Go to Post Being involved with FIRST is a privilege, not a right. - Katie Reynolds [more]
Unread 17-01-2006, 21:09
Andrew Schuetze's Avatar
Andrew Schuetze Andrew Schuetze is offline
499 Founder / Alamo FTC & FLL AP
Team Role: Leadership
Andrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond repute
Question fusing ends of latex tubing
We are attempting to make a ball conveyor using the latex tubing supplied in the kit of parts. What successful methods have been used in the past
We applied some rubber cement from a tire patch kit on the outside walls and then slide it into some heat shrink tubing. A heat gun and 2 hours later and it appeared to be holding well ... then it came loose
Does splicing work with thread wound around???
Thanks in advance,
APS
APS
Founder FRC 499
Parent alumni FRC 2745 & 4219
Co-Coach FTC 4549 & 6407
Alamo FTC Affiliate Partner
Alamo FLL Affiliate Partner
telescoping arm CharlieWilken Technical Discussion 45 26-01-2004 22:22
Can you use other tubing? Skabana159 Pneumatics 2 06-02-2003 22:04
latex tubing rules?? Christina Technical Discussion 4 21-02-2002 18:43
Legality of steel tubing. newy Rules/Strategy 3 01-02-2002 09:16
does small parts sell rectangular aluminum tubing mnkysp6353 General Forum 2 09-12-2001 01:28
