Go to Post This may not be Battlebots but it sure isn't Pretty Pretty Princess Bots. - Andrew Schreiber [more]
Unread 17-01-2006, 09:36
Amittt Amittt is offline
FRC #1578
Amittt is an unknown quantity at this point
dismanteling a chain
How do I dismantle a gears chain?
please help, thanks.
Unread 17-01-2006, 09:40
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Team Role: Teacher
Re: dismanteling a chain
You need a chain breaker tool. It looks like this http://quartermidget.com/images/big_chain_breaker.jpg
You can also do it with a dremel tool and cutoff wheel, but the proper chain breaker tool is much easier.
Unread 17-01-2006, 13:40
tjanson tjanson is offline
None #1768
tjanson is an unknown quantity at this point
chain tool for a bike. you can put it back together too.
Unread 17-01-2006, 14:56
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Rookie Year: 1998
Unless I'm sorely mistaken, a bike chain tool just won't work with most any chain you'll be using on a FIRST bot. Unless you happen to in fact be using bicycle chain. The dimensions of bicycle and ANSI roller chain are vastly different, after all.
Unread 17-01-2006, 15:07
Kirk Kirk is offline
FRC #0254
Rookie Year: 1997
Kirk has much to be proud ofKirk has much to be proud ofKirk has much to be proud ofKirk has much to be proud ofKirk has much to be proud ofKirk has much to be proud ofKirk has much to be proud ofKirk has much to be proud ofKirk has much to be proud of
Send a message via AIM to Kirk
You need a chain break for roller chain. You may also want to look into a chain puller. We bought one a last year and it has been one of the most useful tools. The chain puller allows you to pull the chain back together when you are putting in a master link. Its a lot easier then using your hands or a pair of pliers.
Chain Breaker
Chain Puller
Kirk
Unread 17-01-2006, 20:38
Leo 1529's Avatar
Leo 1529 Leo 1529 is offline
uber fabricata, webmasta, president
AKA: Tzu-san
FRC #1529 (Cyber-Cards)
Team Role: Webmaster
Leo 1529 has a spectacular aura aboutLeo 1529 has a spectacular aura aboutLeo 1529 has a spectacular aura about
Kirk
if you dont have those or cant find them you could use a hammer and a screwdriver. thats what we had to do until we got the shop cleaned up and found all of the tools
Unread 17-01-2006, 21:03
Rickertsen2 Rickertsen2 is offline
Umm Errr...
None #1139 (Chamblee Gear Grinders)
Rickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant future
Send a message via AIM to Rickertsen2 Send a message via Yahoo to Rickertsen2
They are different, but in the case of a chain brake they are not different enough to need a different tool.
As mentioned above, if you don't have a chain brake, use a screwdriver and alot of hammering on one of the pins. Once you take the chain apart you will need to buy a special link called a master link to put it back together.
1139 Alumni
Unread 17-01-2006, 21:12
lrdblaster03 lrdblaster03 is offline
FRC #1626
lrdblaster03 is on a distinguished road
Zip ties make great chain pullers too.
Unread 17-01-2006, 22:44
greencactus3 greencactus3 is offline
occra 23.
AKA: ryo
None #1481
greencactus3 is a name known to allgreencactus3 is a name known to allgreencactus3 is a name known to allgreencactus3 is a name known to allgreencactus3 is a name known to allgreencactus3 is a name known to all
Send a message via AIM to greencactus3 Send a message via MSN to greencactus3
GENIUS!!!!
thatll make things SO much easier for us this year! yay! thanks!!
Unread 18-01-2006, 06:10
FRC #0254
Rookie Year: 1997
Both of those tools are invaluable for FIRST teams. Roller Chain is something that almost every robot will have. The chain break retails for 20.53 from McMaster (6051K15) and the chain puller retails for $17.56 (6052K14). The chain puller has to be ground on to make it fit between the links (nothing major just a little work with a file or grinder). So for about $45 to your door you can have the right tools for the job. It makes everything much easier and safer.
Unread 18-01-2006, 10:47
Dick Linn's Avatar
Dick Linn Dick Linn is offline
no team (Synergy)
Dick Linn has a reputation beyond reputeDick Linn has a reputation beyond reputeDick Linn has a reputation beyond reputeDick Linn has a reputation beyond reputeDick Linn has a reputation beyond reputeDick Linn has a reputation beyond reputeDick Linn has a reputation beyond reputeDick Linn has a reputation beyond reputeDick Linn has a reputation beyond reputeDick Linn has a reputation beyond reputeDick Linn has a reputation beyond repute
Send a message via AIM to Dick Linn
For years, I've just used a bench grinder to grind off the protruding portion of the pins on one side of an outside connecting plate. Grind the two pins flush to the plate or just a tad lower. Support the chain over a slightly opened vise and you can very easily tap out the rest of the link. Almost takes longer to describe it than it does to do it.
Richard Linn
Proud father of Marine LCpl. Karl R. Linn
Co-founder Team 975
KIA, Iraq 1/26/2005
Unread 26-01-2006, 11:06
None #1768
Bike chain tools do work, at least the two I've used. The the standard bike chain size is smaller, but most tools have two spots for a standard size chain and for a larger BMX chain. The BMX chain spot is just big enough to jam the #35 in. And you don't need master links to put it back together, though that can be a pain to put them together without masters. I personally think a non-master link chain is more reliable than a one with a master link, though it probably doesn't matter.
You push the pin almost out of the hole, yank on the chain to pop it apart, shorten the chain with the same method, pop the chain back together, push the pin in, and then push it back from the other side to keep it from binding.
Chain Drive chain Damelvin 3D Animation and Competition 2 15-02-2005 00:19
Aluminum chain? Brawler006 Technical Discussion 11 24-02-2004 15:52
25 or 35 chain? Alan Ing Technical Discussion 24 02-03-2003 13:56
1/4" chain and links from small parts archiver 2001 2 24-06-2002 00:18
Chain and chain breaker source? kmcclary Off-Season Events 4 22-10-2001 22:51
