Go to Post Build the wrong robot that aims well or build the right robot that can't aim.... decisions, decisions.... - Tom Bottiglieri [more]
Unread 17-01-2006, 11:36
stephenthe1 stephenthe1 is offline
stephenthe1 is on a distinguished road
CMU CAM setup
Hi,
These instructions are really hazy to me, can someone explain which cables are connecting to where, there seem to be conflicting instructions, having this clarified would help me out a lot. thanks!:
Connect the RC programming cable to the Serial Communication Port,
(com port), of the computer and the RS232 PORT, (DB9) of the Vision
Sensor Assembly.
The instructions already said to connect the DB9 cable from the vision sensor port to the computer. and here it's saying to connect the serial cable from the computer com port to the vision sensor again. why is this? Am I missing something in these sections? Where are settings for the computer's com port changed. In the actual labview application? I'm using hte tutorial located here: http://www.kevin.org/frc/CMUcam2_workbook.pdf .
thanks a bunch,
Stephen
CMU Cam prosseser running hot kjhobin Programming 4 10-01-2006 21:57
Video of the (not so) humble beginnings of the CMU cam. Elgin Clock Programming 0 29-03-2005 21:31
CMU Cam GUI Arc736UV Programming 2 15-03-2005 19:26
CMU Cam servo jitter adamdb Programming 3 01-02-2005 14:42
CMU cam and Linux? scitobor 617 Programming 2 30-01-2005 23:02
