Go to Post Don't just assume that because you can modify an existing design that you are an engineer. - Daniel_LaFleur [more]
Unread 16-01-2006, 15:43
TheAnsweris42's Avatar
TheAnsweris42 TheAnsweris42 is offline
Team 1896 "Rules Guru"
AKA: Kenneth Casperson
FRC #1896 (Xodus)
Team Role: Webmaster
TheAnsweris42 will become famous soon enoughTheAnsweris42 will become famous soon enough
Send a message via ICQ to TheAnsweris42 Send a message via AIM to TheAnsweris42 Send a message via MSN to TheAnsweris42 Send a message via Yahoo to TheAnsweris42
Alternator
Apparently someone on my team found an alternator we could use on our robot. While I am severely skeptical about the feasibility of this idea... I can't find anything in the rules that says you can't. Does anyone else know anything about it? I can't imagine that no one else would have tried this before us...
"A common mistake people make when attempting to engineer something completely foolproof is to underestimate the ingenuity of complete fools"
-Douglas Nathaniel Adams
Unread 16-01-2006, 15:49
Sscamatt's Avatar
Sscamatt Sscamatt is offline
AKA: Matt Syska
FRC #0195 (Cyber Knights)
Team Role: Electrical
Sscamatt has much to be proud ofSscamatt has much to be proud ofSscamatt has much to be proud ofSscamatt has much to be proud ofSscamatt has much to be proud ofSscamatt has much to be proud ofSscamatt has much to be proud ofSscamatt has much to be proud ofSscamatt has much to be proud ofSscamatt has much to be proud of
Send a message via AIM to Sscamatt
Re: Alternator
<R51> The only legal main source of electrical energy on the robot is one of the two 12v DC non-spillable lead
acid batteries provided in the Kit of Parts, or a spare of the same part number. The 7.2v “backup” battery is
considered an integral part of the Robot Controller, and may not be used for any other purpose.
2006 Championship Finalist, Thanks 25 + 968!
2006 Newton Division Winner
2006 International Innovation In Control Award
2006 Radio Shack Innovation in Control Award, UTC Regional
RIT Class of 2011
Unread 16-01-2006, 15:52
EricH's Avatar
EricH EricH is offline
New year, new team
FRC #1197 (Torbots)
Re: Alternator
OK, as far as I know, there is no rule specifically allowing or disallowing alternators. BUT, you need to check costs, size, and weight. You also need to go through the Parts Use Flowchart in Section 5. If you are using it to charge the battery, I'm not sure it's legal. This would be something for Q&A to determine (don't base a strategy around this and have an inspector tell you to take it off kind of thing).
Past teams:
2003-2007: FRC0330 BeachBots
2008: FRC1135 Shmoebotics
Unread 16-01-2006, 15:55
Sscamatt's Avatar
AKA: Matt Syska
Re: Alternator
<R52> The EX18-12 Battery may only be charged by a 6 Ampere rated Automatic Battery Charger between
matches. When recharging Kit batteries, you may use the charger provided by FIRST or an automatic charger
with an equivalent charging current rating.
and it would be a custom circuit so:
<R57> The use of additional electronics is intended to allow teams to construct custom circuits for their robots.
The custom circuits may be used to indirectly affect the robot outputs by providing enhanced sensor feedback
to the Robot Controller to allow it to more effectively decide how to control the robot. In addition to the
required branch power circuit breaker, smaller value fuses may be incorporated in the custom circuits for
additional protection. All outputs from the custom circuits must be connected to the analog inputs, digital
I/O, TTL Serial Port, or Program Port on the Robot Controller.
There are many rules against using an alternator
RIT Class of 2011
Unread 16-01-2006, 15:58
MikeDubreuil's Avatar
MikeDubreuil MikeDubreuil is offline
Carpe diem
FRC #0125 (Nu-Trons)
Rookie Year: 1999
MikeDubreuil has a reputation beyond reputeMikeDubreuil has a reputation beyond reputeMikeDubreuil has a reputation beyond reputeMikeDubreuil has a reputation beyond reputeMikeDubreuil has a reputation beyond reputeMikeDubreuil has a reputation beyond reputeMikeDubreuil has a reputation beyond reputeMikeDubreuil has a reputation beyond reputeMikeDubreuil has a reputation beyond reputeMikeDubreuil has a reputation beyond reputeMikeDubreuil has a reputation beyond repute
Send a message via AIM to MikeDubreuil
Re: Alternator
First off, you would actually lose more power than you would gain by using an alternator to recharge the battery. Additionally, I don't see how an alternator can pass the Parts Use Flow Chart.
Is the part a motor,
solenoid, pump, or other
actuator?
This would be a Yes. Therefore, you can't use it.
For a more precise answer you would have to tell us the purpose of the alternator.
"FIRST is like bling bling for the brain." - Woodie Flowers
Unread 16-01-2006, 16:01
FRC #1896 (Xodus)
Re: Alternator
Yeah, I was actually just studying those rules you put up, but I wasnt sure if they applied. Anyways, I think the case is pretty much closed, no alternator. I personally agree with mike about the loss of power anyways. Thanks for the assist
Unread 16-01-2006, 16:21
KenWittlief KenWittlief is offline
KenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond repute
Re: Alternator
WOW! you got doused with four buckets of ice water, but no one has asked the critical question:
what do you want to use the alternator for?
