Go to Post One day the code will be written first, and then a robot built around it - dag0620 [more]
Unread 17-01-2006, 19:34
Greg Needel's Avatar Unsung FIRST Hero
Greg Needel Greg Needel is offline
REVving up for a new season
FRC #2848 (All-sparks)
Greg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond repute
Bad Pwm cables
so we were hooking up the the controls to the kit bot today and found 2 bad pwm cables (new from the kit) I just was wondering if anyone else has encountered a bad set of pwm cables in there set.
I guess you can also heed this as a warning if something is not working from your initial setup check the cables.
Greg Needel│www.robogreg.com
Co-founder REV Robotics LLC www.REVrobotics.com
2014 FRC World Champions with 254, 469, & 74
Unread 17-01-2006, 19:40
KenWittlief KenWittlief is offline
KenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond repute
Re: Bad Pwm cables
Ive definately seen bad PWM cables before. I cant say whether they were bad out of the box, but its something everyone shoud keep in mind
and check with an ohm meter if you have any doubt.
the connector pins are crimped on - sometimes they dont make electrical contact.
Unread 17-01-2006, 20:53
Rickertsen2 Rickertsen2 is offline
Umm Errr...
None #1139 (Chamblee Gear Grinders)
Rickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant future
Send a message via AIM to Rickertsen2 Send a message via Yahoo to Rickertsen2
Re: Bad Pwm cables
The PWM cables have always had a problem and are i feel the weekest point of the control system.
1139 Alumni
Unread 17-01-2006, 21:01
Travis Hoffman's Avatar Unsung FIRST Hero
Travis Hoffman Travis Hoffman is offline
O-H
FRC #0048 (Delphi E.L.I.T.E.)
Travis Hoffman has a reputation beyond reputeTravis Hoffman has a reputation beyond reputeTravis Hoffman has a reputation beyond reputeTravis Hoffman has a reputation beyond reputeTravis Hoffman has a reputation beyond reputeTravis Hoffman has a reputation beyond reputeTravis Hoffman has a reputation beyond reputeTravis Hoffman has a reputation beyond reputeTravis Hoffman has a reputation beyond reputeTravis Hoffman has a reputation beyond reputeTravis Hoffman has a reputation beyond repute
Re: Bad Pwm cables
I assume you checked the continuity of the cable with a meter, but FYI, in recent years we've found that the male end of the PWM cable sometimes engages very poorly with the connector on the speed controller, even if it seems the connector has been inserted all the way. We've had to pull them out and reseat them several times to get everything to work. Luckily, once seated properly, we haven't observed any intermittent problems after that.
Travis Hoffman, Enginerd, FRC Team 48 Delphi E.L.I.T.E.
Encouraging Learning in Technology and Engineering - www.delphielite.com
NEOFRA - Northeast Ohio FIRST Robotics Alliance - www.neofra.com
NEOFRA / Delphi E.L.I.T.E. FLL Regional Partner
Unread 17-01-2006, 21:32
Andrew Blair's Avatar
Andrew Blair Andrew Blair is offline
SAE Formula is FIRST with Gasoline.
FRC #0306 (CRT)
Andrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond repute
Send a message via AIM to Andrew Blair Send a message via Yahoo to Andrew Blair
Re: Bad Pwm cables
Yes, the new Victors can be real pains as far as getting a PWM into them. We had to completely omit using some of them; they simply wouldn't do anything after seemingly seating the PWM. Some would work, some wouldn't. I hope IFI has fixed this...
Reading makes a full man, conference a ready man, and writing an exact man.
-Sir Francis Bacon
"Any intelligent fool can make things bigger, more complex, and more violent. It takes a touch of genius -- and a lot of courage -- to move in the opposite direction."
-Albert Einstein
Unread 17-01-2006, 21:47
Mike Martus's Avatar Unsung FIRST Hero
Mike Martus Mike Martus is offline
FRC #0051 (Wings of Fire)
Team Role: Coach
Rookie Year: 1996
Mike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond repute
Re: Bad Pwm cables
Before you throw the cable away and blame them take a look at the speed controller where they plug in. I was shown by the guys at Innovation FIRST that a small piece of flashing (thin plastic) is sometimes in the hole during the manufacture of the speed controller. Taking a thin sharp object you can remove this and the PWM wire will seat correctly.
We found this to be the case on many of the speed controllers.
This is a basic check we make on all controllers using a magnifying head gear to replace my old eyes.
Mike Martus
Unread 18-01-2006, 07:28
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
Re: Bad Pwm cables
This has been the case for several years. It comes with practice but the PWM connector does not always seat all the way into the speed controller. If you take a look at a working controller and compare it to one with a suspected bad cable you will see the difference, about 1/8" less engagement on the bad one.
Al
WB9UVJ
www.wildstang.org
________________________
Unread 18-01-2006, 23:13
Uberbots's Avatar
Uberbots Uberbots is offline
Mad Programmer
AKA: Billy Sisson
FRC #1124 (ÜberBots)
Uberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond repute
Re: Bad Pwm cables
yes we have had that problem before.
sometimes a litlle bit of solder (or auder whatever the spelling is) where the crimps are supposed to be helps a bit where the wires dont make contact.
but we have had dead wires before (non-connection-based)... and were too lazy to fix them so we make sure we order a lot of PWM cables.
A few of my favorite numbers:
175 176 177 195 230 558 716 1024 1071 1592 1784 1816
RPI 2012
BREAKAWAY
PWM Extention Cables: 4 Shall Be the Limit Joe Johnson FIRST Tech Challenge 4 12-04-2005 23:33
PWM cables: too fragile? what fixes/precautions? BillCloyes Control System 18 14-03-2005 17:34
The PWM Cables amateurrobotguy General Forum 1 22-02-2005 17:42
Can we shorten the PWM cables? RAWdealer59 Electrical 3 18-02-2003 15:49
Loss of signal in PWM cables. archiver 2001 6 23-06-2002 23:29
