Searching...
In the terminal window after I download the camera code it is suppose to display searching and then the camera is suppose to searching for a target. It never does and nothing is ever displayed in the terminal window.
Re: Searching...
Some things you might check or do (sorry if any of these are obvious): 1.) Verify you have downloaded Kevin Watson's 2006 Camera Code, you need IFI Loader 1.0.12 2.) Verify you have the serial connection wired correcly, we use the TTL->RS-232 adapter on the TTL port of the Robot Controller and then use a 3-wire 'PWM' cable to connect from that convertor to the robot controller's 3-pin RS-232 connector. Kevin has this described in his guide. 3.) Confirm power is applied 4.) Kevin has posted a program to verify serial communiations, though our team hasn't tried it yet, I suggest you use it to verify your setup. 5.) Kevin has some debug code that you can enable via a #define in camera.h "_DEBUG". uncomment his line and some useful debug messages should be available. Hope this helps! -Terry |
Re: Searching...
Here is what is displayed in the terminal window when debug is enabled.
Camera: Initialized abnormally with code 131 Camera: Initialization state = 1 Camera: No EEPROM configuration data found; using default parameters Camera: Initialization state = 2 Camera: Initializatoin state =3 Thanks for your information. I'll try all of it today after school. |
Re: Searching...
That sequence of debug information means the camera isn't responding to commands. It could be as simple as a disconnected wire in either the power or communication cables, or as nasty as a fried camera or TTL converter board. It's most likely to be one of two things: the PC serial cable is still plugged in to the camera and is interfering with communication, or you're using the broken release of the camera default code. See http://www.chiefdelphi.com/forums/sh...78&postcount=5 for Kevin's explanation of the problem and instructions on how to correct it.
Re: Searching...
I ran Kevins serial port diagnostics. The camera passed the first test but failed the second. What does this mean?
| Searching for a Laptop | s0lidMetal | Programming | 12 | 30-03-2005 17:36 |
| A Searching Tutorial | Katie Reynolds | CD Forum Support | 5 | 03-02-2005 16:39 |
| searching for sponsors | n0cturnalxb | General Forum | 17 | 21-09-2004 06:14 |
| searching | David Kelly | CD Forum Support | 1 | 10-08-2001 18:05 |
