
Veselin Kolev Veselin Kolev is offline
X51 Production Company PGM (TM)
Veselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond repute
Cad is 90% done
Chassis has been sent out for fabrication and welding
Drive trains are done
Ball capacity: 40
Unread 20-01-2006, 13:01
Elgin Clock's Avatar
Elgin Clock Elgin Clock is offline
updates this status less than FB!
AKA: the one who "will break into your thoughts..."
FRC #0237 (Black Magic)
Elgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond repute
Send a message via AIM to Elgin Clock
We got pretty far.
Ball capacity: 149.
The influence of many leads to the individuality of one. - E.C.C. (That's me!!)
Unread 20-01-2006, 14:29
AKA: Jonathan
FRC #1778
our board with all of the electronic parts hasn't even touched the robot yet! hopefully we will get it on the robot soon.
Jonathan
Unread 19-01-2006, 21:53
Andrew Blair's Avatar
Andrew Blair Andrew Blair is offline
SAE Formula is FIRST with Gasoline.
FRC #0306 (CRT)
Andrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond repute
Send a message via AIM to Andrew Blair Send a message via Yahoo to Andrew Blair
I don't know if anyone did this, but if you watch the assembly video from 2005 it says that the set screws will bind, and that you need to replace them with the included replacements...
Yes, but even after you replace them, if that lockwasher is still in place, it will give you trouble. Eventually, through vibration or whatever, it will loosen, fall off, and 50% of the time, bind your gearbox. As Rick said, take it off. It will not make a difference. But yes, disregarding my rant, the setscrew must be replaced.
EDIT--------------------
Not sure if the 2006 ones need it replaced though. Would have thought they'd have fixed that bay now...
Reading makes a full man, conference a ready man, and writing an exact man.
-Sir Francis Bacon
"Any intelligent fool can make things bigger, more complex, and more violent. It takes a touch of genius -- and a lot of courage -- to move in the opposite direction."
-Albert Einstein
Unread 21-01-2006, 22:02
Cpt_Dave_Lister
Posts: n/a
okie dokie! time for an update, we just finished 90 percent of our robot base just need to decide now where to mount motors...
*our drivetrain is mostly inside our frame...* HEHEHHEHEHE
Unread 15-01-2006, 19:47
BuddyB309's Avatar
BuddyB309 BuddyB309 is offline
I freaking love animating!!
AKA: Peter Casey
FRC #1625 (Winnovation)
Team Role: Animator
BuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond repute
Send a message via AIM to BuddyB309
we only have some prototypes made from cardboard, we can stop the camera from having fits, and its so freaking cold in our shop! but the 3ds max team (which only consist of me and two other non-dedicated dudes ) is doing well. I just finishing lip synch today and i only had one aneurysms so far .
A.K.A Llama
check out my latest animations Appliance Night Out, Infant Intolerable, Fishing Like a Loony Tune, VVV Roadside Assistance
Life? I have a life. It is sitting at my computer and Animating. AND DRAWING!!! WEEEEEEE!!!!
Unread 15-01-2006, 21:00
greencactus3 greencactus3 is offline
occra 23.
AKA: ryo
None #1481
greencactus3 is a name known to allgreencactus3 is a name known to allgreencactus3 is a name known to allgreencactus3 is a name known to allgreencactus3 is a name known to allgreencactus3 is a name known to all
Send a message via AIM to greencactus3 Send a message via MSN to greencactus3
we opened up our boxes and took otu everything... and then pulled out cardboard and had an arts and crafts show. then played marioparty2 and then back to inventor.
Billfred's Avatar
Billfred Billfred is online now
One week in, and after strategizing the heck out of the game, 1293 has together our Kitbot frame and transmissions, with the gear tooth sensors mounted as well.
This week, the aim is to get Chomp ready for wiring.
(Yes, that would also be the first public mention of our 2006 robot's name.)
Unread 17-01-2006, 23:30
Uberbots's Avatar
Uberbots Uberbots is offline
Mad Programmer
AKA: Billy Sisson
FRC #1124 (ÜberBots)
Uberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond repute
dang... we have already got our launch systems going.
bam! 12 feet per second. this launcher is pretty awesome. and EXTREMELY accurate (spray range average of about 5 inches)
unbounded we got the launcher to shoot at a maximum of 25 feet per second. so this thing is dangerously powerfull (we even went and fired it at the principal of the school, and OF COARSE he volunteered)
it really stinks that we havent been able to get our closed loop to work, the sensors seem to like to return null values
and the camera? *shiver*
we have gotten pretty far along as far as planning goes, and we have a separate team of brainiacs (non-programmer/building but smart types) who are contemplating the posible strategies. im hoping for a good competion seaon this year!
(i hope i stayed on topic.... im not really good at that as my english papers would say)
EDIT: hey spiffizzle... keep going on that design. it looks really nice so far.
A few of my favorite numbers:
175 176 177 195 230 558 716 1024 1071 1592 1784 1816
RPI 2012
BREAKAWAY
Unread 16-01-2006, 15:20
LPaton716's Avatar
LPaton716 LPaton716 is offline
YYURYYUBICURYY001thee
#0716 (The Who'sCTEKS)
Team Role: Student
LPaton716 has a spectacular aura aboutLPaton716 has a spectacular aura aboutLPaton716 has a spectacular aura about
Our team prototypes everything first. So as of now it's all in cardboard and PVC. There are some details that need to be figured out with the design before we can put the kit bot chassis together. But we're basically on schedule and I'd say further along than last year so that's good. woot
??? TEAM 716 The Who'sCTEKS ???
"Education is not about the filling of a pail, but the lighting of a fire." -William Butler Yeats
"May peace prevail on earth, and let it begin with me."-song
Unread 16-01-2006, 16:11
AGWSPilot AGWSPilot is offline
FRC #1415
AGWSPilot is on a distinguished road
We finished the kitbot chassis, we tossed on a couple of gears, and 2 CIM motors from last year, to set up 4 wheel drive. We did some testing, and we got it to push several cinder blocks, but the kitbot wheel slip way too much. We are searching for new wheels. Our camera is shy. It will look at the target, then stare at the ground. For our launcher, we have doodles and equations...
  #15   Spotlight this post!
Unread 16-01-2006, 18:39
cire's Avatar
cire cire is offline
Alumni, Mentor, and Coach
AKA: Eric Diehr
FRC #1716 (Redbird Robotics)
cire is just really nicecire is just really nicecire is just really nicecire is just really nice
Send a message via MSN to cire
We are using the kit gearboxes, not using any other parts of the kitbot though.
Our progress:
Drivetrain design completed, Parts have been ordered and should be done by friday or saturday.
Payload concept is pretty much done, hasnt been designed in detail yet though.
Programmers having fun with the camera i think.
Field is partialy completed.
VCU NASA Regional Collmandoman Regional Competitions 83 10-03-2005 13:20
2005 FRC Team Update 14 Jeffrafa General Forum 43 01-03-2005 15:52
Manual placement of tetras Petey Rules/Strategy 7 22-02-2005 18:04
A Question on Sportsmanship Steve M General Forum 31 25-05-2004 23:52
Calling all Lawyers... ...Define "all parts" Joe Johnson General Forum 10 13-03-2002 15:12
