Go to Post We can sit here and engineer this all day but I think untill one of us gets off our chair and starts making it we'll never know if its possible. - sanddrag [more]
View Poll Results: Drives Platform
2 Wheels 2 1.10%
4WD 47 25.82%
4 wheels, 2 driven 12 6.59%
6WD 73 40.11%
8WD 5 2.75%
10WD+ 5 2.75%
Tank tracks 15 8.24%
Kiwi Drive 4 2.20%
Omni Directional 4 2.20%
Crab Drive 5 2.75%
Swerve Drive 1 0.55%
Wheels? Who needs wheels? 9 4.95%
Voters: 182. You may not vote on this poll
Unread 29-01-2006, 14:12
ida_noeman's Avatar
ida_noeman ida_noeman is offline
AKA: phobbs
FRC #1719 (Umbrella Corp.)
Team Role: Mechanical
ida_noeman is on a distinguished road
Re: The Annual Drives Platform Poll
Originally Posted by Pavan
We are using the Crab Drive meathod on our robot. Also I was wondering the efficiency of the Kiwi Drive system. See the video I believe it would be easy to trap or "Pin" this robot on the sides not even needing a corner.
-Pavan
According to 4.3.4.4 <G24>, you can only pin another robot for 10 seconds before you have to back up 3 feet (then try again). Perhaps it's not that much of a disadvantage to be weak against pinning.
"Weeks of coding can save you hours of planning"
"If the code was hard to write, I'm dam well going to make it hard to read!"
Unread 29-01-2006, 14:25
Andrew Blair's Avatar
Andrew Blair Andrew Blair is offline
SAE Formula is FIRST with Gasoline.
FRC #0306 (CRT)
Andrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond repute
Send a message via AIM to Andrew Blair Send a message via Yahoo to Andrew Blair
The idea of a holonomic drive is that, on a flat field, you don't need to worry too much about being pinned because with a good driver, the bot is so fast and maneuverable that you can't get it.
Reading makes a full man, conference a ready man, and writing an exact man.
-Sir Francis Bacon
"Any intelligent fool can make things bigger, more complex, and more violent. It takes a touch of genius -- and a lot of courage -- to move in the opposite direction."
-Albert Einstein
Unread 29-01-2006, 14:56
Gdeaver Gdeaver is offline
FRC #1640
Gdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond repute
I hope that all teams that are going up the ramp have looked at the dynamic of their drive choice and the CG issues. Teams that don't could be great tippers.
Unread 29-01-2006, 15:44
Gene F's Avatar
Gene F Gene F is offline
FIRST Fanatic
AKA: Gene Falendysz
#0343 (Metal in Motion)
Gene F is a splendid one to beholdGene F is a splendid one to beholdGene F is a splendid one to beholdGene F is a splendid one to beholdGene F is a splendid one to beholdGene F is a splendid one to beholdGene F is a splendid one to beholdGene F is a splendid one to behold
Send a message via AIM to Gene F
Metal in Motion, team 343 will be on tracks again this year for the forth year in a row. We're getting quite comfortable with them. We talked about a 6 wheel base but felt there wasn't enough of an advantage to change from what we are familiar with. Look for the 6 wheel base next year!
- Gene Falendysz
Unread 03-02-2006, 08:25
Alex Cormier's Avatar
Alex Cormier Alex Cormier is online now
www.TwoPencilDesigns.com
AKA: Grizz, Twinkletoes, PitBull1126
FRC #1405
Team Role: Coach
Alex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond repute
interesting. slowly 4WD is creeping up to 6WD, who will have the most be the end of build season??
Two Pencil Designs - Vinyl Graphics, Bumper Numbers, and Strategy Items!
Like us on Facebook & follow us on Twitter
Facebook.com/TwoPencilDesigns & TwoPencilDesign
Unread 18-01-2006, 15:52
BRosser314's Avatar
BRosser314 BRosser314 is offline
Post-A-Holic
AKA: Brandon Rosser
FRC #0469 (Las Guerrillas)
BRosser314 is a splendid one to beholdBRosser314 is a splendid one to beholdBRosser314 is a splendid one to beholdBRosser314 is a splendid one to beholdBRosser314 is a splendid one to beholdBRosser314 is a splendid one to beholdBRosser314 is a splendid one to behold
Send a message via AIM to BRosser314 Send a message via Yahoo to BRosser314
Originally Posted by Kris Verdeyen
Someone please describe the difference between Crab and Swerve. And while you're at it, tell us what omni means. I'm lost. I thought Omni, crab, and swerve meant essentially the same thing.
essentially crab and swerve are similiar, but few differences. i believe that a swerve drive has one wheel that turns like a turret and having only 3 wheels in total which are all driven. so in crab all four wheels are able to spin like a turret and be driven. in omni the wheels are stationary and turn in similar direction to the way there paermanently mounted too. there are little wheels that make up the circumfrence of the wlarger wheel, say someone is pushing you from the side omni wheels allow the robot pushing you to move you a lot easier.