I can think of applications that might not break the rules.
BTW, an alternator is not a motor, solenoid, pump, or other actuator
an alternator is a device that converts mechanical energy to electrical energy.
Unread 16-01-2006, 17:29
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
Re: Alternator
Inquiring minds want to know what you are thinking. On the other hand I don't believe it fits in the rules. Threre may be extenuating circumstances so I would like to hear what you had in mind.
Al
WB9UVJ
www.wildstang.org
________________________
Unread 16-01-2006, 18:01
Unsung FIRST Hero
Rookie Year: 1996
Re: Alternator
Originally Posted by mechanicalbrain
Off the bat alternating current deals much better with resistance then DC. It's one of the reasons the power company uses it.
This is one of the more confusing myths. The power company uses AC because you can use a transformer to increase voltage. DC power does not pass through a transformer and there is no efficient method of increasing a DC voltage at the power levels we are discussing. For a device consuming 1kW, it doesn't matter whether that is 100 volts DC or 100 volts AC RMS at 10 amps, the power delivered to the load is the same.
For a specific power, using a higher voltage reduces current. Reducing current reduces IR losses and the resistance in miles of delivery cable is devastating to power companies. Imagine delivering 100 MW (100,000,000 watts) at 1000 volts or at 100,000 volts.
Al
WB9UVJ
www.wildstang.org
Unread 16-01-2006, 22:23
Unsung FIRST Hero
Mike Betts Mike Betts is offline
Electrical Engineer
Rookie Year: 1995
Mike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond repute
Re: Alternator
That statement is not correct.
The power lost in in wires is dissipated as heat. In DC circuits, the heating in the wires is purely caused by the resistance of the wire. In AC circuits, the heat is caused by the resistance and the inductance (reactance) of the wire.
Since more heat (hence more power) is dissipated in AC circuits, DC is the preferred choice based on efficiency alone.
It was the difficulty in switching DC which was one of the deciding factors in the great Nicola Tesla/Thomas Edison "war of the currents" debates in the 1880's.
Edison lost...
Regards,
Mike
Mike Betts
Alumnus, Team 3518, Panthrobots, 2011
Alumnus, Team 177, Bobcat Robotics, 1995 - 2010
LRI, Connecticut Regional, 2007-2010
LRI, WPI Regional, 2009 - 2010
RI, South Florida Regional, 2012 - 2013
As easy as 355/113...
Unread 16-01-2006, 23:10
Re: Alternator
the real thing that pushed Tesla ahead wasnt that he invented AC or transformers, or the idea of high voltage transmission lines
the Tesla invention that made all the difference was his AC motor. No one could figure out how to make a motor that ran on AC. Tesla invented the basic AC induction motor concept that is still used today (and patented it)
Westinghouse bought his patent rights for a cool $1M cash + royalites!
House lights and street lights were great, but it was big powerfull electric motors in factories that drove the electrification of the world.
Unread 16-01-2006, 23:46
Biff Biff is offline
AKA: Tom Cooper
#1227 (Techno Gremlins)
Biff is a jewel in the roughBiff is a jewel in the roughBiff is a jewel in the roughBiff is a jewel in the rough
Re: Alternator
Tesla also invented the multi phase (read 3) alternator. The patent went to Westinghouse. (Which he later tore up the royalties contract for when Westinghouse was almost bankrupt.) He later went on to study pulsed DC, and the effects that happened when high voltage generators were switched into the distribution lines of Edison's electric plants. (Put on tinfoil hat and check sources when studying what other people say about Tesla.)
Unread 17-01-2006, 00:22
ahecht's Avatar
ahecht ahecht is offline
'Luzer'
AKA: Zan
ahecht has a reputation beyond reputeahecht has a reputation beyond reputeahecht has a reputation beyond reputeahecht has a reputation beyond reputeahecht has a reputation beyond reputeahecht has a reputation beyond reputeahecht has a reputation beyond reputeahecht has a reputation beyond reputeahecht has a reputation beyond reputeahecht has a reputation beyond reputeahecht has a reputation beyond repute
Send a message via ICQ to ahecht Send a message via AIM to ahecht Send a message via Yahoo to ahecht
Re: Alternator
I'm still confused as to why anyone would use an alternator on their robot. If you can't make it through a 2 minute match without running out of battery power, something else is wrong. And, if for some reason you wanted to do something like regenerative braking (and found a way for it to be legal), why would you want AC power on a DC robot?
Zan Hecht
Scorekeeper: '05 Championship DaVinci Field/'10 WPI Regional
Co-Founder: WPI-EBOT Educational Robotics Program
Alumnus: WPI/Mass Academy Team #190
Alumnus (and founder): Oakwood Robotics Team #992
"Life is an odd numbered problem the answer isn't in the back of the book." — Anonymous WPI Student
Unread 17-01-2006, 00:27
Re: Alternator
I am still waiting for "TheAnswerIs42" to come back and tell us what his original application idea was.
he never said what he wanted to do with it
inquisitive minds want to know! :^)
Making a welder from an alternator and engine sanddrag Technical Discussion 11 09-10-2005 03:55
