Go to Post And another big factor in winning. Luck. - Carol [more]
Unread 16-01-2006, 18:13
Rickertsen2 Rickertsen2 is offline
Umm Errr...
None #1139 (Chamblee Gear Grinders)
Rickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant future
Send a message via AIM to Rickertsen2 Send a message via Yahoo to Rickertsen2
Motor theory questions
I was looking at the differences between the two CIM motors and started asking some questions. What internally about a PM DC brush motor defines its characteristics. What factors determine the maximum speed, torque etc.
Motors like the CIMs are designed to be low speed high torque while motors like the old drill motors are high speed low torque. How do they do that?
1139 Alumni
Unread 16-01-2006, 18:20
Matt Adams's Avatar
Matt Adams Matt Adams is offline
b(o_o)d
FRC #1525 (Warbots)
Rookie Year: 2000
Matt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond repute
Send a message via AIM to Matt Adams
Re: Motor theory questions
Originally Posted by Rickertsen2
I was looking at the differences between the two CIM motors and started asking some questions. What internally about a PM DC brush motor define its characteristics. What factors determine the maximum speed, torque etc.
James, this is a great question. I don't know how much motor background you have, essentially knowing how a motor works, but I think there are a few websites out there that will give you a good description of how they work.
Here's one that's pretty good:
How Motors Work at HowStuffWorks.com
Once this is set, it really depends on the motor construction. Here are a few things off the top of my head:
Number of turns on the motor windings.
Thickness of windings (this affects the max current capacity).
Input Voltage (Higher voltage will yield a proportionally higher speed)
Magnet type & strength
Friction of brushes
I'm sure others can add to this discussion.
Matt
Unread 16-01-2006, 20:19
Henry_Mareck's Avatar
Henry_Mareck Henry_Mareck is offline
FRC #0418 (Purple Haze / LASA Robotics)
Team Role: Student
Henry_Mareck is a jewel in the roughHenry_Mareck is a jewel in the roughHenry_Mareck is a jewel in the rough
Send a message via AIM to Henry_Mareck
after reading that, what about the number of poles?
how important is that?
Unread 16-01-2006, 22:12
Richard Wallace's Avatar
Richard Wallace Richard Wallace is offline
I live for the details.
FRC #3620 (Average Joes)
Rookie Year: 1996
The number of poles is always even, since every north pole must return magnetic flux to a south pole.
Generally, a motor with a higher pole count will run slower and develop higher torque than another motor with a lower pole count, assuming that both motors are the same size and are rated for the same operating voltage and continuous-duty current.
Richard Wallace
since 2003
Unread 17-01-2006, 08:08
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
Jim,
Some of the factors involved are the power of the magnetic structure, the current through the windings and the number of windings. Now everyone knows that magnetic fields jump gaps but a gap is seen as a loss sort of like a resistor to magnetic field and different materials also act as losses to magnetic fields. For that reason, the choice of materials for both the magnetic structure and the armature come into play. A designer is looking to maximize a variety of factors like RPM, torque and input power for particular applications and does so by massaging all of these variables. A close look at a drill motor vs. a Fisher Price (both of which have openings at the brushes and are about the same size) will show only three commutator segments for the FP but many more for the drill. Although the free speed is close for both these motors the stall current and stall torque are nearly double for the drill.
The motor works on the principle of opposite magnetic poles attracting. Everyone who has played with permanent magnets knows that the greatest attraction occurs when the ends of the magnet are closest together, and the same is true inside the motors. In the case of the FP, there are only three coils of wire spaced 120 degrees apart so at any one time the energized coil is not very close to being inline with the magnets. The drill on the other hand has many more poles so a coil is much closer to the magnet field when current is passing through it. This is one of the reasons that the drill has superior low speed torque specs.
I know that there are other reasons, and a mentor out there (Mark McLeaod or Mike Betts, I don't remember which) does work with motor design everyday can add much more to this discussion than I can.
Al
WB9UVJ
www.wildstang.org
________________________
47 Questions! Matt Krass Games/Trivia 52 19-04-2006 00:58
Licensing Questions WebWader125 Inventor 2 03-11-2005 12:33
#1 The Journey of a FIRST Graduate: Questions Ken Leung General Forum 12 27-07-2005 18:24
Q/A questions so far.. AmyPrib Rules/Strategy 49 28-01-2005 08:39
**FIRST EMAIL**/Autodesk Inventor Training and Technical Questions Information Rich Wong FIRST E-Mail Blast Archive 0 07-12-2004 17:22