Unread 25-01-2006, 08:39
FRC #1405
Team Role: Coach
interesting still no 2WD or 8WD, lots of 6WD. wahoo
Unread 25-01-2006, 15:42
BRosser314's Avatar
Post-A-Holic
AKA: Brandon Rosser
I think there might be people not reading the poll properly and thinking that two wheels might mean driven only. I know there is a spot for that but there must be some confusion. I know of some teams that are going with two wheels with some rolling casters like skid plates.
Unread 25-01-2006, 18:01
devicenull devicenull is offline
Robot? We need a robot?
Rookie Year: 1234
devicenull is just really nicedevicenull is just really nicedevicenull is just really nicedevicenull is just really nicedevicenull is just really nice
Omni wheels aren't all bad, you can do lots of quick turns with them. Among other things I can spin our entire robot around one of the back wheels quite easily. I can't see how 4WD without them would be efficient without them.
Unread 25-01-2006, 20:07
Nuttyman54's Avatar
Nuttyman54 Nuttyman54 is offline
Mentor, Tactician
AKA: Evan "Numbers" Morrison
FRC #5803 (Apex Robotics) and FRC #0971 (Spartan Robotics)
Nuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond repute
Send a message via AIM to Nuttyman54
been there done that...it's not efficient at all. You either have to have low traction on one pair of wheels (front or back), or hop...a lot. it's NOT fun, especially when you're holding a tetra 7 feet in the air
Unread 25-01-2006, 15:52
Chuck Glick Chuck Glick is offline
Gone Fishin'
Chuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond repute
Send a message via AIM to Chuck Glick
we're doin 6wd but how in the world would you do 8wd or even 10wd? that seems almost impossible
Unread 25-01-2006, 16:00
Greg Needel's Avatar Unsung FIRST Hero
Greg Needel Greg Needel is offline
REVving up for a new season
FRC #2848 (All-sparks)
Greg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond repute
nothing is impossible...
Greg Needel│www.robogreg.com
Co-founder REV Robotics LLC www.REVrobotics.com
2014 FRC World Champions with 254, 469, & 74
Unread 25-01-2006, 16:06
FRC #0306 (CRT)
Hmmm. It would seem that it would be quite easy with an omni drive...I'm thinking up to, say 60! If you count the rollers...
I'm just curious to see what this year will be like. The omnis are going to have trouble getting up the ramp, but they'll be unstoppable at center goal defense. We'll see...
-Sir Francis Bacon
-Albert Einstein
Unread 25-01-2006, 19:40
Gone Fishin'
well i know that but ten wheels with all drive, either thats a lot of chain or something
  #15   Spotlight this post!
Unread 25-01-2006, 22:38
greencactus3 greencactus3 is offline
occra 23.
AKA: ryo
None #1481
greencactus3 is a name known to allgreencactus3 is a name known to allgreencactus3 is a name known to allgreencactus3 is a name known to allgreencactus3 is a name known to allgreencactus3 is a name known to all
Send a message via AIM to greencactus3 Send a message via MSN to greencactus3
do duallys count as 2? or are you counting independant axles?
so if a robot had a 6wd platform but each driven axle had duallys on each, is that 12WD or 6WD?
4th Annual Tournament of Rosie Rosiebotboss General Forum 1 31-05-2005 11:12
Time for the annual <fill in the blank> thread Gary Dillard General Forum 6 07-01-2005 22:55
**FIRST EMAIL**/FIRST Annual Fund Message from James R. Utaski, FIRST Board of Direct miketwalker FIRST E-Mail Blast Archive 0 27-05-2004 11:25
**FIRST EMAIL**/First Annual FIRST Robotics Conference, April 16 April 18, 2004 for t miketwalker FIRST E-Mail Blast Archive 6 04-04-2004 18:31
idea: a semi-official coaches poll archiver 1999 8 23-06-2002 22:23
