Go to Post Driving without the trailer was quite fun, but driving with the trailer was just painful. - Paul Copioli [more]
Unread 16-01-2006, 15:07
Max Brin Max Brin is offline
FRC #1943 (Neat Team)
Max Brin has a spectacular aura aboutMax Brin has a spectacular aura aboutMax Brin has a spectacular aura about
Air gun length
Can we make our air gun longer than 38" ?
Thanks!
Unread 16-01-2006, 15:11
EricH's Avatar
EricH EricH is offline
New year, new team
FRC #1197 (Torbots)
Re: Air gun length
Thanks!
Your shooting mechanism must stay within the starting footprint (28" by 38"). The manual is very good reading this time of year.
Past teams:
2003-2007: FRC0330 BeachBots
2008: FRC1135 Shmoebotics
Unread 16-01-2006, 15:17
Re: Air gun length
Thanks, but I ment after the game starts, not at the first measurments.
Isnt there a 60" limit or something similar while playing?
Unread 16-01-2006, 15:18
Unsung FIRST Hero
Mike Betts Mike Betts is offline
Electrical Engineer
Rookie Year: 1995
Mike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond repute
Re: Air gun length
Thanks!
Max,
What makes you think that it is legal to make an airgun at all?
Regards,
Mike
Mike Betts
Alumnus, Team 3518, Panthrobots, 2011
Alumnus, Team 177, Bobcat Robotics, 1995 - 2010
LRI, Connecticut Regional, 2007-2010
LRI, WPI Regional, 2009 - 2010
RI, South Florida Regional, 2012 - 2013
As easy as 355/113...
Unread 16-01-2006, 15:24
Re: Air gun length
Generally speaking about shooting mechanism, not air gun as a specific, sorry about misleading you.
Unread 16-01-2006, 15:27
Andrew Blair's Avatar
Andrew Blair Andrew Blair is offline
SAE Formula is FIRST with Gasoline.
FRC #0306 (CRT)
Andrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond repute
Send a message via AIM to Andrew Blair Send a message via Yahoo to Andrew Blair
Re: Air gun length
It must fit into the original space of 28x38x60. I suppose that if you put the gun at an angle in that virtual box, you could get a gun longer than 38", longer than 60" actually. But no, the gun cannot extend outside the original robot footprint, if thats what you mean.
Reading makes a full man, conference a ready man, and writing an exact man.
-Sir Francis Bacon
"Any intelligent fool can make things bigger, more complex, and more violent. It takes a touch of genius -- and a lot of courage -- to move in the opposite direction."
-Albert Einstein
Unread 16-01-2006, 15:33
MikeDubreuil's Avatar
MikeDubreuil MikeDubreuil is offline
Carpe diem
FRC #0125 (Nu-Trons)
Rookie Year: 1999
MikeDubreuil has a reputation beyond reputeMikeDubreuil has a reputation beyond reputeMikeDubreuil has a reputation beyond reputeMikeDubreuil has a reputation beyond reputeMikeDubreuil has a reputation beyond reputeMikeDubreuil has a reputation beyond reputeMikeDubreuil has a reputation beyond reputeMikeDubreuil has a reputation beyond reputeMikeDubreuil has a reputation beyond reputeMikeDubreuil has a reputation beyond reputeMikeDubreuil has a reputation beyond repute
Send a message via AIM to MikeDubreuil
Re: Air gun length
Originally Posted by Andrew Blair
It must fit into the origninal space of 28x38x60.
And the reason is <S03>:
Originally Posted by <S03>
Shooter Mechanism must remain inside the ROBOT - Any mechanism used to throw balls must be contained within the original 28” x 38” x 60”starting envelope of the ROBOT and must be shielded such that the mechanism cannot make contact with other ROBOTs. A ROBOT that violates this rule will be considered unsafe per <S01>.
"FIRST is like bling bling for the brain." - Woodie Flowers
Unread 16-01-2006, 15:35
Re: Air gun length
Guys, I've copied this paragraph:
The_Robot.pdf
5.3.2.1: Robot Size
"<R08> Once a match begins, robots may extend horizontally beyond the 28-inch x 38-inch starting size under
their own power, up to a limit of 60 inches in either horizontal cardinal dimension. The robot may not exceed
the 60-inch height restriction at any time during the match. In other words, after the start of the match the
robot may expand up to a maximum volume of 60 inches by 60 inches by 60 inches. The one exception to the
height restriction is provided in Rule <R13>. Any restraints (elastic bands, springs, etc.) that are used to
maintain starting size must remain attached to the robot for the duration of the match."
Unread 16-01-2006, 15:42
Carpe diem
Rookie Year: 1999
Re: Air gun length
Your cannon would be a part of your ball throwing mechanism. Therefore, your cannon can not exceed the 28" x 38" x 60" starting envelope. Please see this thread in the FIRST Q/A for further clarification.
Unread 16-01-2006, 15:45
EricH's Avatar
New year, new team
FRC #1197 (Torbots)
Re: Air gun length
<S03> still wins. Your shooter (and barrel, as clarified by Q&A) must remain in the 28" by 38" footprint for the entire match. Length is only limited by what you can fit into the box at the start and cannot expand out of it.
Why does <S03> win here? 2 reasons: 1) It's a limiting agent on <R08>, and 2) It's a safety rule and will be heavily enforced.
Past teams:
Nerf ball starting at 12m/s 45 degree angle ending at 8ft 6in w/ air resistance Ethulin Technical Discussion 39 14-01-2006 19:04
Higher PSI in air Tanks Projectchon Pneumatics 8 01-02-2005 15:05
More than two air tanks? Mercutio Pneumatics 6 10-02-2004 16:07
What are pneumatics? Aignam Pneumatics 23 16-10-2002 21:17
heat gun Lake Orion OCCRA 2 21-10-2001 23:34
